Old 09-12-2011, 08:04 PM   #326
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: 1966 SBBW pro street
Originally Posted by chad64chevy View Post
So let me get this right, 'you sold one of your trucks and your getting to work on it' which means you have money to put into the prostreet truck, lol!!
what happened yesterday with the pics? i'm waiting to see updated pics!! LOL!!!!
I think we may have a pic-tease...
I crack myself UP!
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-13-2011, 11:55 AM   #327
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Okay Okay.....pictures i get it ...
So we have the box back on again with the new rear cage.....the fuel cell goes into the middle. The batteries go on either side of the fuel cell....The rear tubs are out at the moment just to make it easier to work around. We changed up the rear cage so the cab didn't get cut at all and just the window gets cut instead....it's a bit cleaner looking i think and will be a better seal in the end.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 09-13-2011, 12:00 PM   #328
Dinos63
chevy only
Dinos63's Avatar
Duuude sic!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 09-13-2011, 12:04 PM   #329
66-PMD-GMC
66-PMD-GMC's Avatar
The cage has been my issue.
I just haven't figured out how to re-enforce the frame without having the cage visible and hacking up the back of the cab.
I don't want to see the cage outside the truck.
Projects..
440CID 2X4 Pontiac
Old 09-13-2011, 12:05 PM   #330
wutnxt
The cage is all finished now.....
Decided to not go with the swinging side door bars....didn't want them bashing into the doors....
Old 09-13-2011, 12:07 PM   #331
wutnxt
Originally Posted by Dinos63 View Post
Duuude sic!!
Thanks Dude....
From a guy like you that builds killer stuff thats a awesome thing to hear
Old 09-13-2011, 12:14 PM   #332
wutnxt
We went with a floating seat and shifter plan.....The seats mount off the cage not the floor so they kind of just float there....When i sat in the seat....(which took forever by the way) and your all buckled up there is no way to reach anything on the dash so we will be moving the switches/ignition to the center between the seats.....not sure when I drive on the street how i am going to use the turn signals just yet. With the seat belt laws here it basically say's that if it came with belts you have to have them,if you but belts in it you have to wear them. So call me silly but I might make the harness so it comes out easy when i drive it on the street....then i can reach everything.....lol....
Old 09-13-2011, 12:20 PM   #333
wutnxt
I still have a few changes to make.....
Filled a hole in the dash.....cut the hole for tunes....going to need something loud to drowned out all of the engine noise. Thinking we are going to make a gauge cluster to fit into the original dash , still not excatly sure on that just yet.
Old 09-13-2011, 12:28 PM   #334
wutnxt
I am not a huge fan of the high back seats so thats going to be a change...Having a big back window cab full of huge head rests didn't seem like a good idea to me. So the plan will be ( I think ) to cut head rests down and then have a head rest that hangs off the roll cage on both passenger and driver seats.That way they could be removed when driving on the street and if it goes to the track you just pop them back in with the seat harness.
Old 09-13-2011, 12:34 PM   #335
wutnxt
Well if it's not going to the track it would make it alot easier, if it's going to go to the track and going to run a pass....It gets way more complicated. I decided if i was going to make it possible to run that fast I might as well make it legal for the track.....in the event that oneday I want to sell it to someone who might want to race it. If i was starting the build all over, not so sure i would have done that much cage work and I would have made it more for the street.
Old 09-13-2011, 03:44 PM   #336
66-PMD-GMC
66-PMD-GMC's Avatar
I am on the fence at this point.
The frame has an Art Morrison back half unit in it with a narrowed 9". I was originally going to do a extended cab/custom 5' bed job but I found a flawless 63 donor cab and couldn't bring myself to cut it.
Now I have a virgin short wheel base frame I am looking at and rethinking the build. Problem is, I have 20" wide M/T street radials and I can only get 16" tires in using a stock frame.
Then again I could re-enforce the frame and use no cage at all but what would be the point of using the 600+ hp motor at that point?
Projects..
