Old 08-25-2010, 07:55 AM   #326
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Over 25 Years Later, Finally My 71 C-10 Truck Build
Thanks Scott. I guess the only thing I've done different is I've been doing the filler work on bare metal then spraying the epoxy over the panel. Someone told me to do it that way, don't remember who now.
I've come so far, yet there is still so much to do.
hgs_notes is offline   Reply With Quote
Old 08-28-2010, 07:03 PM   #327
hgs_notes
GEARHEAD
hgs_notes's Avatar
Didn't do much today. Just didn't feel like sanding some more. I had the new wheel tubs sand blasted the other day. I went over them with a hammer to bang the dings back out. They should look pretty good. I hope to spray the hood and wheel tubs in the next day or 2.
Old 09-12-2010, 04:17 PM   #328
hgs_notes
GEARHEAD
hgs_notes's Avatar
I got back to work on this project. I couldn't keep putting off the sanding. I got the tailgate stripped yesterday, and filled the dings in it today. Then got the new bed wheel wells cleaned up. Then sprayed some more epoxy primer.
I also got the two dings on the front of the hood filled and that area primed (no pic). I still need to do a lot of sanding on the hood before I can spray it. Hopefully I'll get some time this week to finish that up. All thats left for body work is the hood, some touch up on the cowl cover, and a ding on one of the fenders where a ladder fell on it in the garage. Should blocking it it soon fellas.
Old 09-12-2010, 04:23 PM   #329
VA72C10
VA72C10
VA72C10's Avatar
looking good. Nice progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-12-2010, 06:41 PM   #330
Nice work. I need some un-super-humid weather down here to start shooting mine.
Old 09-12-2010, 11:10 PM   #331
Jaysonb
Jaysonb's Avatar
You are making this look way to easy! I hope my body work turns out half as nice as yours has. I see you live in Sleepy Eye, I lived there for about 3 years, now I am just south of Mankato. Cool to know that there is another board member close by! Give me a shout if I can lend a hand with anything.
Jaysonb is offline   Reply With Quote
Old 09-12-2010, 11:56 PM   #332
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks.
I hear ya. It's been pretty bad here until the last week or so.
I wish it was as easy as it looks. I guess it could appear that way when you guys get to see the pictures before and after. That tailgate took about 3 hours to strip using a drill with stripper wheel on it. Then a few welds to fix one side where the spot welds let go on the outer skin. Then the filler work and sand sand sand. There was nothing easy about it, except maybe posting the pics. This was one of the easiest panels though. Doors are the worst, no question about that.
There is another member on here from Mankato. His build has kind of stalled but he had a nice dropped stepside he was working on. If you know anything about body work and want to help block this out, be my guest. If you're ever around town, let me know.
Old 09-13-2010, 08:59 AM   #333
mcbassin
Still Learning
mcbassin's Avatar
Nice progress! That tailgate looks like it was pretty nice before you even started!
mcbassin is offline   Reply With Quote
Old 09-13-2010, 06:03 PM   #334
hgs_notes
GEARHEAD
hgs_notes's Avatar
Yeah, hard to believe that was the original MN part for my truck. We used to haul wood and trash in this thing for many years. Just had a few dings on the top edge and some rust along the bottom edge. The only original body parts on this are the doors, hood and tailgate.
Old 09-22-2010, 11:48 PM   #335
hgs_notes
GEARHEAD
hgs_notes's Avatar
While out working today I was at a body shop, and in the lot was a truck there for some work. It just happened to be painted the color I intend to paint this. At least as close as I think it is without having the color chip right there. This truck was originally ochre and white, then painted turquoise, and I guess will get repainted to a maroon color. The cell phone pics turned out ok, might look slightly greener then reality...
Old 09-25-2010, 05:57 PM   #336
72SWBChevy
72SWBChevy's Avatar
Looking good, I hear ya on the sanding gets old and humid weather!! People on this board help each other stay motivated, its hard sometimes. But I read all the build pages and it helps keep me motivated. As long as you keep at it, and enjoy doing it, that s all that matters. Keep us updated!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 10-29-2010, 11:42 PM   #337
hgs_notes
GEARHEAD
hgs_notes's Avatar
Last real progress was on 9/12. Long time. I've been busy with work and the Jimmy build, but that is almost buttoned up and ready to put away for the winter. The reason for this post is that I found a deal on a Holley Pro-Jection EFI set up from a board member here. It's paid for and hopefully gets shipped this coming week. It's not a fancy unit, just the 2D and rated for 275 HP, which should be just about perfect for my little 283. I'll have to re-do a little gas line work, but it should be a pretty easy install. The edelbrock carb will be swapped to the Jimmy. This EFI is probably the easiest and cheapest way to do it. New systems are around $1000 or more from Holley, used ones can be found for around $300 plus or minus. The FAST EZ-EFI is what I really wanted, with the self tuning feature, but those systems will set you back nearly $2000.
