Old 04-02-2014, 09:59 AM   #326
IWanna49
IWanna49's Avatar
Re: 49 ls1
X2!! Maybe make it to Nashville now!!
Greg
IWanna49 is offline   Reply With Quote
Old 04-02-2014, 11:01 AM   #327
oldman3
oldman3's Avatar
Re: 49 ls1
Great news Chris, maybe we'll run into each other this year...Jim
oldman3 is offline   Reply With Quote
Old 04-02-2014, 01:07 PM   #328
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks all, I already have a '52 lined up for a S10 frame swap mid April. Should be a fun little project!
skymangs is offline   Reply With Quote
Old 04-05-2014, 11:06 PM   #329
skymangs
skymangs's Avatar
Re: 49 ls1
Ok, so lots of progress this week... First off is shock mounts. I'm using 98 or so Blazer 4x4 front shocks in the rear. I like the travel, and I figured that they would be a little stiff to handle the weight of the front end, so it should make my bags ride pretty nice. Here's the pics
Old 04-05-2014, 11:12 PM   #330
skymangs
skymangs's Avatar
Re: 49 ls1
Next up was front shocks. I'm using stock 2wd 4.3L S10 shocks. Here's how they came out. I mocked up with used shocks, but of course I'll put all new shocks on it.
Old 04-05-2014, 11:15 PM   #331
skymangs
skymangs's Avatar
Re: 49 ls1
I also got that 2000 Camaro LS1 pan on the motor. It measures 5.5" at the deepest point vs. 8.5" at the deepest point on the truck pan. Holds 5.5 qts of oil.
My Wheels and tires got here Thursday. I have 255/45R 17s for the rear, and 225/45R 17's for the front. They will be getting mounted and balanced on Monday.
Old 04-05-2014, 11:20 PM   #332
skymangs
skymangs's Avatar
Re: 49 ls1
I also worked out the tilt bed floor pivot. I ordered 1" I.D. grease-able pillow blocks and used 1" OD tube steel for the pivot. Mounted them so they will be just below the bed floor. I am planning on counter weighting the bed, so the air cylinder won't have to lift any weight, just move it.
I disassembled the front suspension for new ball joints, bushings, and steering linkage. Then rolled the chassis outside for some sand blasting.
Old 04-05-2014, 11:24 PM   #333
skymangs
skymangs's Avatar
Re: 49 ls1
Here's the new bed mounts. Rear mounts have welded nuts inside the frame rails, front mounts stand off the frame and mount to a re-enforced section of the front bed panel (these mounts aren't holding any weight, just the bedsides, fenders, and tailgate. All the bed weight will be supported by the frame.
Also removed the factory battery box, and widened it 1/2" to hold a group 24 battery. I'll have pics of that tomorrow.
Old 04-05-2014, 11:29 PM   #334
skymangs
skymangs's Avatar
Re: 49 ls1
And finally rolled the chassis back in to spray the whole thing in a nice coat of Chassis black. Also got the rear disk setup started. It turns out My 8.5 rear is a B.O.P. with bolt in axles, so backing plate removal was "C" clip free! I did have to turn down the axle flanges about 1/4" to fit in the rotor hats though. My rear disk setup was done on the cheap, I got weld on brackets from ebay ($28 shipped), they take 75 Chevy truck front calipers ($19ea. Autozone), and I used 90 Camaro rotors ($23 each, Rock Auto). More to come!
Old 04-06-2014, 12:05 AM   #335
oldman3
oldman3's Avatar
Re: 49 ls1
Nice update Chris, everything is looking great. Really like the wheels...Jim
Old 04-06-2014, 07:57 AM   #336
99 to Life
99 to Life's Avatar
Re: 49 ls1
great progress sarge, off to the races now. I like the rear disc conversion. Can't wait to have my frame coated. So sick of looking at it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-06-2014, 11:21 PM   #337
skymangs
skymangs's Avatar
Re: 49 ls1
More progress... Got the tilt bed all worked out today. It will be powered by an air cylinder, off the air bag setup. Tomorrow the wheels and tires get mounted/balanced, the bed gets sandblasted, and of course, more bodywork on the cab.
Old 04-06-2014, 11:37 PM   #338
chev3600
chev3600's Avatar
Re: 49 ls1
Making great progress there. Frame turned out really nice.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 04-06-2014, 11:46 PM   #339
oldman3
oldman3's Avatar
Re: 49 ls1
Hey Chris, nice set-up on the tilt bed...Jim
Old 04-10-2014, 12:06 AM   #340
skymangs
skymangs's Avatar
Re: 49 ls1
Thank you both.
More progress. Chassis is sitting on it's own suspension again. Even rolled it out of the garage for a couple pics.
Old 04-10-2014, 12:10 AM   #341
skymangs
skymangs's Avatar
Re: 49 ls1
Got the trans rebuilt last week. My 6.0 flywheel and spacer are finally here.
Last couple pics show the manifold setup and the widened battery box
Old 04-10-2014, 12:13 AM   #342
skymangs
skymangs's Avatar
Re: 49 ls1
Here's the detail work on the passenger side of the dash board. Still need to do the drivers side. I think it came out pretty well though.
Old 04-10-2014, 12:16 AM   #343
skymangs
skymangs's Avatar
Re: 49 ls1
And the cab went in primer today! I'm using URO-Fill Filling primer. Should help me catch any small imperfections. I think that about covers the last couple days of work.
Old 04-10-2014, 07:52 AM   #344
FarmerSid
FarmerSid's Avatar
Re: 49 ls1
You got a ton of work done. The dash work looks awesome.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 04-10-2014, 10:51 AM   #345
oldman3
oldman3's Avatar
Re: 49 ls1
Hey Chris, moving right along, chassis looks good, dash work looks great, the cab in primer says, sand and paint...Jim
Old 04-12-2014, 09:11 AM   #346
skymangs
skymangs's Avatar
Re: 49 ls1
as always... Thank you gentlemen. Got lots more progress pics from the last couple of days to post. First off, the motor and trans are in (for the final time I hope!) 4th pic shows clearance on that ac compressor... Tight, but it clears. Camaro oil pan gave me 2.5" of clearance below the engine at full droop.
Old 04-12-2014, 09:16 AM   #347
skymangs
skymangs's Avatar
Re: 49 ls1
The exhaust manifolds are Trailblazer SS, and look just about like those headman cast headers I see online. These cost me $75.
Old 04-12-2014, 09:19 AM   #348
skymangs
skymangs's Avatar
Re: 49 ls1
Also got a lot done on the box. Sand blasted it, fixed that damaged corner, put some patches here and there, fixed the tailgate, filled the stake pockets, and the bed rail ends are getting capped today.
Old 04-12-2014, 09:22 AM   #349
skymangs
skymangs's Avatar
Re: 49 ls1
pics of the finished bed corner repair, and the hose/line/shock routing for the front suspension. That's all for today. Truck goes into hibernation for the next few weeks. I have a 52 coming in this week for an S10 swap.
