Old 05-05-2023, 11:53 AM   #326
cornerstone
cornerstone's Avatar
Re: Uncle Loyd's 72' C-10
I got the fenders, doors, hood, bed and tailgate in high build 2k primer this morning. Hope to get the cab sprayed later this afternoon. I used a different cheap HF spray gun this time so I could open up the tip and get more primer out of the gun and on the panel. I've been watching D.I.Y. AUTO SCHOOL with "My friend Pete" on the YouTube. He recommended this particular pressure pot style gun for primers. If you haven't seen his channel check it out. The guy cracks me up, to say he's super rough around the edges would be mild. The gun worked well after I played with it some. Not bad for 24 bucks. Here's where I'm at currently.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-05-2023, 02:04 PM   #327
hewittca
hewittca's Avatar
Heck yes, that's some progress right there! That's bold spraying paint outside in the spring. I'm not sure how it is by you, but over here in NC everything is covered in pollen!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-05-2023, 02:17 PM   #328
kev2809
low n' slo
kev2809's Avatar
Originally Posted by cornerstone View Post
Thanks man! I've been watching yours come along nicely as well. It's a freekin' butt load of work aint it!
thanks. sure is and I'm barely getting into the hard part, body work!
I've seen that YouTube channel before, I always watch his painting videos. seems like he knows a ton about it
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-05-2023, 06:20 PM   #329
cornerstone
Yeah, not the best of options spraying outside, but this was only primer which will be block sanded anyways. I did have to thoroughly wipe everything down with wax and grease remover one last time after I mixed the primer. Once I finished cleaning the gun, I looked everything over and found one bug knee deep in the dried paint. I had hopes of getting the cab in primer as well but a heat wave rolled in... 97* this afternoon, and I thought that would have affected the job for the worse. I'll git after it in the morning.
When it comes time for final paint the plan is to use my enclosed garage at the least. I'm also thinking of renting a booth if I can find one.
Brian
Old 05-05-2023, 08:51 PM   #330
zicc1835
zicc1835's Avatar
looking real good nice work....
zicc1835 is offline   Reply With Quote
Old 05-11-2023, 11:13 AM   #331
Stickman
Stickman's Avatar
Very nice work.
Stickman is offline   Reply With Quote
Old 05-18-2023, 11:12 PM   #332
cornerstone
I've been off of the truck project for about a week taking care of other crap. Responsibilities are overrated. Anyways, this morning I was able to get the cab prepped and masked off for a couple coats of high build urethane primer. First I shot any remaining bare metal spots with a final coat (hopefully) of epoxy primer, then laid down 50 ounces of high build. Since I've already bought all the paint I know I probably won't go through with this thought, but I think the truck would look cool with a low sheen, almost suede look textured paint. Kind of how the tinted Raptor Liner looks on this Dodge truck. Has anyone seen one of our trucks done this way? I'd want to have the 2 tone with all the trim as well. It would sure hide any boo-boos in the body work and be unique. I can only imagine what a pain in the a$$ it would be if I ever wanted to take it off. I do like a patina look as well, so if my paint work turns out lousy maybe that'd be an option instead of stripping it back to metal. I nabbed these images from the web.
Brian
Old 05-19-2023, 08:16 AM   #333
hewittca
hewittca's Avatar
I am all for patina and semigloss or even a matte finish, but I would hesitate to add any texture to the paint. I do like a color matched liner in the bed, but I don't know that I'd like it on the rest of the truck. Of course, that is not to say it wouldn't look good if done right. And I get what you are saying, it would bother me to have done that much work on the paint/body and still have little imperfections that stood out to me in an otherwise shiny paint job. That's why all 4 of my previous projects have been left OG paint On my previous truck I had to paint the bedsides and fake the patina. I tried to match the original primer color and use single stage color like factory, and then lightly sand in the normal wear areas to match the level of fade on the rest of the truck. I finished it off with some 000 steel wool for a semi-matte finish.
Old 05-19-2023, 05:03 PM   #334
SCOTI
SCOTI's Avatar
Absolutely agree 100%. No texture in the paint on the outer body panels....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-26-2023, 09:28 AM   #335
cornerstone
Yeah, that was just another random fleeting thought. I'm not gonna do this much sanding and then cover up all that work. I just have to make sure and follow the directions and follow the best practices I've read about and it'll look good'nuf for me.
I want to get more opinions on some paint and body questions.
My truck has been taken down to clean metal or original sanded paint then epoxy coated in 2 different colors. (Black and white)
Then I did filler work after hammer and dolling any dents I could access.
After sanding the filler down I sprayed Summit Racing 2K urethane primer (gray) This is where I am now. I'm all out of the gray 2K urethane primer, but I do have a gallon of this Feather Fill G2 Polyester primer in "buff" color, also a high buildable primer. The Technical Data Sheet for the Feather Fill G2 says it's ok to apply over urethane primers.
