Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-08-2015, 08:50 AM   #326
7dee2
7dee2's Avatar
Re: 72 K30 Build
Here are some pics of the lower flange holes that have gotten filled so far.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 07-08-2015, 08:55 AM   #327
7dee2
7dee2's Avatar
Re: 72 K30 Build
After grinding flush bolted on the hangers and drilled the remaining 3/8” pilots in the lower flange.
Brett
Old 07-13-2015, 10:05 AM   #328
7dee2
7dee2's Avatar
Re: 72 K30 Build
Made the final fit adjustments and drilled to 7/16” re-bolting one at a time. All the spring hangers have been drilled on the frame except for the front shackle frame brackets those were drilled over using a drill press. Really need to fix the spring bushings!
Brett
Old 07-13-2015, 11:09 AM   #329
DLTruck1973
Re: 72 K30 Build
Hardware clerk:
"Yes sir, how may I help you?"
Brett:
"I'll take about a couple thousand 7/16 grade 8 bolts, nuts and washers please"
Looking good there Brett. Keep up the good work. Looks like a roller soon
Take care,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 07-14-2015, 10:41 AM   #330
7dee2
7dee2's Avatar
Re: 72 K30 Build
Originally Posted by DLTruck1973 View Post
Hardware clerk:
Brett:
Take care,
Thomas
Ha, you got that right and thanks Thomas!
We’re pretty lucky in that I’ve got a nut a bolt supplier just a few miles away that will sell to me. All this shiny new hardware ran me less than $10 for mockup compared to the big box store specialty bins with the little packages and the 400-500% markup.
Working the rear hangers, pretty sure this is the setup on the rear position but want to see it flipped over with springs and axle before punching all the holes.
Brett
Old 07-14-2015, 09:31 PM   #331
mx289
mx289's Avatar
Re: 72 K30 Build
Looking good.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 07-15-2015, 09:37 AM   #332
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Tom.
And we have some rear springs!
Brett
Old 07-16-2015, 10:11 AM   #333
7dee2
7dee2's Avatar
Re: 72 K30 Build
Flipped over with the rear axle in place ain’t that a looker? Ha!
Brett
Old 07-16-2015, 01:46 PM   #334
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: 72 K30 Build
That first photo brings back terrible memories of trying to work on the brake lines around those spring packs
Looking good, liking the stance!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 07-17-2015, 09:46 AM   #335
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Jim, It does look pretty dang tight in there and I'm sure the will be flying when that day comes.
Now it’s the front axles turn and it is finally a roller! Currently it sits almost level with no weight on the front end with an extra inch or so from the dollies. Last 2 pics you can see the frame rails kinda line up with the lines in that scrap paneling.
Brett
Old 07-20-2015, 10:06 AM   #336
7dee2
7dee2's Avatar
Re: 72 K30 Build
Decided to move forward with the generation correct engine cross member first instead of the K35 stuff. Pretty sure it’ll do the job and I’ve got the correct oil pan to make it work. Not 100% sure on the front sway bar mount and the trans mount we will see what fits the best.
Brett
Old 07-20-2015, 12:54 PM   #337
JJorgensen52
Re: 72 K30 Build
As far as I know, the only difference between the 10-20-30 series engine crossmembers is the height to match the different frames - if it fits, I'd say run it! Installing original style power steering brackets with the later cross members is difficult at best.
CURRENT
SOLD
Old 07-20-2015, 08:14 PM   #338
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
Nice work on the frame! It's really coming along nicely!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-20-2015, 10:59 PM   #339
DWilbur
Re: 72 K30 Build
Looking good keep up the work. I think it took me about a year to get it back on the wheels.
DWilbur is offline   Reply With Quote
Old 07-21-2015, 09:32 AM   #340
7dee2
7dee2's Avatar
Re: 72 K30 Build
Power steering pump fitment did cross my mind from your build Jim. Running this style K20 cross member does simplify things. The only con for me is the motor mount style. IMO the clam shell motor mount is a far better design but I’m hoping with better heavy duty poly mounts that we won’t have any lifting problems later.
