01-08-2007, 11:51 PM | #351 |
Re: Dropmember in a 69 C10
Correct, the 73-87 3" drop spindle can be used ( and necessary to lay it on the ground with a 29" diameter tire), I just don't offer it... yet. Keep in mind, the 73-87 spindle uses a different ball joint than the others.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-09-2007, 12:11 AM | #352 |
I'm aware of the ball joint issue. Can the newer ball joint(73-87) be used on the 67-72 arms?
01-09-2007, 12:20 AM | #353 |
yes
01-09-2007, 01:40 AM | #354 | |
I guess I should say I'm trying to minimize the underhood hardware for minimal cash outlay. Homemade/modified aftermarket steel brackets are a heck of a lot cheaper & already in place. The C4 Dropmember was appealing 'cause it would help shed some of those extra pounds that big ole' engine has vs something much smaller. I'm already doing alum heads, radiator, & electric fan/shroud combo to help minimize the front end weight. How much drop is the dropmember? I mean, if I were to 'Z' the stock frame, how much would it take to equal the dropmember?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-09-2007 at 01:44 AM. |
01-09-2007, 10:23 AM | #355 | |
Junior Member
01-09-2007, 11:49 AM | #356 |
What is the starting point? Runnung driver? All sheetmetal? The starting point of the vehicle will have a large effect on the price. I charge by the hour, but can give a sound estimate.
01-09-2007, 03:32 PM | #357 |
Señor Member
Talk about a hijack...
SCOTI, I thought about running the alternator off of the rearend to get it out from under the hood. If you put the (right size) pulley on the rearend at the driveshaft and then mount the alternator back there, it might work pretty well... so long as you didn't spend a lot of time sitting at idle. Waddaya think?
01-09-2007, 03:34 PM | #358 |
Señor Member
Any chance? I've got several projects I'd love some quality help on...
01-09-2007, 03:41 PM | #359 |
I can't remember what the brackets look like but boats w/ V-drive run the alt of the driveshaft. If you know anyone that has one it's a good place to start
01-09-2007, 04:01 PM | #360 |
01-09-2007, 04:13 PM | #361 |
Señor Member
I was kind of thinking the rate was a little more than that. But... gotta ask
01-09-2007, 04:18 PM | #362 |
Commander Taco Bello
so any update on the 69 C-10?
this thread on well on it's way to be the next million post thread :-) |
01-09-2007, 09:52 PM | #363 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-09-2007 at 09:52 PM. |
01-09-2007, 10:08 PM | #364 |
Nathan, congrats on the article. I just got my issue in the mail today and it made me think about the difference in price between the dropmember and the C4 version.
Minus the price difference between bags/shockwaves, is there a price difference from a complete C4 dropmember spindle to spindle to the dropmember using strong arms and 6 lug discs? I know you have a "source" for the C4 parts and your a dealer for Air Ride. But I dig the idea of the C4 kit. I'm not looking to lay frame, but to use Vette parts (I will have an LSx motor some day) would be so pimptastic! <edit> NEVER MIND. I used search and found the info in the C4 thread. I still want it though! Last edited by jimmydean; 01-09-2007 at 10:40 PM. |
01-09-2007, 10:21 PM | #365 | |
might be too small for youre use but you could run a lil bigger weedwackerpowered dynamo generator under the bed if the driveshaft one doesnt provide enough juice (think i need to take my pill now )
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-09-2007, 10:21 PM | #366 |
Outlandish Trends - FL
did you just say pimptastic???? hehehe
-Bret 67 short-fleet sold! |
01-09-2007, 10:34 PM | #367 |
Dude, you can not tell me that by running an after market Vette suspension and steering setup wouldn't increase my pimp-factor by at least +5.
Of course I would end up spending way more than my initial budget, but I guess that went out the window a long time ago. |
01-09-2007, 10:47 PM | #368 |
DropmemberC4 = $1200
C4 front kit off ebay = $800 Shockwaves = $850 Pimp-factor = priceless... I'll be posting some internal organs on ebay this week. I need to support my habit somehow. |
01-09-2007, 10:55 PM | #369 |
Scoti-
Just convert all your power to AC and run a Honda gas generator in back.. under the tonneau cover of course!
01-09-2007, 11:02 PM | #370 | |
Here's some pics of one going into a 71 Blazer... the body has a 'little' rust.
01-09-2007, 11:10 PM | #371 |
A guy with a truck
Beautimus!!!!! Anyone want to buy my first-born?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-10-2007 at 01:27 AM. Reason: I'm a non-spelling fu#*tard |
01-09-2007, 11:16 PM | #372 |
Señor Member
Good luck! I've been trying to sell mine for 10 years... why do you think my truck is taking so long to finish?
01-09-2007, 11:18 PM | #373 |
I really want one of those just can't afford it right now.
01-09-2007, 11:30 PM | #374 | |
Señor Member
01-10-2007, 12:18 AM | #375 |
Ok.... we now return to our normal programming. Nathan, in the barrage of posts recently I didn't see an answer to my question: How much drop is the dropmember? I mean, if one were to 'Z' their stock frame, how much would it take to equal the dropmember? That C4 set-up sure looks right . . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-10-2007 at 12:23 AM. |
