07-18-2016, 07:41 PM | #1 |
Re: What did you do to your truck today? Chapter II
Changed the front wheel bearings, races, and wb seal today. for the last couple of weeks I was getting a slight vibration at 55 mph and a 'chirp' or click every once in a while. thought maybe a U joint but decided to check wheel bearings 1st. no clicking and no more vibrations. happy dance..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
07-18-2016, 09:19 PM | #2 |
I made some progress today: I was over at my parents' house anyway so I cut out the bracket that will hold my replacement windshield washer pump. I wanted to cut it out of 1/8" steel but dad suggested I use 1/8" aluminum since he had some scrap and it would be easier to cut.
I used my Dremel tool and although the piece ended up a bit bigger than the template (usually does, right?) I think it will work fine. I am going to place it up against the washer bottle bracket tomorrow to check the bolt holes and then finish the project. |
07-21-2016, 01:05 PM | #3 |
Nice looking scoops. Great idea too.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
07-21-2016, 02:58 PM | #4 |
Old member
Here you go!
Those are nice and metal too! Cool.
07-25-2016, 12:25 AM | #5 |
My cousin (poweredbychevy) and I swapped out the steering column on my 68.. Pretty easy and straight forward.. Gonna install the lokar linkage and steering wheel tomorrow after work
07-25-2016, 12:52 AM | #6 |
I pulled an all nighter last night just in case those prowlers wanted to pay me another visit. I was hoping to be able to stay up all day also but that didn't work so I ended up taking an unplanned nap!
I did though, get some work in on my new windshield washer pump bracket. I nearly have it finished and should be able to get it bolted to the bottle bracket tomorrow. |
07-25-2016, 05:52 AM | #7 |
Sandblasted and primed some more of my small parts last night Some headway is better than no headway
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
07-27-2016, 07:43 AM | #8 |
I have a HUGE pile of small parts sitting next to my blast cabinet that I just cleaned and refilled with glass beads , It sits in my 10X24 tool room that's been over 100 degrees for a few weeks now so I installed a new A/C-Heat unit in the wall and I can finally get back to some blasting myself . How does that pile of parts GROW SO FAST ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-25-2016, 06:31 AM | #9 |
Dropped spindles new shocks lowered resr springs adjustable trsck bar repack bearings. New front pads fix exhaust relocate gas tank to rear. New fuel lines. On the hottest weekend
07-26-2016, 01:32 AM | #10 |
Started wiring my new gauge set. Hope to be back on the road by Oct.
07-27-2016, 07:39 PM | #11 |
Installed some CPP lowering springs. Here is the after...
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
07-27-2016, 10:42 PM | #12 |
Looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-28-2016, 12:42 AM | #13 |
I made my longbed a shortbed, well the frame anyway....
07-28-2016, 07:52 AM | #14 |
I got half my of my new disc brakes installed. Now for the other side, new booster, master and bleeding. I hope I am done by Saturday.
07-31-2016, 01:32 AM | #15 |
Wrestled the first inner fender today after repaint
08-03-2016, 07:58 PM | #16 |
09-08-2016, 03:00 PM | #17 |
Nice truck, is it a stock GM color? What is the color name/code?
'67 c10 cst farm truck |
07-27-2016, 07:42 PM | #18 |
Before...
07-27-2016, 08:07 PM | #19 |
Well i just received my wiring harness looks really good great quality from what i can tell, guess i know what i'll be doing for the next few days in my a/c lol!!! its been so hot here the pool is like a hot tub!!!
07-31-2016, 10:16 AM | #20 |
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
07-31-2016, 01:17 PM | #21 |
Fixing up this foam for new covers. Dodge buddies I bought last year.
http://67-72chevytrucks.com/vboard/a...1&d=1469985197 |
07-31-2016, 11:09 PM | #22 |
Finished my inner fender install today. Both painted body color. Now on to getting the bed finished this coming weekend.
07-27-2016, 08:20 PM | #23 |
New rear wheel houses bolted up today.
07-27-2016, 09:57 PM | #24 |
Looking good, your truck is going to be to nice to drive, will have to make it a trailer queen.
GARY 67 LWB CST FLEET 56 CHEV 3100 55 CHEV BEL AIR 2DR SEDAN 67 BUICK GS400 CONVERT |
08-01-2016, 12:20 AM | #25 |
My stepdad threw an open pair of sheers "too me" yesterday morning. He's not quite right anymore (85, Marine Lt. Col.). I was backed up against a ledge at the time adjusting sprinklers. Anyway, it was my hand or upper chest, so off to the doc. tomorrow for a stab wound on the palm..................But I had prior arrangements (ha!), so I tore down the bed. Today was get organized day and I cleaned up the reverse housings...........Man, the rubber on three of four pieces were a mess. I realized today it's not corrosion, or at least mine weren't. The dirt came of with oil, rubber cleaner and a wire brush on a low setting. Took some patience like most everything else, but they turned out nice.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-01-2016 at 12:26 AM. |
