Old 10-16-2012, 03:38 AM   #326
DLOE65
DLOE65's Avatar
Re: DLoE's Dropmembered 65 StepSiDe Build
Thanks guys.. made dome progress on the raised bed floor tonight.
DLOE65 is offline   Reply With Quote
Old 10-16-2012, 09:12 AM   #327
dbomb53
dbomb53's Avatar
Nice job "D"! ....
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 10-16-2012, 09:56 AM   #328
62-One-Ton
62-One-Ton's Avatar
Looks nice. You going with wood slats?
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 10-16-2012, 11:49 AM   #329
DLOE65
DLOE65's Avatar
Yeah I think so. Prob go look around at a hardwood supply and find something different.
Old 10-16-2012, 02:09 PM   #330
jimmydean
jimmydean's Avatar
Looking good!
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-16-2012, 02:55 PM   #331
62-One-Ton
62-One-Ton's Avatar
I vote for Leopard wood. (google it)
'62 C10 SWB
Old 10-16-2012, 07:21 PM   #332
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Originally Posted by DLOE65 View Post
you got anymore pic of that tank. just want to see which port you used for a breather?
Sick5 is offline   Reply With Quote
Old 10-17-2012, 05:15 AM   #333
DLOE65
DLOE65's Avatar
i used the one right next to the fill for the breather.
Old 10-17-2012, 07:39 PM   #334
McMurphy
McMurphy's Avatar
have you run your tank to pump fuel lines yet?
If so, what did you use?
I am not sure what to use; I just know that I dont really want to string 3 or 4 tubes along to make one that is good length for the task.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-18-2012, 11:57 AM   #335
zippeay
zippeay's Avatar
Very cool build! What gas filler door did you use? I just got my tank in on tues and I need to figure out where to put the gas door at. I'm probably putting it in the bed floor. Looking good though!
zippeay is offline   Reply With Quote
Old 10-18-2012, 12:50 PM   #336
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
do you have strap under that tank and if not you should...
i just ran to a problem today i got a hair line crack were the bolt hole is at.
im thinking its from the weight of the gas pushing down on it.
are those tank aluminum or metal?
Old 10-18-2012, 01:30 PM   #337
DLOE65
DLOE65's Avatar
Mcmurphy - I used 2 3/8" hard lines with a union fitting, then a small piece of soft line from the framerail to the pump, and fron the tank to framerail.
Zipp- I got my filler at West Marine, it will be under the bedfloor when you drop the tailgate.
Sick - no straps, maybe I will add one, you have the same tank?
Old 10-18-2012, 02:12 PM   #338
McMurphy
McMurphy's Avatar
Thanks, I may have to do the same thing. I am guessing they are the 70" lines from the parts store? I am going to need to do a return line too on mine, both the fuel pump and the tank sending unit are set up for it.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-18-2012, 02:34 PM   #339
DLOE65
DLOE65's Avatar
Yeah got then at O'Reilly's
Old 10-18-2012, 06:25 PM   #340
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
same tank !
well looks like it..
Old 10-20-2012, 01:06 AM   #341
DLOE65
DLOE65's Avatar
Windshield and Rear window installed...
Old 10-20-2012, 01:21 AM   #342
DLOE65
DLOE65's Avatar
Also got my mufflers relocated and pipes all in... sounds awesome!
Old 10-20-2012, 09:04 AM   #343
DURG
DURG's Avatar
Having that raised bed floor gives you all kinds of room under there for stuff like the exhaust. Truck is looking great!
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 10-20-2012, 08:53 PM   #344
dbomb53
dbomb53's Avatar
Very nice, can't wait to see it in Nov.
Old 10-20-2012, 09:04 PM   #345
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Badass!... It's really coming together now
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 10-21-2012, 12:43 PM   #346
McMurphy
McMurphy's Avatar
That really is badass !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-21-2012, 07:48 PM   #347
Dinos63
chevy only
Dinos63's Avatar
Diggin it !!where are the doors??
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 10-22-2012, 01:15 PM   #348
DLOE65
DLOE65's Avatar
Painter is laggin!
Old 10-22-2012, 01:22 PM   #349
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-22-2012, 03:56 PM   #350
dbomb53
dbomb53's Avatar
If your doors aren't done by Nov. I'll send you some of these doors for your drive to Phoenix.
