04-22-2012, 11:32 AM | #326 |
Re: Post Your Straight Six Pics!
I think it's a 250. But what do I know?! Wish we could see the pass. side of it better. If it's a 230 you could still use it, but I don't know much about that engine.
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
04-22-2012, 01:05 PM | #327 |
Yea wish I could see a side shot too.
04-22-2012, 11:34 PM | #328 | |
Re : Buying A Straight Six
I can tell you it has the Rochester Series ' B' carby and those were used from 1963 ~ 1968 on the thinwall L6's .
Can you rustle up a compression tester & test it there ? . it's simple , easy & cheap and will prevent you from buying junk . -Nate Quote:
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
04-23-2012, 12:40 PM | #329 |
a good 230 is still a nice engine.... if its good deal I would go for it.... if I was buying one for an honest price i would look 250 for the other 20 ci... Just my opinion...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
04-23-2012, 02:03 PM | #330 |
The argument could then be made to go for a 292 then for the extra 62 cu in.... just playing devils advocate
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
04-23-2012, 07:50 PM | #331 |
Sold my sbc 350 so now I am on the search for a 250 or 292 if the one I posted falls through. NO MORE V8 for me. STRAIGHT 6 here I come
04-23-2012, 09:33 PM | #332 |
04-24-2012, 01:48 AM | #333 |
If you can get the "dress numbers" off the machined pad just behind the distributor hole, you can run the numbers online and find out the displacement if it's a 230 or a 250. 292s are more obvious to the educated eye: Asymmetrical motor mounts (pass side mount and fuel pump are in the opposite places), Taller deck, Taller --6" lifter panel covers on the 292, 4" on the 250, Extra hoses coming out of the water pump.
04-24-2012, 02:25 PM | #334 |
I asked him if he could send me the casting numbers but he is laggin it after a week. I found a 1967 chevy truck 250 still sitting on the frame that the guy will start up for me. If it is good I will be buyin it for my 67 c10. I hope it works cause I do not have a motor in my truck anymore. Looks like a 4x4 now haha I WISH
04-24-2012, 02:49 PM | #335 |
Re : MY Straight Six Pics!
From my 1976GMC C2500 .
Pics 1 & 2 are from the day I bought it , note the old T-Shirt stuffed in the oil filler hole . Pic # 3 is the original exhaust manifold , this is why you don't stupidly keep driving it when it has exhaust leaks ! .
04-24-2012, 02:53 PM | #336 |
Re : MORE 292 Pix
Here we have the engine ready for cleanup , the original intake manifold cleaned & re painted and the various accessory brackets all painted and ready to go back on .
I wish I could figure out how to put text between each picture ! .
04-24-2012, 02:58 PM | #337 |
Re : 292 Pics Fin
Pic # 1 : various rubber grommets sourced from local FLAPS , Pep Boys , Kreagen , Shucks Ect. , just take your old crumbly ones and match 'em up in the " HELP ! " aisle ~ Dorman Products makes tons of good stuff and new grommets staunch those pesky oil leaks .
New radiator hoses too . Last pic : ready to re assemble . I paid $700 for this truck (no rust) and dumped $3,700.00 worth of parts into it and felt lucky to get $600 back out after it did the one long distance hauling job I bought it for , admirably .
04-24-2012, 08:25 PM | #338 |
Cool! How about some of the 1969 250 NATE?
04-25-2012, 08:35 AM | #339 |
I know ! they're coming (so is Christmas yadda yadda) , please bear with me ~ I don't know how you alls got those super clear underhood pictures but I'll give it a go as I'm the deepest L6 lover you'll ever meet .
It's still crappy weather here in La La Land ~ I must needs drive my truck Thursday & Friday so I'll try to remember to take my camera and grab some snaps . It's just another clapped out old 250 , not a shining thing like some here but then it's a real workhorse in spite of burning all that darned oil .
04-25-2012, 09:39 AM | #340 |
We love all the Sixes CLEAN or DIRTY As long as they work its All good in the neighborhood
04-26-2012, 06:29 PM | #341 |
Pulled this Inline 250 out of a 1967 chevy c10 stepside and going to put it in my 67 c10 longbed. Question: I have a rochester Single barrel carb and do not know where the passing gear cabel attaches to.
04-27-2012, 12:27 AM | #342 |
That's a Rochester Series 'B' carby and the kickdown cable attaches to the lower arm on the throttle linkage , you may have to go rob it off some old Nova / Chevelle Ect. in Pick-A-Part , for now it's not important as you can always manually pull the shift lever down one notch , that's a better way anyway .
Congrats on your new (to you) 250 C.I.D. ! now strip off all the accessories , mounts & ect. , plug the holes and scrub it Hospital clean & re spray it , then the accessories gloss black so when you re assemble it , it'll look really nice .
04-27-2012, 09:35 AM | #343 |
What color should I paint it? Last time I sprayed my old straight 8 buick 320 it burned the paint right off hahaaaa. I used the engine spray from auto parts store too. Do i spray the the intake manifold and exhaust manifold too? or just the block and the valve cover/oilpan?
04-27-2012, 10:24 AM | #344 |
Re : Post Your Straight Six Pics!
Engine paint is a subjective thing unless you're restoring it .
I like Chevrolet / GMC red , others prefer Chevrolet orange and still others prefer the passenger car blue . The main thing is to paint the entire lump including manifolds then assemble the accessories and drive it , the exhast manifold paint will burn off quickly and the contrast of black motor mounts , starter , power steering pump and so on against the engine color and bare metal carby , dizzy and alternator , will make it look ' factory ' even if you choose some engine color that more matches or accentuates the truck's color . See ? . I suppose it's obvious I built & sold used vehicles for many years , the devil as they say , is always in the details , a dealer engine overhaul/rebuild or replcement , was *very* persnickity in this manny back in the day . If you take the time to really scrub it clean , especially in the corners & crevices , the new paint will stick well and last a long time . DO NOT use cheapo paint ! . I took some pix of my 250 yesterday and will try to post them , it's nothing special as I've said so no whining about the HEI or chrome rockerbox please ! .
04-27-2012, 10:33 AM | #345 |
Re : 1969 C/10 250 Pix
Let's see......
Hm ; This works fine from my work computer but I cannot find the ipod in the browse files box.... Crap . I'll try later or next week from work .
04-27-2012, 10:45 AM | #346 |
HellYeah Inliners!!!!
My 250 with a 3 speed saginaw. Got a donor original 250 motor from a 1971 Nova with a 2 speed powerglide that will replace my tired mill.
04-27-2012, 11:19 AM | #347 |
>>....that will replace my tired mill.<<
I'd rethink that PCV System before I made that determination.
'67 GMC 2500, 292, 4spd, AC |
04-27-2012, 02:41 PM | #348 |
Any advice is appreciated.
04-27-2012, 06:29 PM | #349 |
I've been making a little progress on my 292 build.
Milo can't wait! One thing I need to know-what is this: And does it go in the big hole on the upper side of the oil filter place?:
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
04-27-2012, 11:54 PM | #350 |
Re : PCV
Why ? there's nothing wrong with that , it's cobby but properly set up .