I'm not sure why I though it was a good idea to pick so many different colors, and I don't believe it will make a difference in the paint job. I'm thinking as long as I use a good sealer before I spray the final blue single stage paint, it ought to cover either the gray or the buff just the same. Does this sound right?
My question is this. Would you buy another can of the gray urethane primer and finish the bodywork in the same color and material; or would you use what you already have on hand even though your project is gonna look like a wild hyena, with grays and tans all over the thing.
Here are some pics to ponder.
Brian
Old 05-26-2023, 09:36 AM   #336
clay68c10
clay68c10's Avatar
As long as those different products are chemically compatible, why not. Supplies are expensive.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-26-2023, 10:30 AM   #337
hewittca
hewittca's Avatar
Yeah, I would be most worried about chemical compatibility. If that checks out, then I think it will be fine. These trucks were painted originally with black primered fenders and red oxide cabs, so I think the color uniformity will be fine with your primer colors.
Old 05-26-2023, 11:14 AM   #338
MDPotter
MDPotter's Avatar
It's generally not best practice to spray polyester over 2K urethane. Typically polyester is sprayed over epoxy or filler, then you sand it, maybe reapply and sand again depending on how it blocks out and then you apply 2K. 2K doesn't build nearly as thick and is meant for "fine grading". I used a spray polyester once and wasn't a fan - it's like spraying bondo so you have to mix it quick, spray it quick, and clean the gun quick. Much more flexibility with 2K or even epoxy. 2K dries quicker but isn't always recommended over bare steel (depends on the manuf) whereas epoxy can be sprayed over anything but takes longer to dry.
In the end, just read the TDS for the products you're using but I would be leery of polyester over 2K. It's like applying filler over 2K - you're supposed to be done with filler work by the time you get to 2K to do the "fine grading".
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-26-2023, 05:05 PM   #339
cornerstone
Thank you guys for your thoughts. I went back and re-read the TDS and apparently I assumed the 2K would be an acceptable substrate based on the other things listed as acceptable. On the list are fiberglass, SMC(?), rigid plastics, body filler or putty, epoxy primer, and etch primer. 2K isn't actually listed, but "pre painted surfaces" are on there... I guess that's why I made that assumption. Anyways, I'm glad I asked.
I've seen the nice paint work you fellas have done before which proves you know what you're talking about. I've ordered another gallon of urethane 2k to continue on. My son has a Toyota Tundra he intends to paint in the relatively near future so I'll save the Feather Fill G2 for that truck's body work repairs.
Brian
Old 06-21-2023, 11:36 AM   #340
cornerstone
Nothing real big going on here, but thought I'd show these sweet caps on white steelies. I pulled the 20" Coys off and put them up for a while. Thanks again to Kingsolver72, your generosity is remarkable man. I picked up a can of Krylon true blue in order to paint the bowties in the center. I'm trying to find projects that I can work on in the house since the heat and humidity are unbearable here lately. We had a heat index of 118* a couple days ago and they say the next week or so will be similar temps.
Brian
Old 06-21-2023, 12:46 PM   #341
hewittca
hewittca's Avatar
Oh man, I like the look of that wheel! Is this a direction change in the overall look of your truck or just for fun?
Old 06-21-2023, 03:00 PM   #342
cornerstone
I've always planned on having the 2 different sets. I love both styles.
Brian
Old 06-22-2023, 08:37 PM   #343
zicc1835
zicc1835's Avatar
that's a great look.........stay hydrated, its been cooler than normal here in the East
Old 02-25-2024, 09:47 AM   #344
cornerstone
Just touching base here. It seems I can only stay focused on any particular project for a maximum of 6 months. I haven't touched anything on the C10 in a long time so with any luck I'll come back around to it soon. Lately I've been eat up with flying again. I bought a Quicksilver ultralight back in November. The closest airport is privately owned and has a waiting list for hangar space, so I fully committed to it and built a hangar to keep it in. I took out my MX track (I hardly ride anymore) in order to have an airstrip at the house.
Brian
Old 02-25-2024, 08:25 PM   #345
zicc1835
zicc1835's Avatar
Love the look of the ls in the frame
Old 02-26-2024, 11:04 AM   #346
rodstored-72
chevy truck fan
rodstored-72's Avatar
cornerstone, really liking the build especially the modern drivetrain.... I read thru the build & couldn't help but notice that you have the same issues alot of us have...... "I took out my MX track (I hardly ride anymore) in order to have an airstrip at the house LOL!! that is too funny when taken out of context...keep up the nice work on the build!
rodstored-72 is offline   Reply With Quote
Old 03-08-2024, 01:05 PM   #347
hewittca
hewittca's Avatar
Good to see you check in even if you haven't worked on the truck in a while. My motivation comes and goes in phases as well. I look forward to seeing updates when you get back to it!
