#326 |
Re: 85 burb meets 6.0 lq4
im anxious to see how it looks instaled,maybe ill do the same to my truck.i have a budy who put one in his mud runner and it was a lot meaner than his old big block.took him a couple of nights to do.he told me that the flywheel of a 5.3 bolts on to the block and the torque of a th 350.he used the edlbrock intake and msd for the coils
87 short bed.4",6" drop sold 90chev z71 6" lift. with 35"sold 07 4x4 colorado on 31" 1971 chev blazer |
#327 |
I cant wait to see it installed too... I know for sure it will be 10 times meaner then my old sbc.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#328 |
![]() Join Date: Feb 2004
I am anxious to see you get this thing running! I really enjoy reading your updates. I really want to swap a 6.0L that I have into a 1990 K5. I am half scared that a built 700R4/4L60E will not hold up with the 33" tires I want to run. But looks to be a definate pain to find the right parts and install a 4L80E in the short K5. Do you think the built Monster you have will hold up long term? Will you be wheeling or towing with your suburban?
1985 GMC K1500 305/SM465 A little of this and that. |
#329 |
I do plan on some wheeling but not towing anything. I do think that the monster transmission will hold up. It has almost every upgrade they make for the 700. Says its rated for 500 hp and 450 tq. I still have 2 years left on warrinty so i guess we will find out. May not hold up forever but i am not worried about it. It will deff spin a tire befor it trys to break a shaft or someting like that. Hope to be finding out soon.....
#330 | |
Still plays with trucks
There is also a kit from GM that has the flexplate and the adapter. Part number 12621399 and sells for under $50. http://www.ls1tech.com/forums/13720181-post27.html If you have a 99 or 2000 vintage 6.0 you will not need the spacer as the crank is thicker to make up the difference and will stick out of the block like the last picture. The 2001-up 6.0's the crank flange is flush with the block face.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#331 |
Truck and auto performance nut
looks like what I bought from Pace. Wouldn't fit my 200-4r converter
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#332 |
![]() Join Date: Jul 2006
Ummm, wow! I paid $45 for those six bolts alone at a dealership.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#333 |
So what is everyone doing for the coolant temp sensor and oil psi sensors? And where can a person find one of them block off plates that go on the oil pan to remove the oil cooler.
#334 |
I'm planning on using adapters to put my old mechanical sensors in. Holding off on instrument upgrades until later...
#335 | |
There is a small bolted on fitting above the oil filter that people are tapping for an oil pressure gauge fitting. On the Vette it is tapped but some others it is not. I know the fitting is on the LS1's but don't know if it is on the LQ motors.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 11-09-2010 at 12:34 PM. |
#336 |
unless I'm mistaken (and it wouldn't be the first time) my motors oil sensor is in the top of the valley pan, at the rear of the motor?
on my genIV....I think the oil pressure sensor is in valley cover, crank sensor is on side of block near the starter, cam sensor is on the timing cover, and I'm guessing coolant temp sensor off the front of the drivers side head. ![]()
#337 | |
#338 |
I found all the addapters i need on s&p. I hope to get my gasket set in this week and my timing chain also. Hope to get to put it togther for the last time soon.
#339 |
YAY my gasket set and timing chain got in today. Now i have to find oil pump gaskets and i can install everything ecept my push rods wich i have money for in my pocket right now. All i need is new engine mounts, hoses, plugs and wires, map sensor, pushrods, oil and filter, sensor addapters and i think that is it. Then the on only thing will be time and place to install. Very excited!!!!
#340 |
Almost forgot pic in all the excitment.......
#341 |
#342 |
Stupid question here..Does the oil pump have gaskets???? Or just the oring for the pick up tube??
#343 |
They only have one...got it from gm today.
#344 |
Got oil pan painted today. I have everything but the pushrods to put it together. Just have to paint the block and put it all back together. Then save up for the rest of the stuff i need. YAY
#345 |
Just put in an order with SDPC for a set of Manley Performance 5/16 4130 chrome moly pushrods in 7.400 length. And a Balacner bolt from them. Looks like a renamed arp. It is there house brand.
#346 |
The spark plug wires that fit a camaro should fit a LQ4 right?
http://www.summitracing.com/parts/MS...RO&prefilter=1 This is the set i was looking at.
#347 |
the "truck coils" are different then the LS1 coils. Not sure if it would make a difference in the wire length tho?
#348 |
wounder if it is just the coil shape to fit under covers or the connector shape. Hmmmm... Maybe i will just go to the parts store and compare. My engine only came with 4 plug wires. What kind of plugs do these engines need. Do they come with the fancy iradiam ones?
#349 |
I'll try to take a look at mine and tell you whats in it. Its factory new so has the latest and greatest plugs they were using in 12/08.
#350 | |