Thanks you guys!
So I borrowed an early style motor mount from a friend who only had one. A block of wood was subbed for the other side this is some high tech stuff here! With the K35 trans mount just set inside the frame rails and no TC mounts we got pretty close to carb level just messing around. Left exhaust manifold is touching the cross member but I think the new poly mounts are thicker.
Brett
Old 07-21-2015, 10:22 AM   #341
JJorgensen52
Re: 72 K30 Build
The poly mounts are built with travel limiters in them, so they don't have the same lift/breakage issue as the old style ones. That's a good call! I actually hate the clamshells, the short/wide style is my preference when I can use them.
Do you have SBC or BBC motor mount stands?
CURRENT
SOLD
Old 07-21-2015, 03:23 PM   #342
Dieselwrencher
Re: 72 K30 Build
If the poly mount isn't tall enough, you could always shim the engine up if you had to to clear the cross member.
Ryan
Old 07-22-2015, 09:51 AM   #343
7dee2
7dee2's Avatar
Re: 72 K30 Build
That's what I keep hearing on these newer design early style mounts so they should be OK for what we'll need.
Both the 73 K5 and the 84 K35 stands we have are for a small block, the motor mount take 3 bolts to mount to the stands not 4 like the big block version. I'm thinking ours are the short/wide you describe and have noticed that our later K35 version does seem to be a little heavier duty with extra mounting provisions to the frame and cross member but are still pretty much the same overall dimensions.
Good suggestion DW! I’ve had to use spacers before and that works really well when you just need a little more room/height, pretty sure that GM did the same on some applications.
While waiting for the new motor mounts to show up we’ll get the crossmember mounted and start to figure out how we will mount the sway bar. Really want to run the original front cross member if possible and these later sway mounts are not helping that goal as much as I’d like. So, so close but no cigar!
Brett
Old 07-22-2015, 10:50 AM   #344
JJorgensen52
Re: 72 K30 Build
You know I was never really happy with the way I got that to fit on my truck. What about something like was done here?
http://67-72chevytrucks.com/vboard/s...d.php?t=140216
Food for thought
CURRENT
SOLD
Old 07-23-2015, 09:43 AM   #345
7dee2
7dee2's Avatar
Re: 72 K30 Build
Great minds do think alike Jim, I saw that thread and thought wow! Here’s another one closer to what we'll end up with http://67-72chevytrucks.com/vboard/s....php?p=4935792 . Forum member snj8198 did a great job so all credit for this design goes to him. We lucked into some scrap 2x4 tubing a buddy had laying around and it was just perfect.
Brett
Old 07-23-2015, 10:36 AM   #346
JJorgensen52
Re: 72 K30 Build
Hey, I've got some of that 2x4 tubing laying around ... maybe I should get a wild hair and put some sway bar mounts on my K10???
Nice progress!
CURRENT
SOLD
Old 07-23-2015, 11:11 AM   #347
DWilbur
Re: 72 K30 Build
That is a good idea for mounting the sway bar. I just might have to do something like that.
Old 07-23-2015, 04:46 PM   #348
Dieselwrencher
Re: 72 K30 Build
That is a great idea. I may have to alter the tube a lot due to my front cross members being modified for inline 6's.
Ryan
Old 07-24-2015, 10:51 AM   #349
7dee2
7dee2's Avatar
Re: 72 K30 Build
Nice progress!
It's a pretty easy setup go for it! Thanks, but your progress on the Red Herring is outstanding!
That's what I thought when I saw the thread. Ha, easy peasy you know.
Brett
Old 07-27-2015, 10:40 AM   #350
7dee2
7dee2's Avatar
Re: 72 K30 Build
Here's another reason I wanted to stick with the original front cross member. I’ll tell you what these blazer steering box supports don’t fit the 133” or 157” frames real great. But with a little trimming it’s going to work out just fine, still need to add an upper shim to complete the fitting but you get the idea.
Brett
72chevy, dually, flatbed, k30, motorhome
