Old 03-18-2013, 04:57 PM   #326
crossfire84
crossfire84's Avatar
Re: My '59 Apache
so cool!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 03-18-2013, 05:08 PM   #327
Clarance J
Clarance J's Avatar
Re: My '59 Apache
Hi Denee007. Glad to see your 59 out in the sunlight. Especially liked the part about the cold air. Its nice to see something that you worked hard for work the way its supposed to. Also my congratulations to you and your truck. One more step closer. YAHOO.
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 03-18-2013, 09:30 PM   #328
Denee007
Denee007's Avatar
Thank you Clarance!
Thanks everyone! And Thank you Earl! I received the part from you to get started on my drivers side window for the one piece window conversion! I especially felt a smile come across my face when I saw the name Denee007 on the carefully wrapped package! Ok, I'm going to have work on a name for the old truck, names just don't jump into my head for naming a truck, or my 67 mustang for that matter. I promise to work on that
Sincerely, Denee007; )
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 03-18-2013, 09:47 PM   #329
Clarance J
Clarance J's Avatar
Re: My '59 Apache
Yeah, that kinda looks like the package I sent you. Good luck on those windows. There's a lot of people watching and waiting to see the installs. Some day I'll do mine. Its another one of those steps. Of course I don't have to tell you to have fun.
Old 03-19-2013, 10:53 AM   #330
ET56
ET56's Avatar
Re: My '59 Apache
Congrats Denee, Your going to have a lot of fun with that truck. Do you see very many other trucks at your 50's cruise in spot?
56 Chevy Pickup, 66 Corvette
ET56 is offline   Reply With Quote
Old 03-19-2013, 08:18 PM   #331
G&R's57GMC
G&R's57GMC's Avatar
Re: My '59 Apache
Congrats , now all the little stuff.
BTW PM sent.
G&R's57GMC is offline   Reply With Quote
Old 03-20-2013, 11:52 AM   #332
_Ogre
_Ogre's Avatar
Re: Thank you Clarance!
if you use the same name format as i did your name/plate would be EENED
i tried to get my initials but KUJO was taken,
so was OGRE (a misspelling of my last name)
shop air compressor timer
Old 03-21-2013, 10:07 AM   #333
Denee007
Denee007's Avatar
Is that kind of like Pig latin?
Ok, yesterday I worked on my drivers side window install following Blackdiesels video~ testy but doable, and a big thanks to Clarance J for the part so necessary to get going on this part of the build! I guess after the completion of this drivers door, I'd like a guide channel for the channel nearest the door latch to be like the Wing channel guide. The wing channel guide is a narrower channel and the window felt of which the Brothers kit supplies, which makes a continous loop fits this channel perfectly, whereas the original channel that's un-spot welded, is very wide. I may look for a used wing to rob the channel from it for the passenger side. I hope that made some sense!lol
Here I'm using tie wraps to hold the guide felt/liner in place. If I'd roll down the window, it'd pull the liner down. Since this pic, I have used adhesive(actually black seam sealer from Braults auto paint~ recommended by the saleman there~ gave me a tube for a caulk gun) to hold the felt in place and allowed to cure overnight, should be re-installing the glass hopefully for the last time, then work on fine tuning.
Yes, there is glass in the door~ just can't see it!
Old 03-21-2013, 10:38 AM   #334
Kim57
Kim57's Avatar
Re: My '59 Apache
Looks like you're getting real close to having it done.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-21-2013, 11:20 AM   #335
SCHRUMGMC
SCHRUMGMC's Avatar
Re: My '59 Apache
Is it possible to take paint off the chrome on the Gas Cap ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 03-21-2013, 01:07 PM   #336
OrrieG
OrrieG's Avatar
Re: My '59 Apache
So you used felt from Brothers, not the stuff listed in Blackdiesels thread?
Laquer thinner should soften and take paint off of chrome without damaging it. Some times you have to use something like an Exacto knife or razor blade. Do not use steel wool. There might be a residue but chrome polish will take care of that. I have been doing that a lot on my build the PO were not the best maskers when they repainted the first time.