I've had a good break from this project. Now I think I'm ready to take it on again.
Old 11-27-2010, 08:25 PM   #338
hgs_notes
GEARHEAD
hgs_notes's Avatar
The sanding/paint stripping I've been dreading for the past couple months is finally getting done. I started cleaning up the bottom side of the hood today. I also was trying to straighten one of the hood supports in the middle of the hood. It sags a bit, like many of them do. The passenger side support was bent downward some and someone tried to hammer it back, but I think it just dented the support instead. I'll find out later with new pads, etc. if what I did helped at all.
You might see the dents in the pics, one straight, one off a bit:
I propped up the one side so there would be some give room to bang it back down.
tools
and stripped, mostly...
Old 11-27-2010, 08:33 PM   #339
hgs_notes
GEARHEAD
hgs_notes's Avatar
The other day I did manage to get the new throttle body cleaned up some. No pics, but other than some new gaskets it should work out well. It needs a wire harness built, bought or repaired, install the fuel pump and return fuel line, remove the mechanical fuel pump, weld in an O2 bung in the exhaust, hook it all up and see what happens. I'll post a pic of that later.
Old 11-28-2010, 01:58 AM   #340
hgs_notes
GEARHEAD
hgs_notes's Avatar
The wife went to bed early, so I went out to the garage to finish what I started. The bottom of the hood is in primer. Just need to get the top side done and start getting the truck ready for the next stage of primer.
The Holley Pro-Jection 2D throttle body:
Old 11-29-2010, 03:51 PM   #341
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-29-2010, 03:55 PM   #342
67cheby
67cheby
67cheby's Avatar
i bought my wiring harness from (www.fuelinjectionconnection.com) a very nice piece for $298 i believe
67cheby is offline   Reply With Quote
Old 11-29-2010, 07:38 PM   #343
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by Dieselwrencher View Post
Nice progress!
Thanks.
The holley replacement harness is about $130 through summit for this system. I have all the end connections and will try to repair the original first. This is a very simple system, about the same as hooking up a stereo.
Old 11-29-2010, 11:44 PM   #344
67cheby
67cheby
67cheby's Avatar
sorry i wasnt paying attention i didnt realize you had the pro jection system, i just have the holley throttle body
Old 01-15-2011, 08:26 PM   #345
hgs_notes
GEARHEAD
hgs_notes's Avatar
Now that I got my Jimmy running and set aside, I'll be focusing on the C-10. The only real body work left to do is stripping the hood and getting it in primer. I got it stripped today and will primer either tomorow or monday. Didn't find a single ding in it. Just a little finer grit sanding and it's ready to go.
There is some rust to repair inside the bed, but it can wait for now.
Old 01-15-2011, 10:23 PM   #346
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
looking really good! i hope to be starting mine in a month or so, and your thread is perfect! you're doing a great job! i hope mine comes out as nice as yours is!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 01-16-2011, 03:39 AM   #347
Dieselwrencher
Are you still planning on green for the color on this one?
Ryan
Old 01-16-2011, 10:26 AM   #348
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks, I hope it does too.
No on the green. I'm going with a turquoise metalic, it's kind of an aqua blue, available in 69 on GMC, though there have been some chevys with it also. There is an example back in this thread somewhere from a radio delete plate I pulled from a truck.
Here it is in the sun...
In the shade...
Old 01-16-2011, 12:30 PM   #349
hgs_notes
GEARHEAD
hgs_notes's Avatar
I decided to go out early and spray it. I hand sanded with 180 first and found a few little bumps. A couple are from the supports underneath pushing into the hood, and a couple other tiny bumps like that. And ond ding that I was able to tap out with a few swings of the hammer. It will need some minor filler work before paint, but not too bad.
Nice cleaned up hood...
After epoxy primer...
So now I have to figure out what to do next. I think I need to buy some paint.
Old 01-16-2011, 01:08 PM   #350
mcbassin
Still Learning
mcbassin's Avatar
Nice job sanding and priming the hood. How many coats of the epoxy primer are you laying down on it?
