02-05-2012, 12:10 AM | #3351 |
Re: What did you do to your truck today!
Hey slick67 what brand dash bezel is that, very interesting pattern to it.
02-05-2012, 12:22 AM | #3352 |
got some more welding and grinding done to the frame rails. have to finish up the weld finishing up front tomorrow and then its ready to have a some primer and satin black shot on it in most places. then i can set the cab and clip on it and hope for an engine to start fitment
ryan |
02-05-2012, 12:53 AM | #3353 |
Sofa King Crazy!!
Got it from Outback Truck Parts. Not sure of the brand, but it's a standard bezel in all chrome.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
02-05-2012, 01:09 AM | #3354 |
Ridin' Dirty
Pulled the 305 out of my 68 to make room for a 350.
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
02-05-2012, 01:15 AM | #3355 |
Threw on some new bfg's
02-05-2012, 02:19 AM | #3356 |
C/10 junkie
What size are those bfg's??
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
02-05-2012, 06:54 AM | #3357 |
Finished up the complete overhaul of the rear brakes, and rearend. All new springs, shoes and drums. All new axle bearings and seals. New rearend gasket,and fresh 80w 90. Put the new driveshaft in. All new U Joints and Carrier Bearing. Had it extended 2 5/8". Fit like a charm. At least something went in without A fight or trip to the Parts Store!.
It got too dark for pics. will take some and post later today. Plan on getting the door seals and new regulators in today. |
02-05-2012, 07:24 AM | #3358 |
I installed some sweet hubs that I purchased on ebay.
I know I can! I know i can! 72 K20 Restoration |
02-05-2012, 07:29 AM | #3359 |
02-05-2012, 10:58 AM | #3360 |
Got all my vent window felts, door seals, and the window felts and rubber scraper seals, so painted all the metal around vent window, and the metal at bottom of window with Por15Door has sound barrier inside and evrything is ready to install. Pasenger door only, will do drivers side next weekend.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
02-05-2012, 12:14 PM | #3361 |
May have found the culprit to my charging problem... Loose connection on the alternator .. Bought a new battery and had the alt. checked and my pops always told me check the simplest things 1st
Posted via Mobile Device |
02-05-2012, 12:40 PM | #3362 |
A day late and $1 short...
Picked my buddy buckets up from being blasted and painted (por-15)...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-06-2012, 03:01 AM | #3363 |
For the first time since I bought my truck 11 months ago... I actually used it as a truck. Hauled a bed in it.
02-06-2012, 03:56 AM | #3364 |
I've got grease on my mind.
Turned this...into this!
02-06-2012, 08:57 AM | #3366 |
Smoothing out some small problem places in the bed..... still trying to build my skills really......A couple of the areas turned out nice.....A couple need work!!!
02-06-2012, 10:44 AM | #3367 |
Sofa King Crazy!!
02-06-2012, 02:52 PM | #3368 |
02-08-2012, 07:55 PM | #3369 |
Finally got a new windshield installed. Glass company came out to my shop(10 miles from town) installed the windshield. $150.00 total. Took him 30 min and he did a great job.
02-08-2012, 08:08 PM | #3370 |
Cadillac power
I stared at it longingly as I stumbled past the shop on my way to work. I imagine I'll do the same when I get home at 10:30.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style. --Scott Adams author of Dilbert |
02-08-2012, 09:18 PM | #3371 |
I started my 70 stepper& was only going to drive it around the building but, once I got going I drove it for an hour good stuff! cheers, Pat
02-08-2012, 10:09 PM | #3372 |
Rebuilt both drivers and passenger side wing windows. All new rubber seals and rivits. Took about an hour and a half per side. The hardest part was getting the window into the channel with the rubber seal!.
Here are some pics! |
02-08-2012, 10:24 PM | #3373 |
Worked on restoring a set of seat belt retractors and painting an amrest.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
02-09-2012, 12:04 AM | #3374 |
found the right connector to get my turn signals, brake lights, and horn to work. finally, turn signals, not that its really needed, here
02-09-2012, 04:02 AM | #3375 | |
Collector of Projects
I installed ONE furd mirror on the door. I need to adjust the hole a little bit and then duplicate the measuremens on the driver side.... |