OrrieG is offline   Reply With Quote
Old 03-21-2013, 01:10 PM   #337
Denee007
Denee007's Avatar
Re: My '59 Apache
Thanks Kim! Another few months and it should be cruising the streets!
Now Howard, I want everyone to know, I did not do that! lol I bought the truck painted already, and the "reputable" paint shop should be shot for many of the things they did to this truck! But, I could possibly do something to it; kind of been the least of my concerns. It'd be funny to see someone try to steal gas with a siphon hose since my tank is in the back of the truck! The truck actually came with a new gas tank behind the seat, but I knew I was going to go with a gas tank where the spare tire went.
I'm just taking a break from the remainder of the glass install~ omg, then I got to adjusting the door as seems the weight of the glass may have put a little extra weight on the door~ it's as good as it's going to get!
I'm finished with the drivers door glass (not finished with the door)~ the passenger will have to wait until next week, but I have it down pretty good now and know what to expect! I expect the unexpected!
Old 03-21-2013, 01:33 PM   #338
_Ogre
_Ogre's Avatar
Re: My '59 Apache
i used the brothers kit for everything. one thing i noticed is that there was a 1/4'' gap from the channel to the screw on window trim. i had some 1/4''x1/2'' black foam strip that i stuck in there to fill the gap. it's not a good pic but you can see where the gap is filled with the black foam weather strip. the strip filled the gap and compressed a bit to hold it firmly in place.
Old 03-21-2013, 02:33 PM   #339
Denee007
Denee007's Avatar
Re: My '59 Apache
Hey, that's a clever idea~ that should do the trick~ thank you Ogre!
[QUOTE=_Ogre;5961632]i used the brothers kit for everything. one thing i noticed is that there was a 1/4'' gap from the channel to the screw on window trim. i had some 1/4''x1/2'' black foam strip that i stuck in there to fill the gap. it's not a good pic but you can see where the gap is filled with the black foam weather strip. the strip filled the gap and compressed a bit to hold it firmly in place.
Old 03-22-2013, 02:30 PM   #340
Clarance J
Clarance J's Avatar
Re: My '59 Apache
Hello Denee. Glad to see that you were able to work with the parts you received. I was wondering if you would post a picture of what the window kits contain besides the glass. At the moment you're the only builder I know who is in the middle of an install. Most of the other builds are already done. Alot of how to's and great advice, but what is in the kit? By the way your truck is looking great. After the windows, Whats next?
Old 03-22-2013, 05:27 PM   #341
G&R's57GMC
G&R's57GMC's Avatar
Re: My '59 Apache
My door had a tight gap at the top before I pulled the Glass & hardware out now it won't close.
When I get done installing the power window and wiring that gap will most likely be slightly larger and the door will close just fine.
Old 03-24-2013, 08:40 AM   #342
Denee007
Denee007's Avatar
Re: My '59 Apache
Hi Earl, this is the brothers kit. I bought iit when it was on sale for half price. I don't remember how much it was. Brothers has sales pretty often, so you may want to keep an eye out at their store. I'll put an update soon, this project wasn't bad at all; )
Old 03-24-2013, 05:45 PM   #343
Denee007
Denee007's Avatar
Re: My '59 Apache
Now that I'm back in town, I can add a little more information of what I've ran in to on this glass install. First, I think the brothers glass may be different measurement~ I don't have another to go by. The reason I write this is that the measurement of what Blackdiesel wrote, I had to lengthen their hole measurement by at least another inch to get a good fit. I know what to do on the passenger side now. I'll elaborate on this from doing the passenger side glass soon.
This is a great time to put the new door handles on! once the glass is in, it is difficult to got to the screws which affix the handle.
ON my passeger side door, the guide which is nearest the door latch, is not useable.
