Closed Thread
Old 04-13-2016, 11:19 AM   #3526
saltynuke
Re: What did you do to your truck today? Chapter II
Went to take my daughter for a ride this weekend, engine turned over, and then starter wasn't turning the flex plate. Looked under the truck and found this. Seems to be a common problem with the aftermarket PMGR starters. Tried installing a replacement from Napa and it was bad out of the box so I spent $3.60 on 3 new machine screws to mount the starter to the mounting flange (thanks to some great comments on the Summit site). I'm really glad this happened in my driveway and not 60 miles from home!
Shawn G.
1969 C20
saltynuke is offline
Old 04-13-2016, 11:19 AM   #3527
66clow
66clow's Avatar
Originally Posted by JG67 View Post
66Clow your drop looks good. What tire sizes do you have on in the pictures. Looks perfect man. I'm thinking of the same drop. Did you uses ECE? Spindles/springs/shocks? Is your drives haft close to the cross member? Thanks in advance I'd like to do this soon.
Thanks, CPP springs and shocks. 3 5. Tires are 235/75/15. The drive shaft is right down the middle of the hole. I want to put on spindles and blocks to go 5.5 and 7. I did use the old lower rear shock mount brackets to get another 1/2 inch. So it is actually 5.5 rear. Not pretty but it was a free .5. Will do a notch as well.
66clow is offline
Old 04-13-2016, 10:24 PM   #3528
Lanman1972
Lanman1972's Avatar
Getting ready to start the rust repair, removed the bed today at work. Drove it home about 8 miles on the city streets with my make shift tail lights. Fully functional of course.
Lanman1972 is offline
Old 04-14-2016, 07:21 PM   #3529
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
I added some lights to mine!
One on each door.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 04-14-2016, 09:58 PM   #3530
palallin
I broke it.
On the way home from work, I heard a hissing sound, and soon the power steering wasn't. Popped the hood to find the expected spray of fluid in the front left corner. I man-handled him home, and now I have to refill the pump to see where the leak is. I *think* its a hose and *hope-and-pray* it's not the box.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline
Old 04-14-2016, 10:02 PM   #3531
Possmguts
Possmguts's Avatar
Got a call from the woman to tell me I have 5 big boxes sitting in the living room waiting on me to get home this weekend...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 04-14-2016, 10:16 PM   #3532
OregonNed
OregonNed's Avatar
Bought some new shocks to install this coming week
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-14-2016, 10:38 PM   #3533
Raleighswb
When I could not get enough hood to fender gap(on passenger side) with my aftermarket hood,decent gap on driver's side I put a hopeful ad on Craigslist.Jim not only had an hood in excellent shape but drove over an hour to deliver it,so I learned that when you get disgusted and don't know what to do next---it is going to work out.
Raleighswb is offline
Old 04-14-2016, 11:10 PM   #3534
Dave K.
Dave K.'s Avatar
Finally got brake fluid squirting from all four corners on my K10. Found the rear flex line had collapsed inside--likely original. Some more bleeding to do to get it right as the master cover (rebuilt unit) leaked so I used the old one.
Also installed the new glove box insert and will be doing the door and window seals as well as some other small items.
Pertronix is next.....
Dave K. is offline
Old 04-15-2016, 05:31 AM   #3535
88fordf150
88fordf150's Avatar
One on each door.
That is cool! I have never seen that done before.
Brad handshoe
88fordf150 is offline
Old 04-15-2016, 07:46 AM   #3536
Mator
Mator's Avatar
One on each door.
That is way cool. One of the best lighting mods I have ever seen.
Mator is offline
Old 04-15-2016, 12:03 PM   #3537
66clow
66clow's Avatar
One on each door.
Can you post a wide angle shot I can't see exactly what you did? Thanks
66clow is offline
Old 04-15-2016, 03:35 PM   #3538
Andy4639
Old member
Andy4639's Avatar
You drill a hole in the bottom of the door and run the hot wire to a constant 12 volts. Then the ground to the door jam ground so when you shut the door it turns off. The flash washed it out.
I bought them off E Bay!
Here is his add.
Takes about a week and half to get them.
http://www.ebay.com/itm/LED-Lighting...658017?vxp=mtr
Andy4639 is offline
Old 04-15-2016, 03:40 PM   #3539
66clow
66clow's Avatar
Here is his add.
I see now pretty cool. Thanks I got a lot more to do before I get to those details. But nice.
66clow is offline
Old 04-16-2016, 10:50 AM   #3540
matthamby
Hey guys!
I just made a post on the thread about my truck;
http://67-72chevytrucks.com/vboard/s...=1#post7562538
I will get more photos soon!
matthamby is offline
Old 04-16-2016, 11:41 AM   #3541
Lanman1972
Lanman1972's Avatar
Started the tear down, no big surprises yet. The speaker holes behind the seat really irritate me. Need to get the fuel tank out and weld in some braces.
Old 04-16-2016, 09:42 PM   #3542
custom10nut
custom10nut's Avatar
Yesterday, I took a broken header off. Today, I put one new one in, along with replacing the fuel pump and filter. (There's nothing like getting a gasoline bath right before supper!). Tomorrow, finish up the other header and put a new temp sending unit in. Pretty fruitful weekend, so far
custom10nut is offline
Old 04-17-2016, 08:25 PM   #3543
Possmguts
Possmguts's Avatar
Fit the new grille, mocked up some radiator brackets, and sat the bed back on the frame to get an idea on how Im going to do the fuel fill with the Boyd tank and stripped the driver side of the bed and uncovered quite a bit of work its gonna take to get it straight. No rust hidden under all that paint and bondo though.
Old 04-17-2016, 08:40 PM   #3544
custom10nut
Got the headers finished, temp sender in, and one wheelwell. I'll finish it up tomorrow. Still have to replace some fuel line. Sorry for the blurry pic. Next week I'll start on the inside. I'll keep y'all posted
Old 04-17-2016, 09:05 PM   #3545
Elliot949
Dan Johnston
Elliot949's Avatar
Got the final block done on the cab of "Raymond... moving to the bed this week... Hoping to go to paint with the cab and bed next weekend...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 04-17-2016, 10:37 PM   #3546
jdalexa84
Got to take mine on a road test and drove it about 120 miles to San Antonio.
I finished my transmission swap about two weeks ago and I'm loving the overdrive.
I put a 200-4r in and cruise at about 2250 rpm to do 75 mph.
Glad to be able to drive it again as it has been down for about 3 1/2 years.
jdalexa84 is offline
Old 04-17-2016, 11:32 PM   #3547
Possmguts
Possmguts's Avatar
What rear gear are you running? That's one of the trannys on my possibility list..
Congrats on getting yours back on the road.
Old 04-17-2016, 11:34 PM   #3548
jdalexa84
I have a 3.73 with 30x9.50x15 tires
Thanks it's great to drive it again
Old 04-17-2016, 11:42 PM   #3549
colgad
colgad's Avatar
Installing Vintage AC in the Blazer. Good AC is a must have for the Power Tour.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 04-18-2016, 08:49 PM   #3550
gangforward
Hootis is as Hootis does...
gangforward's Avatar
3" Exhaust Install - Future SuperCharger....
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline
Closed Thread
