09-10-2011, 12:50 PM | #3351 |
Daring to be Different
Re: Project Vitamin C-10
That's true.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
09-10-2011, 10:40 PM | #3352 |
1 thing at a time is progress.
That would be great, but would anything get done or would we just talk about doing something.
So far all I have scratched is the frame. Not much shop time today, but I'm studing the schematics and planning while watching the race. 13 cautions and just half way thru. Questions: Is there any reason why I can't keep the relay inside the cab? I know the reason for a relay is the reduce the bigger wires from being in the cab. So that means I need to keep it close to the battery. I just don't want a lot of wires in the engine bay. Info: I am running a single fan with two terminals. Fuse panel Spot #1 to one side of the temp sensor included in the relay package. Then the other wire from the sensor to the yellow wire of the relay. Spot #2 unsure what to connect there if anything. The only thing I can think of is the ground wire from the fan or the ground from the relay. Relay Red wire- to the battery. Black wire-to chassis ground close to the battery Green wire- to the AC controller, which will be discussed in a later post Orange wire- power to the fan with the fan grounded to the chassis. Let me know if I'm getting close to having it right. I don't want to wire up something I'm not sure of and have to redo it. Shannon and I went junkin' today and I picked up the connectors for brake lights. Ok my brain is smoking.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 09-10-2011 at 10:49 PM. |
09-11-2011, 09:26 PM | #3353 | |
But Found Her 25yrs Later!
Side question,
You posted this in another thread. Do you remember what brand support brace you used here?: Quote:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-12-2011, 07:12 AM | #3354 | |
Has any body looked at my wiring question 2 post above?
Alan
Philippians 2:14-16 |
09-12-2011, 10:29 AM | #3355 |
I would mount the fan relay close to the fan. Not in the cab. Run a temp switch to turn on the fan, or a switch where ever you want.
09-12-2011, 08:41 PM | #3356 | |
There's my $.02
09-12-2011, 08:47 PM | #3357 |
Thanks guys, I'm going to repost my question for clarity.
I'm studing the schematics and planning. Questions: Is there any reason why I can't keep the relay inside the cab? I know the reason for a relay is the reduce the bigger wires from being in the cab. So that means I need to keep it close to the battery. I just don't want a lot of wires in the engine bay. Info: I am running a single fan with two terminals. My plan Fuse panel Spot #1 to one side of the temp sensor included in the relay package. Then the other wire from the sensor to the yellow wire of the relay. Spot #2 unsure what to connect there if anything. The only thing I can think of is the ground wire from the fan or the ground from the relay. Relay Red wire- to the battery. Black wire-to chassis ground close to the battery Green wire- to the AC controller, which will be discussed in a later post Orange wire- power to the fan with the fan grounded to the chassis. Let me know if I'm getting close to having it right. I don't want to wire up something I'm not sure of and have to redo it.
Alan
09-12-2011, 10:02 PM | #3358 |
HOW long until spring??
Alan , Just got home, This working for a living screws up my free time
1) the relay is usually located close to the power source and the load as Dennis mentioned. The relay could be hidden be behind the grille off to a side out of view if you wanted. Keeping the relay close to the load keeps the voltage drop to a minimum with the heavier wires doing the work and then the smaller gauge coil wires running back to the cab to turn things on and off. 2) I think you have the right idea with the plan , I am not sure what you mean by spot 1 and spot 2, Would that be the terminal location from the terminal block(panel connection block)?? I cannot quite make out the terminal numbers on page 1 But with a single fan you would only need the one output from the N.O. relay contacts to the fan motor. 3) use a good grounding method, I like to extend all the ground wires to a common area and ground them together and then to the frame or back to the battery or block. I have found on old cars and especially trailer lights, most electrical problems are really grounding problems, Now, looking into the future,, Are you planning to run the high and low beam relays for your headlights??? maybe they all can be hid in a shiny junction box or concealed in the same location behind the grille or headlight bucket area???,
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
09-12-2011, 10:42 PM | #3359 |
Not to confuse the situation, but I use relays to ground also. I did that with air bag compressors, and worked great. No come backs or melted wires.
09-12-2011, 10:44 PM | #3360 | |
So do I need to connect anything to the terminal #2 on the fuse block? It's showing a switch or sending unit to ground. I don't think I need to connect anything there.
Alan
09-12-2011, 10:45 PM | #3361 |
Alan
09-12-2011, 10:46 PM | #3362 |
Sorry for that.
09-12-2011, 10:48 PM | #3363 |
Instead of powering the compressor, I use the relay to switch on the ground. Make sense?
09-12-2011, 11:43 PM | #3364 |
Alan
09-13-2011, 09:38 AM | #3365 | |
PITbut
fixit-p Awesome guy.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-14-2011, 12:37 PM | #3366 |
Lots of progress, looking good!! I'm still not getting notifications on your thread like I used too so I forget to stop by more often
09-14-2011, 03:32 PM | #3367 |
After I commented, I started to think. I'm about to wire up the fan on the 57 Panel I'm working on. Here's American Auto Wire's diagram. I'm going to install the relay close to the fan.
09-14-2011, 11:23 PM | #3368 | |
The other threads I am subscribed to are still working... I will have to look into this when I get time
09-14-2011, 11:49 PM | #3369 |
I made these diagrams to help my customers.
This is how I wire up a compressor for air bags with the relay switching positive power. It can be used for cooling fans also. This one is with negative switching. I think it works best for higher amp draws. Use a 30/40 amp relay. I never had overheated wires or terminals this way.
09-15-2011, 12:12 AM | #3370 |
Just a quick note, I'm not getting all the notifications either from any threads. I think I got two notifications all day from other threads. It's really sporadic.
Alan
09-15-2011, 12:19 AM | #3371 |
I get all the notices. No problem here.
Maybe it your Smart Phone settings?
09-15-2011, 12:41 AM | #3372 |
VA72C10
who's your email carrier? I'm looking into it...
Looking for a 67-72 swb or blazer project in or around VA. |
09-15-2011, 12:49 AM | #3373 | |
I think it's one of the most annoying things ever so I just set up cron jobs to visit the forums every few minutes to keep me updated |
09-15-2011, 01:57 AM | #3374 | |
VA72C10
I already get well over a hundred emails a day from this site...it'd be more like 5-600 if i got one for every single post
09-15-2011, 01:19 PM | #3375 |
I use yahoo. I check my build at least once a day and here lately I hardly get any notifications of new post. There are a couple post I get notifications daily and haven't checked that particular thread for some time. Thanks for looking into it.
Alan
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