Fortunatley I was able to use the left over part from the front wing guide and left over from the passenger side to make a guide! I like it better cause it fits the felt guide much better than the very wide guide. IF this makes no sense, ask me! I just have the new(used) channel sitting in the old channel to get my length.
Some time this week I'll get back on it and finish up and take a bunch of pics along the way. Again, I don't think this to be a super difficult task~ If I can do it, you can too!
Old 03-24-2013, 06:16 PM   #344
Denee007
Denee007's Avatar
Re: My '59 Apache
I suppose if one is patient and sources out parts, you could probably beat Brothers price by having the glass made, then find the felts/guides, then the sweepers, etc, But I look for convienence. btw, my glass is tinted and not nearly as tinted looking as in this sales ad.
http://www.brotherstrucks.com/prodin...r=OPWK900%2DMD
Old 03-25-2013, 12:23 AM   #345
Clarance J
Clarance J's Avatar
Re: My '59 Apache
Hi Denee007. First, thanks for the pictures of the parts and your install. I was going to put my windwings in but still had to replace all the rubber and seals etc, but after seeing the videos, the kit, and your install I will start my plans for the new side glass. I knew there was a reason I kept those old rusted out doors. The bottoms are gone but all the tracks and division bars are in good shape. There is a glass shop not to far from my house and I'll start by checking glass prices. I'll make a pattern and take it to them. They did the install of my windshield and did a nice job so I''l go back to them. With the old parts I have all I should need is the glass and sweepers. I like your build and will be watching until its finished. And the fun continues.
Old 03-25-2013, 12:24 AM   #346
SCHRUMGMC
SCHRUMGMC's Avatar
Re: My '59 Apache
Really neat Denee.How do you install the Gas Tank in the back of the Cab ?
1971 GMC Sierra
1959 GMC 100
Old 03-25-2013, 11:12 AM   #347
Denee007
Denee007's Avatar
Re: My '59 Apache
Good morning! gee, it's 45 degrees here! That's subzero to me!lol However, I'm on a mission to finish my passenger side glass this morning, and to get more pics for here and my blog.
The pic below~ obviously where the cutout will be for the rear channel. This one is narrower due to me using vent window channel instead of the original as show above due to rusted out. One question that I was asking was, how deep to make the cutout? well, what I did was put the door latch back up, then butted the channel against it but only very lightly, but not too hard. I used the "tabs" pointed out by the screwdriver to "adjust" the tabs, then tacked the channel in place, then double checked it. Though I don't have a pic right this second, the channel does need to be in line with the window frame on the inside, but that's common sense, but I did have to unweld my drivers door~ my eyes play tricks on me these days. But it worked out ok.
I'll be back~
Old 03-25-2013, 11:19 AM   #348
Denee007
Denee007's Avatar
Re: My '59 Apache
Howard, are you speaking of the original gas tank? or when you say,"in back of the cab?" If you're talking about the original which goes behind the seat, then I've never done that, but I would have to say, make sure the area has good integrity(no rust), you sender switch wire I believe comes up through the floor through a grommet, also your fuel line comes up in the same area. I would guess if your gas neck isn't secured down somehow, you'd have that out, the put it into place once the gas tank it set down in its new home(the floor), then the gas neck and vent hose can be put on~ maybe a little spray silicone to help it slide on. I would guess there are some straps that hold it into place? Mine didn't have straps, it was just sitting on the floor un-retained. But we don't want our gas tanks flopping around!
Is this what you were asking about? If it's about installing a tank in "back of the cab", where the spare tire goes, that's what I did.
i'll be back~
Old 03-25-2013, 02:16 PM   #349
SCHRUMGMC
SCHRUMGMC's Avatar
Re: My '59 Apache
Yeah behind the seat, I'm going to do that to my truck when I get it
Then eventually put it under the cab
1971 GMC Sierra
1959 GMC 100
Old 03-25-2013, 05:36 PM   #350
Kim57
Kim57's Avatar
Re: My '59 Apache
Nice work on the door glass.
Kim
My build thread
