Closed Thread
Old 03-21-2014, 01:29 AM   #3276
yossarian19
Re: What Did You Do With Your Truck Today ?
Got it into the garage under it's own power (!) and got rid of 10 or so rivets to get rid of some un-needed frame.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 03-21-2014, 05:12 PM   #3277
OrrieG
OrrieG's Avatar
Originally Posted by tbrown5079 View Post
After all the stressing out over the fuel system I went to the local guy that does my hoses and got it started. All that stress over nothing. I pick up the hard line tomorrow, then measure for the braided hose to the fuel rail.
Seems like that is how it goes. The things we worry about the most end up being easy. I think it is because we do it so many times in our head it seems familar. I was that way about the door hinge pins. Put it off for ever and ended up taking less than half an hour for the pair that needed fixed.
OrrieG is offline
Old 03-21-2014, 05:51 PM   #3278
waybad
waybad's Avatar
took the 55 to a glass place to get a new gasket installed,,,,, you guessed it,, they broke the windshield it will be Monday before they can get a new one..hopefully I don't have to pay for it
waybad is offline
Old 03-21-2014, 09:10 PM   #3279
tbrown5079
Filled the radiator and tank with antifreeze and ran the gas line up the frame rail. will get the bend put on it tomorrow and connect to the filter/regulator. then I can measure for the braided hose to the fuel rail. Maybe startup next week!
tbrown's 56 Cameo Build
tbrown5079 is offline
Old 03-23-2014, 12:33 AM   #3280
OrrieG
OrrieG's Avatar
It is alive. Put in the new starter, primed the carb, added 2.5 more gallons to the tank and it fired on the first crank. Would not idle, looks like the used carb that was "just taken off a running car" is shot. But it moved under its own power, more detail in the build thread.
OrrieG is offline
Old 03-23-2014, 04:29 AM   #3281
agnes the dog
agnes the dog's Avatar
I put on some new shorter gas shocks on the rear. Wow! What a difference. Also put in a new distributor. Still working out the bugs on the timing and carb tuning.
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline
Old 03-23-2014, 07:12 AM   #3282
FarmerSid
FarmerSid's Avatar
Got firewall finished and drivers floor in.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline
Old 03-23-2014, 02:53 PM   #3283
OrrieG
OrrieG's Avatar
Short Video, first time I have tried this, sorry for it being sideways, phone does that, now I know.
http://s1156.photobucket.com/user/Or...ipped.mp4.html
OrrieG is offline
Old 03-23-2014, 02:59 PM   #3284
hsdropout
Got first rubber on the asphalt............yee haww.......(forward & reverse).
The 355 is a torque monster!
R&P power steering works excellent..........well..........in the driveway.
Gambled on the 350 TH with new TC and fluids, seems to be good.
Front discs-rear drums good...........well again........in the driveway.
hsdropout is offline
Old 03-23-2014, 03:03 PM   #3285
crossfire84
crossfire84's Avatar
good work! looks great.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 03-23-2014, 06:50 PM   #3286
OrrieG
OrrieG's Avatar
Switched the gas gauge lines and all is well, but cost me some blood, tight fit up there. Also noticed that one turn signal lamp is dimmly glowing with the key off, so get to start the search for a reason. suspect original 1959 light switch....
OrrieG is offline
Old 03-24-2014, 06:02 AM   #3287
lazypineapple
lazypineapple's Avatar
Mounted front bumper. Tucked it in 3".
lazypineapple is offline
Old 03-24-2014, 07:10 AM   #3288
dubie
dubie's Avatar
I had my son out in the shop learning how to handle a spray gun on the weekend. We got the bed in black epoxy on Satuday.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 03-24-2014, 08:31 AM   #3289
hyatt
took the burb to painter to do his magic
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline
Old 03-24-2014, 11:53 AM   #3290
OrrieG
OrrieG's Avatar
duh, can't be the light switch, brake and turn are not switched...search continues..
OrrieG is offline
Old 03-24-2014, 08:37 PM   #3291
tbrown5079
Bent and installed fuel line. Mounted drivers side mirror. Looks like they are going to work fine!
Old 03-25-2014, 06:37 PM   #3292
FarmerSid
FarmerSid's Avatar
Some of the firewall and floor work I've been doing. I think I have worn out my hammer and dollies.
C4 IFS & D44 IRS
5.3 HO L33
Old 03-26-2014, 04:20 PM   #3293
ol'orange
ol'orange's Avatar
yesterday I replaced fuel lines all the way up to the tank, I'll have to finish cleaning the tank and install that, then bend up the remainder of the fuel line. all on the GMC.
72' K10 LWB (Ole' orange)
59' 150 LWB (latest addition, open to suggestions)
01' Ram 1500 (great white)
98' Honda civic (cirvics)
ol'orange is offline
Old 03-26-2014, 04:28 PM   #3294
BADAZ chevy guy
BADAZ chevy guy's Avatar
Today... I sat and looked longingly at photos of it and wished it was here so I could work on it.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 03-26-2014, 04:33 PM   #3295
yossarian19
Yesterday I build the pipe from Driver's exhaust manifold to where I'll hang the muffler & found a place to put the first exhaust hanger.
Today I ordered some glass packs for it.
"Over my head"
Old 03-26-2014, 10:49 PM   #3296
youngrodder
youngrodder's Avatar
Pulled all of the glass out of the 53 suburban.
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline
Old 03-27-2014, 09:48 AM   #3297
lgoodso1
Started on sandblasting the frame on my 57 3200, word of advice make sure your shop door is closed all the way. Had media all over inside my shop, learned from that one lol.
lgoodso1 is offline
Old 03-27-2014, 11:10 AM   #3298
dubie
dubie's Avatar
Put the bed back on after spraying the epoxy primer
dubie is offline
Old 03-27-2014, 12:44 PM   #3299
Daze57
Daze57's Avatar
dubie
truck looks great !!! very ''sinister''
Daze57 is offline
Old 03-27-2014, 03:16 PM   #3300
Sam03
Sam03's Avatar
pulled the cab and steering off and started cleaning the frame.
1st Series 55 Chevy Pickup
235 4 speed
Sam03 is offline
Closed Thread