440CID 2X4 Pontiac
Old 09-13-2011, 03:59 PM   #337
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Buddy, this truck keeps getting better and better! I for one can tell you how those dang harnesses suck goat balls to be in while on the street! I like your idea. In my vette I originally had a retractable seat belt set up in it plus the harness. But, I took it out when I was cutting items to put it on a diet. The blower looks bad azz! Heck, the whole package is off the hook! I really like the look of your cage too man!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-13-2011, 04:00 PM   #338
chad64chevy
chad64chevy's Avatar
very nice, very nice!! love the pictures!!
chad64chevy is offline   Reply With Quote
Old 09-13-2011, 07:47 PM   #339
Dinos63
chevy only
Dinos63's Avatar
Thanks Dude....
THANK YOU BROTHA!!very kind words,and kat this truck your building is sooo bad a$$$ i check the updates every day
Old 09-13-2011, 08:21 PM   #340
wutnxt
I will take some pictures tomorrow when i get a chance......and then the updates will slow down as it heads to the body shop.....The body guy is building a new shop and is going to wait till it's up before starting my truck so .....that gives me time to wait and pick a color......I am guessing a couple of weeks before anything happens on that front....
soooooo while i am waiting i might do a 6 bolt drop spindle swap on my black primered truck.......or a might do a engine swap on the old blue big window truck......or start a cab for the powder coated truck frame....or i could build a addition for my shop.....or i could just drink beer and relax.....
Old 09-13-2011, 08:25 PM   #341
Dieselwrencher
Drink beer and relax happens when it is snowing out.
Ryan
Old 09-13-2011, 08:31 PM   #342
wutnxt
Thanks dude....
I hope we both keep them long enough to see them parked side by side.....We are going to have to pick a place half way when they are done to hit a event....I am down for driving a day for a side by side....We had a big cruise event last weekend with about 1300 cars, and it killed me not to have anything to drive....ugh
Old 09-13-2011, 08:42 PM   #343
wutnxt
LMAO ***...ya but it's been a long wrench pulling nuckle busting summer dude...I pulled more wrench in this summer then I did all of last year....funny bit of info is we drank more beer this summer then we did all of last year too....intresting huh ...
Old 09-13-2011, 09:26 PM   #344
Dinos63
chevy only
Dinos63's Avatar
Thanks dude....
for sure that would be sic, i have plans on going to brothers show for sure and (dont tell my friends i am buying a trailer or everyone will ask me to barrow it) and that show primer nats in ventura ca , find somthing in the middle i will meet ya. we have a huge cruz night coming up oct 4 and i am try to get my p/s done in time
Old 09-14-2011, 09:24 PM   #345
wutnxt
That would be awsome to meet someplace in the middle Dude.....I never even looked at my prostreet truck today....Screwed around with a truck from the " field of dreams "...thats the place with long grass that i hide all my trucks. .....lol
Old 09-14-2011, 09:28 PM   #346
wutnxt
Ya know your a redneck when......
I cut the grass in the "field of dreams " and found 4 more 64 to 66's.....and a 1972 longhorn ....lol....shakes my head
Old 09-14-2011, 09:40 PM   #347
hotrod1
56 - autocross
hotrod1's Avatar
Like the cage. Can u show us more of it and how are you mounting your seats to it? Do the seats attach to the cab at all or only the cage? If so, how are you doing the front seat mounts? Does the cage attach to the cab at all?
hotrod1 is offline   Reply With Quote
Old 09-14-2011, 09:57 PM   #348
chad64chevy
now thats funny!! so any idea on a color or still thinking about it?? and i got a question about the brace by the door opening? you said it took forever to get into, would it be track safe to do like an s bar? instead of a slated straight piece that you have in there now! that way it would be a lil easier to get into!! jmo!!
Old 09-14-2011, 09:59 PM   #349
chad64chevy
kind of like the same shape as the sides of the seats!!
Old 09-14-2011, 10:35 PM   #350
wutnxt
The cage attaches to the cab at the floor....then the cage gets picked up under the cab and down to the chassis. The two back bars that run from the floor to the roof have extra bars the run parallel to the floor and inbetween the two back bars....On the parallel to the floor bars there are steel pads to mount the seats too. So the seats mount to the cage instead of the floor if that makes sence. Then for the front seat belt portion we but tabs in under the seat off of the mounts to pick up the front seat belt. In this picture at the very bottom you can see the two pads the seats bolt to .......and the parallel bars i was talking about. Those seat mounts and parallel bars are about 5 or 6 inches off of the floor....hope that makes sence
