12-27-2022, 07:47 PM | #3476 |
Too Dumb To Know Better
Re: PO has me PO'd
Jim,
I hope that you had a Merry Christmas full of joy and family. |
12-29-2022, 04:59 AM | #3477 | |
Re: PO has me PO'd
Jim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-02-2023, 06:30 PM | #3478 |
Re: PO has me PO'd
16726712071993794333595782012123 by 16726713581084422214247618110369 by [url=https://www.flickr.com/photos/97391199@N06
Had to relocate my dip stick as it interfered with exhaust manifold and spark plug wire
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-04-2023 at 10:57 AM. |
01-02-2023, 09:26 PM | #3479 |
Re: PO has me PO'd
Jim, that's a clean looking setup.
01-04-2023, 10:56 AM | #3480 |
Re: PO has me PO'd
Thanks Bud, the hard part was finding V/Cs with a threaded boss to mount the coil pack,
Didn't want to drill holes for fear of leaking oil Still have to relocate O2 sensor, shorten and repin
01-13-2023, 11:02 AM | #3481 |
Re: PO has me PO'd
Don't remember inner being that RUSTY.......
Oh well, time to seell parts to buy bed sides 16736217880861385148677673716610 by [url=https://www.flickr.com/photos/97391199@N06
01-16-2023, 10:26 PM | #3482 |
Re: PO has me PO'd
Jim I been following you for years now. You are a legend. I always enjoy your posts.
BR549 |
01-17-2023, 11:50 AM | #3483 | |
Re: PO has me PO'd
Here is my present situation fix it with little money 16739705330035015213785893040048 by [url=https://www.flickr.com/photos/97391199@N06 My plan is to flange it and panel bond, we'll see how it goes
01-18-2023, 11:21 AM | #3484 |
Re: PO has me PO'd
16740546194415795064041540739354 by 16740551337337357136205793558200 by [url=https://www.flickr.com/photos/97391199@N06
I prefer the quick release mandrel, makes changing wheels much faster
01-18-2023, 11:34 AM | #3485 |
Re: PO has me PO'd
for some reason my narrative went away between pictures
This is about the tightest arc you can cut with a 1 1/2 inch cut off wheel, I like to sneak up on it, leaving a little white paint to see my line The wheel generates a lot of heat quickly, so touch the metal, if you can’t hold onto it, then your cutting too quickly and you may warp the metal I generally cut right, with my contact area of the wheel at 4 o'clock, don't force it as you may explode your wheel, not pretty It's a slow process but far more accurate than my big dangerous angle grinder, that thing scares the begeases out of me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-18-2023 at 11:39 AM. |
01-18-2023, 12:19 PM | #3486 |
Re: PO has me PO'd
01-21-2023, 09:40 PM | #3487 |
Re: PO has me PO'd
[quote=jaros44sr;9168221]Progress
16740585260413439056306975065340 by [url=https://www.flickr.com/photos/97391199@N06[/quote] nice cut Jim I have same issues with both tools
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-05-2023, 09:36 AM | #3488 |
Re: PO has me PO'd
Opened up the outer bedside to solid metal
16756037954007325747051319963575 by [url=https://www.flickr.com/photos/97391199@N06
02-05-2023, 09:38 AM | #3489 |
Re: PO has me PO'd
I think I know why AMD didn't finish the lip
16756038376591705941485441519095 by [url=https://www.flickr.com/photos/97391199@N06
02-14-2023, 10:41 AM | #3490 |
Re: PO has me PO'd
16756037954007325747051319963575 by 16757818760246899447366407843417 by [url=https://www.flickr.com/photos/97391199@N06
Was able to bend the flange closer to a 90 with my Cresent wrench Now have to figure out the 45 degree bend
02-14-2023, 10:46 AM | #3491 |
Re: PO has me PO'd
16757815537835699553626794217385 by 16762356858382285689831746616053 by [url=https://www.flickr.com/photos/97391199@N06
This patch panel was bought as a replacement for a 67-72 fleetside pick up
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-14-2023 at 10:55 AM. |
03-08-2023, 10:25 AM | #3492 |
Re: PO has me PO'd
16782850771787963944618241151351 by 16778048021787003373180978318510 by [url=https://www.flickr.com/photos/97391199@N06
Don't do it like me, now I have to build a template Saw the great Chip Foose do it when he put boxster head lights in a Europa Cut your patch panel first, then use that as your template
03-08-2023, 10:51 AM | #3493 |
Re: PO has me PO'd
Had to stretch it a bit to get the convex right
16782869450575280686511729652294 by [url=https://www.flickr.com/photos/97391199@N06
03-08-2023, 11:23 AM | #3494 |
Re: PO has me PO'd
Wish I had the tools -Greg has, but in the mean time I'll have to use a chunk of railroad and my body hammer
16782887853227828699904232132280 by [url=https://www.flickr.com/photos/97391199@N06
03-08-2023, 11:33 AM | #3495 |
Re: PO has me PO'd
Not to bad for the first attempt at hammer and dolly
16782894691456990831330073837974 by [url=https://www.flickr.com/photos/97391199@N06
03-09-2023, 07:11 PM | #3496 |
Re: PO has me PO'd
Looking good, Jim.
03-16-2023, 07:24 PM | #3497 |
Re: PO has me PO'd
Thanks for following, Bud
1679008946258155857158489269465 by [url=https://www.flickr.com/photos/97391199@N06 This seems to be starting point for each piece Could not bend the 45 degree without warping the entire panel, so I pu the 45 on the flange
04-08-2023, 11:03 AM | #3498 |
Re: PO has me PO'd
Yesterday's failures, are today's success
16809659918512915031416322998765 by [url=https://www.flickr.com/photos/198023675@N07
04-08-2023, 11:06 AM | #3499 |
Re: PO has me PO'd
16809662707332316500266128816557 by [url=https://www.flickr.com/photos/198023675@N07
04-08-2023, 11:10 AM | #3500 |
Re: PO has me PO'd
1680966533860177011134342163466 by [url=https://www.flickr.com/photos/198023675@N07
