Old 03-05-2020, 05:04 PM   #326
TKCR
TKCR's Avatar
Re: My 86 build
Well I still haven’t done much with Big Red, but I did get some seatbelts restored for someone. Before and After pics on a set of Black Seatbelts. Not much fading in the webbing, but I was able to get the faded section out.
TKCR is online now   Reply With Quote
Old 03-07-2020, 08:18 PM   #327
TKCR
TKCR's Avatar
Re: My 86 build
Well I felt well enough to spend some time with Big Red today. I swapped out the Dash Pad trim with an OEM looking trim. 5-6 years ago I put a Billet trim on there. My new Door Panels from USA1 Industries, also have the OEM looking trim, so I want it all to match. So here’s what I got done today.
1st pic is the Billet
2nd pic is the new dash trim
Last pic is my new door panels.
Old 03-07-2020, 08:37 PM   #328
rgunlock
rgunlock's Avatar
Re: My 86 build
I do prefer the OE style over the billet. Glad you're feeling up to working on it!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-07-2020, 08:55 PM   #329
TKCR
TKCR's Avatar
Re: My 86 build
Thanks Rick! I still had to take it slow, with some breaks. I wasn’t thrilled about taking the dash pad out. But since I’ve done it once already, it went quite smooth. I needed to get that done, so I can finish putting the dash parts on.
Old 03-08-2020, 02:06 PM   #330
TKCR
TKCR's Avatar
Re: My 86 build
I got one door all sealed back up.
Old 03-08-2020, 02:20 PM   #331
TKCR
TKCR's Avatar
Re: My 86 build
Got another set of seatbelts done. These are Burgundy. They were in pretty bad shape, wasn’t sure how they would turn out, better than expected.
Old 03-08-2020, 02:23 PM   #332
TKCR
TKCR's Avatar
Re: My 86 build
Few more before & after pics.
Old 03-09-2020, 11:29 AM   #333
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: My 86 build
very nice work!!! makes mine look promising to rebuild!!!
..... HHHHHHMMMMMMM????
rodstored-72 is offline   Reply With Quote
Old 03-09-2020, 03:42 PM   #334
TKCR
TKCR's Avatar
Re: My 86 build
What do yours look like? You can send them to me, and I'll just charge labor & dye and send them back.
Old 03-10-2020, 09:21 AM   #335
Hart_Rod
Hart_Rod's Avatar
Re: My 86 build
Late to the show but love your build thread and glad you are doing better, .
Hart_Rod is offline   Reply With Quote
Old 03-10-2020, 09:54 AM   #336
TKCR
TKCR's Avatar
Re: My 86 build
I’m getting there, Thank you!!
Old 03-12-2020, 10:24 AM   #337
rodstored-72
chevy truck fan
Re: My 86 build
well... they look very like posts 331 & 332. the belts don't have sun damage though.... this is a tempting offer.... I will PM you after some thought...
thanks!!!
Old 03-16-2020, 08:37 AM   #338
Greenlee
Greenlee's Avatar
Re: My 86 build
Nice work on the interior! Glad you are feeling better.
Greenlee is offline   Reply With Quote
Old 03-21-2020, 06:42 PM   #339
TKCR
TKCR's Avatar
Re: My 86 build
Worked all week on another set of Seatbelts, finally got them done today. These are the 79-80 CarmineRed. I’m doing these for a guy that I built a restored seat for. These CarmineRed belts are hard to find. These were in pretty bad shade, webbing faded and the belts would not retract.
So, started off with removing the plastic sleeves off the center belts. They were busted up, and the customer didn’t mind if they were totally removed.
Next, I sandblasted the mounting base, for the retractors. I also hit the retractor wheel mechanism, up inside the retractor casing. These were gunked up with all kinds of dust and god knows what. The wheels were rusty too, which is why they weren’t retracting.
A good soaking in hot soapy water using Dawn and mild scrubbing. Hang to dry. I also blow the mechanism dry with my compressor. I spray a little lube and whalla, the belts are once again retracting!
Prep, mask and dye.
These are all the BEFORE pics of the belts and the seat I built.
Old 03-21-2020, 06:49 PM   #340
TKCR
TKCR's Avatar
Re: My 86 build
Now for the AFTER pics of the seatbelts.
Old 03-22-2020, 05:57 AM   #341
Hammered 77
Hammered 77's Avatar
Re: My 86 build
TK those look great, I didn't think about dying the belts. I'm still looking for a charcoal set but now that everything is on lock down it may be a while before we can go on the hunt.
Rick
Hammered 77 is offline   Reply With Quote
Old 04-07-2020, 05:14 PM   #342
99_Sierra
99_Sierra's Avatar
Re: My 86 build
What is your process on restoring the seat belts? Are you able to pull the plastics off the belts or do you just have to extract the belts all the way out of the plastic?
thanks
99_Sierra is offline   Reply With Quote
Old 04-07-2020, 05:35 PM   #343
TKCR
TKCR's Avatar
Re: My 86 build
thanks
The only time I remove the plastic, is on the center belts. And that's only if it is all broken. Post #339 & #340, you can see the center belt plastic is broken, so I just removed all of it.
The retractors, I just pull the belts up, and they will have to be clamped off, so they don't retract back in. At that point, I soak the webbing in Hot Dawn Soapy water. Only mild scrubbing if needed. Hang to dry and then dye the plastic parts.
Old 04-08-2020, 01:20 PM   #344
99_Sierra
99_Sierra's Avatar
Re: My 86 build
thanks, I am going to give It a shot on my nova and c10
Old 04-08-2020, 05:47 PM   #345
LT7A
Re: My 86 build
The retractors, I just pull the belts up, and they will have to be clamped off, so they don't retract back in. At that point, I soak the webbing in [Hot Dawn] Soapy water. Only mild scrubbing if needed. Hang to dry and then dye the plastic parts.
Please tell us more about this Hot Dawn. Just kiddin. Thanks for all of the detailed info.
Old 04-08-2020, 07:39 PM   #346
TKCR
TKCR's Avatar
Re: My 86 build
Yeah that didn’t quite come out right, did it? Lol! I use Dawn dish soap, in very hot water. So hot, I have to let them soak before I can put my hands in that water
At the moment I’m cleaning another set of Black & CarmineRed.
Old 04-09-2020, 04:07 PM   #347
TKCR
TKCR's Avatar
Re: My 86 build
Not much to report on Big Red. Still waiting to get help to hang my door, so I can finish the door adjustment, install the rest of the dash parts. Build and install the seat, and install the door panels.
So in the meantime, I’m getting more seatbelts done. These are the BEFORE pics, and after a thorough cleaning.
Old 04-09-2020, 04:10 PM   #348
TKCR
TKCR's Avatar
Re: My 86 build
AFTER pics. Dyed the plastic & webbing. Got the retractors moving freely again.
Old 04-09-2020, 09:18 PM   #349
1967KaiserM715
1967KaiserM715's Avatar
Re: My 86 build
Question, why did you seal directly to the door, vs putting it on the door panel and using foam to seal the panel to the door?
Very nice work on everything, I really enjoy seeing your work and attention to detail you do.
1967KaiserM715 is offline   Reply With Quote
Old 04-09-2020, 09:53 PM   #350
TKCR
TKCR's Avatar
Re: My 86 build
I used a square of FatMat on the interior of the door. That helps with the noise. The thin layer of foil/foam on the outer portion, was just to replace the plastic seal it originally had from the factory. I got the idea from N2TRUX, on one of his builds.
https://67-72chevytrucks.com/vboard/...&postcount=484
