03-10-2012, 07:34 PM | #3601 |
Re: What did you do to your truck today!
Istalled front and rear firestone air helper springs.
Bryce 1972 Chevy K20 powered by an inline 6 |
03-10-2012, 07:44 PM | #3602 | |
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
03-10-2012, 10:59 PM | #3603 |
What did I do to my '67 today? Filled the tank up and drove it down the coast!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
03-10-2012, 11:06 PM | #3604 |
67cheby
Motor looks sick
Posted via Mobile Device |
03-11-2012, 12:24 AM | #3605 |
Hopefully the final install of the motor.
03-11-2012, 03:27 AM | #3606 | |
1970 K20 Custom 427/TH400/PS/PB and a dash of badass! I was made in America, my truck was too...4 years before me. |
03-11-2012, 04:21 AM | #3607 |
I took off my grill for paint-success
I installed a new turn signal lever-success Installed new wood steering wheel-failed (again) Installed clear turn signal/parking lenses-success (real happy with the kit from LMC for $20, 2 lenses gaskets and amber bulbs) Posted via Mobile Device Posted via Mobile Device
03-11-2012, 07:44 AM | #3608 |
Yesterday the the brake and clutch pedals went in. Clutch is hooked up and adjusted. Windshield washer hoses and sprayers installed. Emergency brake cable attached and conected. Power steering hoses connected. Today the carburetor is going on and start wiring the engine harness. It feels good, my goal is to have truck on the road by April 15th.
I had to turn the dipstick because it was in the way of the clutch linkage. That wasn't fun.
I know I can! I know i can! 72 K20 Restoration |
03-11-2012, 06:01 PM | #3609 |
Drove her around and returned some movies then brought her home and cleaned her and threw a coat of wax on her.
_____________________________________ Dennis 1969 C10 250 w/3 on the tree - project/weekend warrior 2010 Subaru Impreza - daily driver |
03-11-2012, 07:58 PM | #3610 |
Very nice extremely clean truck, kind of nice to see a truck that isn't altered to much, not so common anymore is it, she's a looker.
03-11-2012, 08:11 PM | #3611 |
Clean truck, Delo69. Where'd you get the hubcaps?
03-11-2012, 08:46 PM | #3612 |
Cut my dash panel up a bit and fit Autometer Gauges in and a 3 pod on the dash bottom. Dash is gas/speedo and Tach.
A nd had last drive today, sold tires/rims today and bought new doors so off to body work/paint then new rims Mt Classic11 rims and Pitbull Rocker tires. Off the road for a while. |
03-11-2012, 10:12 PM | #3613 |
drove it all day today and stopped by my buddies house..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
03-11-2012, 10:16 PM | #3614 |
Hey big al 71, what kind of box cover do you have, name brand and where from, looks good.
03-11-2012, 10:29 PM | #3615 |
Got some gas before it gets to $5 and burned a little rubber...
03-11-2012, 10:34 PM | #3616 |
Installed freshly restored brake booster and master cylinder. Installed vintage air compressor and engine wire harness.
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
03-12-2012, 01:01 AM | #3617 |
Got the hubcaps off ebay..they started off as S10 hubcaps that were black..I stripped the paint off them and repainted them white with blue bowtie to match the truck.
mud.man.rj Thanks I wanna try keep her as original as I can with some updates..going to freshin up the interior next the PO cut up the dash pretty good but I got an idea to fix..
03-12-2012, 02:11 AM | #3618 |
03-12-2012, 07:08 AM | #3619 |
Thanks Paws_72! Now just to find the time to finish her before summer!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
03-12-2012, 11:40 AM | #3620 |
NICE TRUCK! beleived we talked on Facebook page already, because I have 69 c10 that is ur twin just I have the white bumpers and top and bottom trim. This summer I am going with white steelies like you got. Looks awesome. What size rubber you running?
03-12-2012, 12:04 PM | #3621 |
Florida Edition
Installed my 72 throttle cable and pedal adaptor, now I need to find a shorter cable or shorten this one about 1/2"....it works good I just want to take some of the tension off of it.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-12-2012, 02:16 PM | #3622 |
A small change from my normal, "Jumped in and drove it to work this morning!". In the process of replacing the old worn out 454, with a newer less worn out 454. Should have been finished Saturday but, being an idiot I lost the bell housing bolts out of the donor truck, and had to wait until today to get more!
03-12-2012, 03:11 PM | #3623 |
67cheby
beautiful work
03-12-2012, 04:15 PM | #3624 |
C/10 junkie
Picked this up to go in the 68, an original 327. Needs a cleaning but I have a set of fuelie heads ready to go.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-12-2012, 05:52 PM | #3625 |
trizact 1500-3000 and buff...
