03-15-2012, 09:03 AM | #3651 |
Re: What did you do to your truck today!
Let us know how the vintage air installation goes. I want to put one in next year. Pictures please.
I know I can! I know i can! 72 K20 Restoration |
03-15-2012, 10:03 AM | #3652 | |
PITbut
Living in seattle its a must to be water proof. lol. I REALLY wish it would just be dry for 1 day this week.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
03-15-2012, 10:12 AM | #3653 |
cool, lightened things up for me, too !
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
03-15-2012, 12:36 PM | #3654 |
Today I put seal back on rearend, and installed some tail lights and bu lights
03-15-2012, 08:04 PM | #3655 |
Grand PooBaa Member
Decided to paint my calipers and drums today. Did not have anything else to do until I buy a welder.
03-15-2012, 11:18 PM | #3656 |
Adjusted my headlights...
Driver-side was pointing up in the air and the passenger-side was off to the right blinding pedestrians, walking toward me on the sidewalk.
'69 Fleet It ain't yours, if you didn't build it! |
03-15-2012, 11:23 PM | #3657 |
Went to a car club meeting tonight and discussed all our builds and got a few cool ideas on mine with a twist so good night with work planned soon.
03-15-2012, 11:24 PM | #3658 |
Location: San Diego, Escondido, California, Del Dios Hwy
I put the top on for the 1st time in years cuz its supposed to rain this weekend and I am going to CPP Show Rain or Shine...
03-15-2012, 11:56 PM | #3659 |
I'm such an idiot! I checked my oil an noticed it was about a half quart low. I topped it off and promptly drove it 8 or 9 miles with the PCV valve out of the rocker arm cover!!! I did smell something burning but I thought it was the little bit of oil I spilled on the headers.
Oh well, everything now has a nice protective oil coating on everything. It looks like I only lost 4 -6 ounces of oil. Getting older is for the birds!! Keith Last edited by lil hoodlum; 03-15-2012 at 11:57 PM. Reason: I can't spell PCV |
03-16-2012, 02:36 AM | #3660 |
I adjusted my bed on my 70' shortbed. Next I will be removing the stock spot lights, adjusting the front bumper, replacing the grill which has a dent in it, pull out a little dent in the hood, and buff it out (It's all original and in really nice shape considering the age)
03-16-2012, 07:55 AM | #3661 |
I installed the B&W gooseneck hitch and replaced two bend bed bolts.
Bryce 1972 Chevy K20 powered by an inline 6 |
03-16-2012, 08:03 AM | #3662 |
72 cummins which model did you use!!!??? I talked with them and they told me I would have to order the ford center and fabricate my own brackets! So I ended up buying a blue diamond and am going to have to modify it.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
03-16-2012, 08:23 AM | #3663 |
Tonight was a successful night. It's funny how it goes. One day everything you do takes forever and the next things just sort of fall into place. I was able to build my rear upper shock brackets (to move it up and back) and modify my bed cross sill (spot welded in) to allow clearance for my gas tank. I had a differnt take on the upper shock mount brackets. I used the originals, cut them up and welded them to a piece I had cut out mounting the gas tank. It allowed me to move the mount point 1.75" up and 4.5" back. The shocks will nearly mount in a vertical position. I also moved a frame cross sill that was not square. It was driving me crazy. Each time I walked by the truck it looked like it was leaning to one side. Measured the frame to floor and it is only off 3/8". It was the frame cross sill the panhard bar is mounted to. The passenger side was 1.75" farther to the rear that the drivers side. Removed the rivets (have I said how much I HATE rivets ) and squared things up. I welded it into place and also welded the main cross sill while I was at it. That should stiffen things a bit. Now it's time to take it all apart, clean it up, prime and paint. While my son is home over spring break we will stand the bed on it's front so I can finish the work on that, prep/prime and paint the bottom. Progress!
Attached Images |
03-16-2012, 04:56 PM | #3664 |
Nothing big. I drove it ... with no particular place to go. Great weather today. Ended up in a state park beside the river.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-16-2012, 05:43 PM | #3665 |
Tried to get the back wheels centered in the wheel-wells, but it was a no go. I guess when you lower these "bad-boys" the triangulation of the trailing arms pushes the wheel centerline backward in the wheel-well.
03-16-2012, 08:44 PM | #3666 |
I stole my wife's "minivan" to go pick up my new Transmission. I had it delivered to work to save some cash.
Cant wait to start the swap -=Scott=- |
03-16-2012, 09:16 PM | #3667 |
today i just took a couple pics.......installed my drop this week!!!
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
03-16-2012, 10:24 PM | #3668 |
67cheby
Nice
Posted via Mobile Device |
03-17-2012, 08:40 AM | #3669 |
Put a heater blower motor in. The third trip to the parts store, I finally got a good motor. The first one I brought home squealed worse than the old one. Took it back they didn't have one, had to drive to another town to get one.
Friends don't let friends drive Fords |
03-17-2012, 09:35 AM | #3670 |
C/10 junkie
Nice drop Hotrob, what are the specs?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-17-2012, 09:40 AM | #3671 |
C/10 junkie
Bought a unknown turbo 350 from KrazyRay and when I took it apart it was a fresh rebuild!! The guys next door to my work at Lodi Transmission gave me all new gaskets and seals. So for a total investment of $10 I have a completely rebuilt transmission to go into my truck!! I am so stoked, thanks to board member KrazyRay. He is a super nice guy and awesome to deal with I suggest you look into what ever he is selling, you won't be disappointed.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" Last edited by shawno72; 03-17-2012 at 10:35 AM. |
03-17-2012, 09:44 AM | #3672 |
Starting to put this mess back together ( Muncie 4 speed). Also test fitted my lower alt. bracket.
Brad handshoe |
03-17-2012, 10:02 AM | #3673 | |
03-17-2012, 06:13 PM | #3674 |
put the 2 inch lower front springs in , the front sway bar and rear trailing arms bushings are in...
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
03-17-2012, 06:22 PM | #3675 |
C/10 junkie
Hey 88ferd150 what kind of spindles are you running?
