Old 12-12-2012, 09:29 PM   #326
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Just an Old Truck"
Originally Posted by El Campo View Post
I have always like rallys but these wheels look a thousand times better!!
I like the rallys too, i'd like to keep them for an alter ego but I am going to have to change the rear end to properly fit the new wheels so they will have to go to the classifieds.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-12-2012, 10:55 PM   #327
Bennett68C10
Bennett68C10's Avatar
Love it
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-12-2012, 11:10 PM   #328
jmedero
jmedero's Avatar
Lol. Just messing with you man.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 12-13-2012, 12:00 AM   #329
C10_ustacould
Just a little nip/tuck for Esther Mae, she's already beautiful!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-13-2012, 01:45 AM   #330
jmedero
jmedero's Avatar
Pay no attention to me buddy... I haven't driven mine in two years. I'm just jealous.
Old 12-13-2012, 02:52 AM   #331
RWB-713
RWB-713's Avatar
<----- This guy, likes your truck, ALOT. In fact, if you get a chance, you mind gettin her phone number for me?
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 12-13-2012, 07:37 AM   #332
C10_ustacould
867-5309
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-13-2012, 10:49 AM   #333
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by BucksSS View Post
Does anyone know how many degrees the pinion angle changes by flipping the brackets?
This is the one thing I didn't measure when I did mine. I have read somewhere 1* per inch raised. With that logic, 3 to 3.5* with the flip. YMMV
Does anyone know if flipping the trailing arm brackets will correct this?
The flip moved mine back ever so slightly. Also, it raised my ride height 3/4". I think your best bet is to move the crossmember exactly where you want it and flip the entire thing while you're doing it. Pretty easy to do with a 12" drill bit.
Thanks for having me on your list- the wheels look great- like a different truck!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-15-2012, 04:03 AM   #334
68tigers
That is one clean truck. A buddy of mine growing up had the exact same truck. What are planning to do with the 'ol 6 and 3 speed?
They ain't fast and gas mileage ain't too good either, but their bulletproof.
By the looks of how well it's been maintained, you almost got a turnkey project.
good luck - looking forward to the progress.
68tigers is offline   Reply With Quote
Old 01-01-2013, 04:43 PM   #335
Zander478
Zander478's Avatar
Very nice looking truck... What size tires did you end up running front and rear?
Zander478 is offline   Reply With Quote
Old 01-01-2013, 05:10 PM   #336
C10_ustacould
The old engine and trans are going get a new lease on life in a '58 Chevy stepside. The truck was basically stock when I got it, so I did a complete engine and suspension swap. I also changed the interior with a set of buddy buckets and a new dash pad and visors. So sure, I guess it was pretty much turn key...
Thanks, the fronts are 255/40-20 and the rear are 265/40-22
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-02-2013, 11:26 PM   #337
C10_ustacould
Well, I gave it a shot and it bit me in the @ss. I replaced my heater core last weekend, new core and seals, cleaned out the leaves and crap. Buttoned it up and... It leaks worse than the original heater core! I give up, I'm going to pull it all out and cover the firewall holes until I can afford a vintage air system.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-03-2013, 02:35 PM   #338
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Curious what is leaking????
I had to do this a year or two ago and while it was a PIA, everything matched up as it should. I only had to use rope caulk around the circumference of the box and new core.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-03-2013, 02:54 PM   #339
C10_ustacould
The heater-core is leaking. I took it all apart to replace a leaking heater-core and now the new one is leaking worse.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-03-2013, 03:03 PM   #340
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'm surprised. I just picked one up at the local Oreilly's and while it was lighter in weight/quality of material, it seems to function as expected.
-Nate
Old 01-03-2013, 05:35 PM   #341
C10_ustacould
Cool Re: Project "Just an Old Truck"
That is where I got mine. Let me ask you this, what size hoses are you using?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-03-2013, 06:08 PM   #342
shawno72
C/10 junkie
shawno72's Avatar
I bought one from there as well and it has worked perfectly for well over a year.
One of the connections is 5/8" and one is 3/4"
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-03-2013, 06:40 PM   #343
Xeen
Xeen's Avatar
Don't give up on replacing the heater core just because you got a bad replacement part have them order in another one and do it again.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-03-2013, 06:50 PM   #344
sgaylord
Project collector
sgaylord's Avatar
I agree with Xeen. Get a new part, it's the time of year where heaters are good to have. Even here in Florida!
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 01-03-2013, 07:27 PM   #345
C10_ustacould
Steve
I was second guessing my self on the hoses, but I have 3/4 on the upper and 5/8 on the lower. If I do this again I am going to take the original down to the local radiator and a/c shop and have them refurb it. Seems like I might get a better product.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-03-2013, 07:56 PM   #346
Xeen
Xeen's Avatar
I would say that depends on if the original one you pulled is a GM part or a aftermarket part, if its a GM part then yeah get it rebuilt, if its an aftermarket part then just get another aftermarket part to replace it.
Old 01-04-2013, 11:24 AM   #347
C10_ustacould
Took my factory (Harrison) heater core to the radiator shop this morning, and they said I should order another new heater core, but from a different manufacturer. So, I will pick it up on my way home from work and see if Carquest can do any better...
On a positive note here is a pic from a little cruise we took a few weeks ago...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-04-2013, 11:58 AM   #348
sgaylord
Project collector
sgaylord's Avatar
Nice pic. Love the look
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-04-2013, 12:45 PM   #349
Xeen
Xeen's Avatar
Everytime I see this truck I cant get over how great the original body still is after 45 years.
Redonkulous.
Old 01-04-2013, 02:44 PM   #350
C10_ustacould
Redonkulous.
Thanks fellas! Although she is far from perfect, I feel really fortunate to have found this old girl.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
