04-04-2019, 12:11 PM | #326 | |
Re: What did you do to your Suburban Today?
http://67-72chevytrucks.com/vboard/a...1&d=1554393056 Passenger door has been bulged-out at the holes and it crackled the paint on the top three...but I've got some fitment issues with this side as well due to previous repairs by original owner. Entire drivers side has never been hit and is super straight. May be the reason he put on the large mirrors??? Woody |
04-23-2019, 06:51 PM | #327 |
I got a little more ambitious today...thought I'd quickly pull out my grill to clean-up a few things, and boy, did that turn into a can of worms! The bright side after taking off much more than I thought I would have to, I can easily access my radiator core support body mounts that I received from GMC Pauls. Unfortunately, the Body Mount Kit is back-ordered!
Woody |
04-23-2019, 07:05 PM | #328 |
Question for those more knowledgable than me...is the grill surround normally pop-riveted in place as mine was?
Woody |
04-23-2019, 08:44 PM | #329 | |
Equal opportunity joke ofender
It has likely been changed out at some point. They are riveted from the factory but not with that style pop rivet. Factory ones have no hole. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
04-24-2019, 01:00 AM | #330 | |
Woody |
04-24-2019, 08:21 PM | #331 |
Did my radiator core support frame cushions today...took a while but pretty straight forward. Side by side shows how compressed the upper cushions were. 20 years ago, the original owner must have taken the easy route as the bottom cushions appear to have been changed before, but not the uppers or bolts!
Woody |
04-24-2019, 08:25 PM | #332 |
I started on my body mounts as well but decided to go the long route
04-24-2019, 08:40 PM | #333 |
Here's the finished product with a little black paint added to hide the "Never-Seize" that gets everywhere!
Woody |
04-24-2019, 08:44 PM | #334 |
04-24-2019, 09:04 PM | #335 |
A bit of advice...if your radiator core support cushion set comes with square washers that look like these, don't use them. The square hole is a little bit too large and the carriage bolt shoulder spun inside of it. The hole in the original washer fit the shoulder of the new bolts perfectly. Also, the originals have the square hole "off-set" for a reason...which is to keep the entire washer from spinning around. I had both problems while I was assembling the first side ending up doing it 3 times. Use the original square washers to avoid this issue.
Woody |
09-17-2019, 12:16 AM | #336 |
Today I decided it is finally time to put the body back on the frame.
71 GMC swb 4x4 ...sold 72 suburban "family cruiser" in progress 67 chevy blazer truck 59 Chevy belair 2dr-high school sweetheart |
09-24-2019, 01:26 PM | #337 |
Not sure I drove mine in 2018 and definitely didn’t in ‘19 yet.. but, DW’s late model possibly blew a head gasket yesterday (radiator overflow can full of oil) so she’ll need to use my daily, which means the ol Sub gets duty. A little time on the charger and a couple dribbles of fuel down the carb and whammo! Running and not sounding too bad. Topped off the air pressure, evicted an army of spiders and started a basic pre trip inspection. We’ll know by tonight if it works out as well as hoped
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
10-01-2019, 05:04 AM | #338 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
10-05-2019, 11:44 PM | #339 |
The body is finally back on the frame! Best of all, I freed up space in my garage so I can park in there this winter.
Now I'll be back to metal work. Probably time to start a build thread...
11-13-2019, 05:53 PM | #340 |
Finally put new seatbelt in...six out of the nine being 3 point shoulder straps for the grandkids! The belts will be coming out again when I replace the carpet and have the original seats reupholstered...so I'll paint the brackets at that time...but for now, they're working great!
Woody |
11-13-2019, 05:58 PM | #341 |
11-13-2019, 05:59 PM | #342 |
Post Whore
How or what did you use for an anchor for the top of the three point belts?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-13-2019, 05:59 PM | #343 |
11-13-2019, 06:47 PM | #344 |
I never thought of mounting the retractors there. I haven't mounted mine yet.
I mounted the front one's to the lower part of the B-pillar
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-13-2019, 10:50 PM | #345 | |
My fronts already had the retractors installed by PO which made that part of installing the new ones a lot easier because he used really nice "L" brackets that I reused. They mount to the floor between the "B-pillar" and inline with the seat back...but they appear to use a factory mounting point as the nut under the frame seems to be factory welded in (???in case someone ordered optional 3 points up front???). The retractors mounted with different amounts of difficulty depending on which row of seats I was working on...with the middle row being the hardest (shorter seat brackets)...but all in all, it was pretty straight forward. Woody |
11-13-2019, 11:09 PM | #346 | |
Woody |
11-14-2019, 10:53 PM | #347 | |
Post Whore
Maybe you have a late run truck that was pulled in to engineering to do testing. Congratulations on your nice easy installation it looks good.
11-15-2019, 02:10 AM | #348 | |
Wish I could help you figure out how to get those anchors up there! Seems like a lot of work, though! Woody |
11-15-2019, 10:18 PM | #349 |
Mine has factory shoulder anchor points for all three rows.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
11-15-2019, 11:23 PM | #350 |
Post Whore
Oh great another show off !!
And no mention of what year either.
