Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-21-2019, 08:34 PM   #326
Blackfyre77
Re: Color Wiring Diagram FINISHED
Which are 12v switched and 12v constant? Is "alternator" constant and "terminal by battery" switched?
Blackfyre77 is offline   Reply With Quote
Old 07-21-2019, 09:30 PM   #327
dmjlambert
dmjlambert's Avatar
Electricity from the alternator and the battery are connected together, and are not switched, they are always on.
There are some circuits that are always on, and some that are switched on with the key in the accessory or on positions, and some that are switched on only when the key is in the on position.
Have a look at the wiring diagram and the wire colors, especially the wires that come from the ignition switch and go to the fuse panel.
The fuse panel back is what you see on the wiring diagram, so it is a mirror image of the front of the panel. Here is a diagram of the front of the fuse panel and what is switched and what is not.
http://67-72chevytrucks.com/vboard/s...98#post8004798
dmjlambert is offline   Reply With Quote
Old 05-24-2020, 03:04 PM   #328
Xavier
Figured I'd share a complete version with some of the corrections people have been pointing out as well as some modifications of my own to make it not quite as long.
This is for an HEI and 10/12SI setup but I have the files to overlay points or CS130 as well if anyone would like them. I also have it in PDF format which has been easier to print for me.
https://imgur.com/a/Yfjpeqv
Xavier is offline   Reply With Quote
Old 05-24-2020, 07:18 PM   #329
Xavier
This should work: PDF with different wiring possibilities.
Old 05-24-2020, 07:40 PM   #330
dmjlambert
dmjlambert's Avatar
Wow that sure is nice!
Old 05-24-2020, 09:06 PM   #331
jonmc56
jonmc56's Avatar
Thanks for doing this. I'd like to have the CS130 with HEI if you are willing to do that one.
Thanks, Jon
'69 C10 CST
'68 Chevelle Malibu
My 69 CST Build Thread
jonmc56 is offline   Reply With Quote
Old 05-24-2020, 10:03 PM   #332
Xavier
Thanks, Jon
Updated the PDF with all possible permutations.
Old 06-21-2020, 01:09 AM   #333
gmc684x4
Thank you awesome job
saves looking for my old chilton manual out for a wire diagram
gmc684x4 is offline   Reply With Quote
Old 06-23-2020, 12:13 PM   #334
crakarjax
crakarjax's Avatar
Could you do one for an LS swap also? j/k j/k... but seriously that would be awesome
QQ though, why is there a dashed purple wire going from the ignition switch through the NSS to the starter solenoid, but then also a purple wire that seems to bypass the NSS?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-09-2020, 01:29 PM   #335
truckster
truckster's Avatar
I just downloaded and printed this. Amazing work!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-19-2020, 05:04 PM   #336
Rookiebuilder
@dmjlambert I appreciate the advice on my post.... I deleted it here and changed the location per your recommendation. Thanks again!
Eric
Rookiebuilder is offline   Reply With Quote
Old 07-01-2021, 08:30 PM   #337
Billy Blazer
Please send wiring diagram 1971 Chevy C10 saltybutteredpopcorn@gmail.com
Thank you
Billy Blazer is offline   Reply With Quote
Old 09-04-2021, 01:13 PM   #338
crakarjax
crakarjax's Avatar
I just noticed that the ammeter wiring is missing from the diagram on the in-cab connector side.
Also, there are two instrument cluster connectors shown in the diagram but the pins are different -- why is that?
Old 09-04-2021, 04:18 PM   #339
dmjlambert
dmjlambert's Avatar
I guess you would call the wires missing from the firewall connector a minor defect. I doctored my copy of jimbosprint's diagram, here is an overlay.
Name:  ammeter overlay.png
They made the wiring diagram for a truck with warning light instrument cluster, and are showing the additional connector with wire colors so you can imagine or deduce how the wiring is for a truck with a gauge instrument cluster (oil, temp, amp gauges instead of warning lights). There are also minor differences in the wiring under the dash for an instrument cluster with warning lights, I don't remember the fine details but it is related to the resistance wire and brown wire for the alternator (gen) warning light. And the instrument cluster with gauges does not have or need the wires that go to the ignition switch for temp light and oil light bulb test during start.
Old 09-05-2021, 09:27 PM   #340
truckster
truckster's Avatar
I used this diagram when rewiring my truck. I still have it taped to the wall of my garage. It's a great resource. Thank you so much!
Old 09-27-2021, 04:38 PM   #341
markizme
Thank you for all of your hard work with these diagrams. They are the best!
markizme is offline   Reply With Quote
Old 10-01-2021, 07:42 PM   #342
crakarjax
crakarjax's Avatar
Attachment 2127534
Nice thanks for the context!
Old 12-16-2021, 10:07 PM   #343
Peanut74
Thanks for posting this. Been looking for one to help make sure I don't burn my truck to the ground. I appreciate your effort as I know it was not a easy job to do.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 03-13-2023, 11:57 PM   #344
dmjlambert
dmjlambert's Avatar
In post 302 of this thread jimbosprint posted a superior version of the color
wiring diagram. The certificate for the host website expired and the diagram
seems to have disappeared. Here it is again, I hope that is OK jimbosprint
and thanks for your work on this. I use it all the time. I have added a
correction for the wiper/washer circuit, which I know you fixed on your
version a while back, but I could not find a copy of yours with the correction,
so I did a little bit blurry correction. Also I added a small section showing the
ammeter wiring coming into the cab at the firewall connector.
