Old 09-28-2013, 10:40 PM   #326
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Well bud, right after I got done working with the truck(sifting dirt, moving it ect) it started raining so I quickly washed it and threw the tarp on. It's supposed to stop this coming week sometime so I will try to get those measurements for you. Sorry about the wait! T.J.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-30-2013, 09:45 AM   #327
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Im in no rush, so take your time. Im really considering pulling the front cross member out of the 64 frame that I'm cutting down for my matching trailer project and building it up and swapping it out.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-01-2013, 11:19 AM   #328
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
OK, so sway bar is now prepped and painted. New bushings in place, new mounts here...so I'll go pick up some new grade 8 bolts today to top it off. Should be ready to install soon.
Old 10-02-2013, 02:06 PM   #329
TheBlueBomber
TheBlueBomber's Avatar
Re: 1963 C-10 in NC
Originally Posted by T.J. MCCAULEY View Post
Though I don't think I will be buying sway bars for awhile, cause in my back yard there is a deep ditch that I barrel through to get to the garden when I have a full load of dirt, with the sway bars the truck is only gonna be able to move up and down and not have the twisting ability. Meaning when the sway bar is off one tire can sit higher than the other and when it's on one will go up and the other will be force to, possibly causing something to bend or break in my case cause I load that truck to the hilt!
yes to no sway bars!! I'm going to pull min off my '79 because im not getting the "flex" that I want. Pulled it off a friends jeep and was amazed at how much more flex you can get.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 10-02-2013, 02:11 PM   #330
TheBlueBomber
Re: 1963 C-10 in NC
I was thinking of putting 3/4 ton coils all the way around also, and some stiffer shocks. But with only 6 ply tires a heavy load of dirt can not be moved without care.......
one thing I noticed on my 79 when I bought it compared to my 96 z71 was I have bumpstops and coil springs underneath the bed welded onto the axle. Thatll prolly help with the weight distribution. I can see if I can snap a pic for you if Jon doesn't mind.
Austin
Old 10-02-2013, 02:30 PM   #331
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Not at all....please help away.
Old 10-02-2013, 06:03 PM   #332
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
The reason I wanted sway bars the the handling but since the truck is mostly used for off road work I'm not worried about it yet till I get it fully driveable and paint it. Once the paint is on it will no longer be a Farm truck.
Old 10-02-2013, 06:38 PM   #333
TheBlueBomber
Re: 1963 C-10 in NC
That'll just give you a valid excuse to get another truck!!!!
Austin
Old 10-02-2013, 08:29 PM   #334
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Yeah, but do you really need an excuse to by another truck? I can always use another truck....just don't need. But thats my big problem...wants before needs sometimes. Id like to do a 63 burb or a one ton dually as my next project...or a crew cab is high up there too.
Old 10-02-2013, 08:32 PM   #335
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Here you go aerotruk63. This is the litter bin that I have. I have the underdash mounted litter container also. I put it in the truck sometimes, cruise ins and such...really a pain if you have a passenger in the middle and may even get moved to the passenger side like yours is if I have shifter clearance issues (don't anticipate). This one mounts on the transmission hump...just rests there held in place by the sand bags.
Old 10-02-2013, 08:35 PM   #336
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Also have the 2 speed wiper w/washer ready to install. Just have to figure out the wiring on the white & pink wires. The plug should go to the switch and the single white wire on the back of the switch should move from the one post to the single post on the back of the 2 speed switch. Any help is appreciated.
Will be nice to have two speeds and the washer option.
Old 10-03-2013, 12:19 AM   #337
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Great, 63 c-10! Next project for me will be a 66 with a 9 foot(longhorn) stepside, 4 wheel drive, 40 inch tires, crew cab, and a 6.7 hopped up cummins! That's gonna be a looooooooong truck! Just the way I want it and Lifted to!
Old 10-03-2013, 08:23 AM   #338
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Here you go TJ...something like this
Old 10-03-2013, 09:38 AM   #339
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Damn if this isn't the truth...
Old 10-03-2013, 10:01 AM   #340
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Nice picture! Just needs a 9 foot stepper and no what ever you call it on the roof! And a cummins with stacks!
I'm not married yet so YES for me!
Old 10-03-2013, 10:31 AM   #341
TheBlueBomber
Re: 1963 C-10 in NC
And boggers! Big, loud, knobby boggers haha
Austin
Old 10-03-2013, 10:33 AM   #342
TheBlueBomber
Re: 1963 C-10 in NC
Didnt want intermittent wipers?
Austin
Old 10-03-2013, 11:02 AM   #343
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
No....my original 63 I had when I was 16 (family got it when I was 10 or 11), had the two speed wiper (non washer) and it worked fine for me then, so it'll probably be ok now too. If not, I can always add it later. Anything will be an upgrade from the single wiper speed now.
Old 10-09-2013, 11:31 AM   #344
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Been doing more night driving and that makes the standard rear view mirror no good with all the glare I get. I only see hood, so I found an OEM day/night mirror that was an early take off in great shape that will be going on.
Hoping this solves the issue...will keep you posted.
Also have anew master cylinder to install once the rain stops...
Old 10-09-2013, 11:51 AM   #345
Dinos63
chevy only
Dinos63's Avatar
Re: 1963 C-10 in NC
a ton of cool stuff in this thread
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 10-09-2013, 12:04 PM   #346
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks, be getting into some of the metal work soon and then paint. Its been a slow project, but even a little progress is progress. I follow all of your builds....some really nice work.
Old 10-09-2013, 08:03 PM   #347
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Alright finally got some measures here. They are crappy but as good as I could do holding a cam and measuring tape at the same time. 1st picture is the distance of the lowest hole from the tip of the coil.
Old 10-09-2013, 08:07 PM   #348
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Second is the distance of the upper hole from the coil.
Old 10-09-2013, 08:09 PM   #349
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
3rd is the distance from eachother....
Old 10-09-2013, 08:10 PM   #350
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
4th is the distance of the lower hole from the rubber bumper....
