01-07-2021, 12:16 PM | #3276 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-07-2021, 12:42 PM | #3277 |
Re: PO has me PO'd
16100376010412674429208406588402 by James Jaros, on Flickr
Don't lose roll pin or wave washer as they don't come in the package
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-07-2021 at 12:48 PM. |
02-07-2021, 10:49 AM | #3278 |
Re: PO has me PO'd
Now you did it big time,jinx
16127092134329001020493342322196 by [url=https://www.flickr.com/photos/97391199@N06 But, 70 degrees in the shop
02-07-2021, 10:56 AM | #3279 |
Carpe manana
Re: PO has me PO'd
Looks real pretty though. It’s -19 here right now.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-07-2021, 11:03 AM | #3280 |
Re: PO has me PO'd
Started a jig to support window frame
1612709999404596003859227051884 by [url=https://www.flickr.com/photos/97391199@N
02-07-2021, 11:05 AM | #3281 |
Re: PO has me PO'd
thats my record temperture for fishing in NY for steelhead
Time to start up snowblower
03-17-2021, 06:46 PM | #3282 |
Re: PO has me PO'd
Did someone mention steelhead?And cold, nay I say Oregon
03-28-2021, 10:27 AM | #3283 |
Re: PO has me PO'd
Thats a great looking fishing hole, enjoy
03-29-2021, 11:01 AM | #3284 |
Re: PO has me PO'd
161702980659020955855144450075 by [url=https://www.flickr.com/photos/97391199@N06
The other day I was looking thru the classifieds and came across a thread for parts needed for wind windows, followed the link to car and truck site They had the division bar in shock, ordered the part and was happy with what I received, but, I didn't read the note which mentioned the original felt channel that was not included Ordered that part and was even more pleased with parts Originally what was supplied was a sticky thin piece of felt, which may have worked, but was the wrong thickness for the glass, so if you order the division bar, don't cheap out. Buy the felt with it as recommended in the notes The bead on the division bar is exact replica Now, I have to drill all the holes for the rivets
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2021 at 11:23 AM. |
04-05-2021, 09:55 AM | #3285 |
Re: PO has me PO'd
Drilling new holes in division bar, stainless steel ,so make sure to use a cutting fluid, or you may work harden material
16176305772346572405670059651929 by 16176304306102791501434747171038 by [url=https://www.flickr.com/photos/97391199@N06 Using old division bar as a template
07-10-2021, 09:43 AM | #3286 |
Re: PO has me PO'd
16259242469812399531286890872079 by [url=https://www.flickr.com/photos/97391199@N06
Been working on my aftermarket doors, couldn't get the gaps right, so I tried something extreme, I jacked the body up, about 1 inch and got the gap you see. Now just have makeup a body mount to fit
07-10-2021, 09:49 PM | #3287 |
Re: PO has me PO'd
1 inch seems like alot to shim a body mount
07-11-2021, 09:32 AM | #3288 |
Re: PO has me PO'd
Well actually the original mount is 1/2” and the space to get the door lined up is 1/2”, so considering age of truck maybe the rubber mount is shot. Don’t know what size they should be
Thanks for the input
07-22-2021, 11:34 AM | #3289 |
Re: PO has me PO'd
Picked up a new helmet from yes welder, about 60 dollars, needed one for awhile
16269677645786977449666548940319 by 16269680015024971326383071013235 by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-22-2021 at 12:00 PM. Reason: New pic |
08-03-2021, 10:19 AM | #3290 |
Re: PO has me PO'd
New tool 300 watt American beauty soldering Iron
Don't want to use bondo, just lead 1628000088984249214174123495496 by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-04-2021 at 09:29 AM. |
08-03-2021, 10:48 AM | #3291 |
Re: PO has me PO'd
Correct thickness to get my door gaps, oem on right side
16280019717295277883792602035810 by [url=https://www.flickr.com/photos/97391199@N06
08-03-2021, 11:08 AM | #3292 |
Re: PO has me PO'd
Gaps look workable
16280031752258545380681853025694 by [url=https://www.flickr.com/photos/97391199@N06
09-13-2021, 10:35 AM | #3293 |
Re: PO has me PO'd
16315432678685759242049036878614 by [url=https://www.flickr.com/photos/97391199@N06
Started to grind down welds to see if leading works waiting on tinning butter to arrive from eastwood
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-14-2021 at 09:34 AM. |
09-16-2021, 10:14 AM | #3294 |
Re: PO has me PO'd
[url=https://flic.kr/p/2mrk3Px]
Working on my weatherstripping ,making sure my door closes right, I put down 1 layer of cement, dry to the touch, then add 1 more wet and clamp in place Once you get it started its easy to turn inside out or backwards to apply glue
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-16-2021 at 01:27 PM. |
09-16-2021, 01:28 PM | #3295 |
Re: PO has me PO'd
16318049326633600541790131990024 by [url=https://www.flickr.com/photos/97391199@N06
09-26-2021, 08:19 AM | #3296 |
Re: PO has me PO'd
16326585196707778945394499907987 by [url=https://www.flickr.com/photos/97391199@N06
Don't know where this gap came from, nor how to fix
09-26-2021, 10:12 AM | #3297 |
Re: PO has me PO'd
16326654041606314819141062400952 by [url=https://www.flickr.com/photos/97391199@N06
09-26-2021, 11:01 AM | #3298 |
Re: PO has me PO'd
16326682957322477564073761525475 by [url=https://www.flickr.com/photos/97391199@N06
09-26-2021, 11:40 AM | #3299 |
Re: PO has me PO'd
Computers are out for safety
16326685308443721197222329170359 by [url=https://www.flickr.com/photos/97391199@N06
09-29-2021, 11:11 AM | #3300 |
Re: PO has me PO'd
