Old 01-17-2016, 02:52 AM   #326
64chevtruck
Re: 75 Dually build
Nice metal work.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 01-17-2016, 11:08 AM   #327
whitels1
whitels1's Avatar
Re: 75 Dually build
Great work, that pedestal is awesome!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-18-2016, 08:34 PM   #328
75Dually
75Dually's Avatar
Re: 75 Dually build
Originally Posted by 64chevtruck View Post
Nice metal work.
Thanks everyone! I appreciate it!
75Dually is offline   Reply With Quote
Old 01-18-2016, 08:35 PM   #329
75Dually
75Dually's Avatar
Re: 75 Dually build
Let there be tail lights! Ok the markers and the tail lights work, but no brake lights! Arg! Can't this ever be easy! Oh well I will tackle that later in the week.
Stay tuned!
Old 01-18-2016, 10:02 PM   #330
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 75 Dually build
The pedastal looks great! Wiring on these rigs can always be fun! (If that's what you call it?)
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-18-2016, 11:51 PM   #331
75Dually
75Dually's Avatar
Re: 75 Dually build
Thanks man! The pedestal looks a lot better since I did some bodywork on it and shot some flat black on it. I will have some more pics in a couple of days. I missed a couple of small spots so I want to do one more finish work on it.
Actually these trucks are fairly straight forward as far as wiring goes. I don't mind wiring when I am not rushed. Normally I can sit down and go through it piece by piece, but the deadline on LST is creeping up way too fast this year. Might have to call in the troops! Now I just need some troops!!
Old 01-19-2016, 04:04 PM   #332
monte0185
monte0185's Avatar
Re: 75 Dually build
Stay tuned!
Looks great!! Dont look now though.. I think someone shot a hole in your back glass...
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 01-20-2016, 12:42 AM   #333
75Dually
75Dually's Avatar
Re: 75 Dually build
That's funny! Actually it is the plastic wrap around the back bucket seats. I try hard to not make enemies like that!
Old 01-20-2016, 01:00 AM   #334
75Dually
75Dually's Avatar
Re: 75 Dually build
So we got part of the puzzle figured out tonight on the tail lights. We now have the brake lights figured out, which is good. The turn signals are working fine up front, but the rear is not working correctly. When you move the turn stalk to the right both lights come on, and when you turn to the left nothing. So it is either in the turn signal switch or maybe in the flasher relay. Not sure. A very good friend of mine who is a great auto tech came over tonight and patiently went through the wiring diagrams and got us this far. Hopefully soon we will have those gremlins figured out and we can move to other larger items on the list.
Old 01-20-2016, 01:20 AM   #335
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: 75 Dually build
Make sure you have real good grounds. I had a lot of issues with gm military trucks with same light issues.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-20-2016, 09:31 AM   #336
monte0185
monte0185's Avatar
Re: 75 Dually build
I second this. Id bet money your rear grounds for your tail lights are not good or your missing a ground strap from the bed to the frame.
Old 01-20-2016, 10:07 PM   #337
75Dually
75Dually's Avatar
Re: 75 Dually build
I will double check the grounds, good idea. All the bed parts are actually mounted to the tubing frame work which is welded to the frame. So running a ground strap is not needed, but if I did not have that your idea would have been perfect.
My feeling right now is that it is in the turn signal switch or in something else. I need to trace down each of the wires and confirm continuity and proper location too.
Old 01-20-2016, 10:27 PM   #338
ruffrida2005
Re: 75 Dually build
Also check the light sockets for ground. They are known to go bad. Anyway to unplug the harness from the steering column and add 12v straight to each wire. That should let you know if it's either broken wire in column or turn signal switch.
Paul
Old 01-20-2016, 10:48 PM   #339
75Dually
75Dually's Avatar
Re: 75 Dually build
Great idea Paul. Good way to narrow down a fault like this. I'll let you know what happens.
Old 02-07-2016, 11:51 PM   #340
75Dually
75Dually's Avatar
Re: 75 Dually build
An update on the dually. The Accuair is now fully operational!!! To celebrate I put my Accuair sticker in the back window. It even works well with the 1/2" Aigbaggit valve finally... So happy to have that boxed checked off. Now to get the other boxes checked off before the end of the month, LST is right around the corner!
Stay tuned!
Old 02-08-2016, 12:48 AM   #341
ruffrida2005
Re: 75 Dually build
You figure out the lights?
Paul
Old 02-08-2016, 12:43 PM   #342
75Dually
75Dually's Avatar
Re: 75 Dually build
Haven't had time. Last week I was at a meeting all week, so I hope to figure it out over the next couple of days.
The turn signals are not on the top of the list right now anyways. I most likely will trailer it to LST so I need to get a bunch of other things completed first before we roll.
Old 02-09-2016, 11:49 PM   #343
75Dually
75Dually's Avatar
Re: 75 Dually build
Got the front bumper mounted tonight. Tons more to do!
Stay tuned!
Old 02-10-2016, 12:27 AM   #344
ruffrida2005
Re: 75 Dually build
Really wish I could see it at lst. But I won't be there.
Paul
Old 02-10-2016, 12:41 AM   #345
75Dually
75Dually's Avatar
Re: 75 Dually build
I understand. I will bring it out to other shows later in the year. I hope as soon as it warms up I will get some paint slapped on it. Hope to see you later in the year!
Old 02-10-2016, 05:43 AM   #346
ruffrida2005
Re: 75 Dually build
I wish I could make it to any shows. I work so much I don't get to go to shows. Last one I went to was LST 12'.
Paul
Old 02-10-2016, 11:44 AM   #347
slammed427
slammed427's Avatar
Re: 75 Dually build
She's coming along awesome. I want to hit LST one of these years, it's a bit of a haul for me though.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 02-11-2016, 11:30 PM   #348
75Dually
75Dually's Avatar
Re: 75 Dually build
That definitely needs to change! I understand that working to much stuff... Life seems like stretch Armstrong, and everyone important has a limb and is pulling for all it's worth!
Thanks for the kind words! Yeah that is a bit of a haul for you, but would it be worth it? Only if you bring your friends along with you! Don't tell me that would not be a blast!!
Old 02-12-2016, 12:25 AM   #349
SCOTI
SCOTI's Avatar
Re: 75 Dually build
Looking forward to seeing this @ LST.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-15-2016, 07:21 AM   #350
RNmatt87
Re: 75 Dually build
Read this thread from start to finish and WOW. Awesome work man. I can't wait to see more. Love the passion you have man. Keep it up.
RNmatt87 is offline   Reply With Quote
air bags, alcoas, chevy, dually, lowered
