Old 09-23-2015, 10:53 PM   #326
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by joedoh View Post
what do you know? I just looked at those shocks the other day, I have a lowered blazer that is a little jouncy even with new springs and heavy duty shocks. you'll have to let me know how they work, I passed over them for their high cost but wondered.
Will do. I think I payed $80 cdn for the pair.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-23-2015, 10:58 PM   #327
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got the rear all pulled apart. The plan is that Monday morning to pull the cab.
1951 MG TD
Old 09-24-2015, 10:50 AM   #328
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
don't you just luv taking it all apart when it takes so long to put together in the first place!!!!!!!!!!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-24-2015, 11:26 PM   #329
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I agree very discouraging. But the next time I put a bolt in, it should be for good.
1951 MG TD
Old 09-28-2015, 03:39 PM   #330
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I pulled the cab. To all the guys on this forum that have posted this method of lifting the cab. Thankyou!!!!!! Lifted straight and solid.
1951 MG TD
Old 09-28-2015, 03:47 PM   #331
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Back in the shop, I put the truck on the floor. I made up the K frame tubes and rear 45* supports. The left 45* support is different because the trans cooler is going there. I used 2X4X1/8" tube, frame is 2X5X3/16".
1951 MG TD
Old 09-28-2015, 04:47 PM   #332
Coldshot
Coldshot's Avatar
Re: My 52 GMC Build
Looking awesome! Must be exciting to be getting ready to put it together one final time.
Coldshot is offline   Reply With Quote
Old 09-28-2015, 06:22 PM   #333
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Put it together, take it apart, put it together ....folks don't realize how much work goes into a nice build. Good progress!
Advanced Design is offline   Reply With Quote
Old 09-28-2015, 06:27 PM   #334
joedoh
joedoh's Avatar
Re: My 52 GMC Build
super dope
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-29-2015, 05:47 PM   #335
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Not much to show with pictures today. I finished welding up the inside of the frame now that the cab is off. Also welded the exhaust tip completely on, tabs to hold exhaust to frame and primed frame. Plumed in the temp gauge sensor for the trans and fittings for trans cooler. Should be lots tomorrow!!
1951 MG TD
Old 09-30-2015, 03:13 PM   #336
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I painted the new frame pieces and running board frame. I also finished up the exhaust. Welded in an EGT bung, put the turbo gasket in and sealed up the cup flanges. Then as I put it all together I put wrap on the exhaust. The wrap I used is rated at 1400*. (Note) this is very itchy stuff the insides of my fingers itch like hell. Wear rubber gloves.
1951 MG TD
Old 10-01-2015, 04:21 PM   #337
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I got the transmission cooler mounted and plumed in. Then I got the fuel lines and brake line bent up and fastened. This is the nickel coated line very nice to work with hardest part is getting it straight. I'm trying to get all the under cab stuff done so I can get the cab back on. Maybe tomorrow.
1951 MG TD
Old 10-01-2015, 06:51 PM   #338
Advanced Design
Re: My 52 GMC Build
You are flying! Looks good. What transmission cooler is that?
Old 10-01-2015, 08:39 PM   #339
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks I get lots done when I work afternoon shift. The trans cooler is a Derale 13950. It can be used by itself and comes with a thermal couple so it just does it's own thing when needed. Also mount it anywhere.
1951 MG TD
Old 10-01-2015, 09:16 PM   #340
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
yah your rockin and be rollin soon. I luv the copper nickel line. perhaps you can get that straightner eastwood sells. aluminum line does the same thing.
Old 10-06-2015, 10:21 AM   #341
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 99 I got the lines close to perfectly straight just took a while.
Well after spending 34 hrs working on the truck last week I got the cab back on for the last time. I mounted the air horn, ran all my power wires to the rear. I also got rid of the old steering and put the new stuff on with the drop tie rods.
1951 MG TD
Old 10-06-2015, 10:24 AM   #342
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Then seam sealed the cab and gave the floor and fire wall a good coating of rubberized rocker guard. I then ran the transmission wires into the cab.
1951 MG TD
Old 10-06-2015, 11:05 AM   #343
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
coming together, dang 34hrs a week, that's about my average monthly time I work on my trucks.
Old 10-06-2015, 11:38 AM   #344
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya I went 100% on it because the cab was sitting out side. I had friday off work so that helped.
1951 MG TD
Old 10-06-2015, 01:20 PM   #345
big_moss
big_moss's Avatar
Re: My 52 GMC Build
man this thing is gonna be sick I like the back half set up
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 10-06-2015, 09:48 PM   #346
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: My 52 GMC Build
You're getting so much finished up. Man... 34 hours a week is like working two jobs.
Nice work!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 10-07-2015, 07:29 AM   #347
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Nice work!
Ya felt like working 2 jobs, but this one I like going to.
1951 MG TD
Old 10-08-2015, 07:39 AM   #348
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well I didn't think I would get out to the shop last night. I got the rear shock mounts made and installed. I used s-10 shocks. They are angled for 2 reasons. With the air bag over top of the axle it makes the rear very stiff with little pressure so I did not want the shocks to have full power. Also that's the only spot they fit lol. Jumping on the frame at ride height seems good.
1951 MG TD
Old 10-09-2015, 10:58 AM   #349
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I just signed up as a Premium member.
1951 MG TD
Old 10-09-2015, 05:33 PM   #350
Advanced Design
Re: My 52 GMC Build
Very cool. Build is looking great and you are killing it on progress. 34 hours a week is greuling.
bagged, build, diesel, gmc, hot rod
