03-24-2019, 12:48 AM | #351 |
I have a radical idea!
Re: 67 C-30 Dually pickup build.
I seem to have lost the ability to embed YouTube videos. Has it changed from the way it used to be?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-24-2019, 08:49 AM | #352 |
Glad you did not sell it and things are looking Brighter for you.
Your Write-up and pictures help me get started with my dually fenders on a fleet side bed. I also plan to use Hydro-boost. I can't help you with the U-tube video's. I hope someone can. Looking forward to a video .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-24-2019, 09:35 AM | #353 |
I am glad I asked.
03-24-2019, 10:24 AM | #354 | |
If you haven't solid mounted your rear fenders yet, I'd recommend maybe doing it a little differently than I did - or least doing it better than I did. Back then all I had was a crappy flux core welder (plus I'm a much better welder now) and I got some warpage where I welded the tabs on. I'm going to redo mine with '67 stepside fenders, and I'm thinking of gluing the tabs on this time, or buying a spot welder. I'm glad you did too! The years of working 70-80 hours a week kinda kept me away from here for a long time. I'd lurk occasionally, but it was kinda depressing knowing I had sold most of my trucks, and didn't have time to work on the ones I still had.
03-24-2019, 11:48 AM | #355 |
This is the invoice for the simulators that I finally put on the truck. 😂
03-24-2019, 12:11 PM | #356 |
Your Simulators looks great.
I have not solid mounted my rear step fenders yet. Which reminds me I needs to update my build thread. I would like to see pictures when you redo it with the 67 step fenders. If you can. That what mine are 67 fenders.
03-29-2019, 03:34 PM | #357 |
Things got much tighter after the battery box went in. I’ve git to decide which of these setups for the air cleaner I want to go with. This:
03-29-2019, 03:35 PM | #358 |
Or this:
03-29-2019, 03:49 PM | #359 |
I think the first pic w/o the elbow is the cleanest but then again not sure how hot the front of the turbo gets so the elbow might provide some temperature relief.
03-30-2019, 09:46 AM | #360 |
That was my concern as well. I like the way it looks coming straight off the turbo, but I worried about the heat also.
03-31-2019, 10:17 PM | #361 |
I posted some of these pics on the main board, but I figured I’d catalog the latest work here on the build thread.
I made spacers to get the alternator positioned correctly and got the correct length bent figured out. I’ll go back and get another one now that I have it right. That will give me twin Hydroboost and alternator belts. The HumVee crank and water pulley caused a lot of alignment issues, but I'm glad to have the extra belts. The single V belts on my CUCV and always squeaking, no matter what I do. I also figured a way to bend the ‘67 - 68 side molding to wrap around the dually humps. I’m happy with the way that turned out.
03-31-2019, 10:26 PM | #362 |
I recorded a couple videos of it running:
https://www.youtube.com/watch?v=A1iHKarTFK0 https://www.youtube.com/watch?v=mo1y5XQn3XY
04-02-2019, 12:17 AM | #363 |
I got another belt today, so I have the twin belts to the alternator and Hydroboost pump. I’m hoping this eliminates the dreaded belt squeal associated with the normally V-belt 6.2’s.
04-07-2019, 04:54 PM | #364 |
I found out that ‘67 did not have provision for the auxiliary battery tray, but 2 existing holes did line up. I added the 3 additional holes and mounted it.
04-28-2019, 11:41 PM | #365 |
Testing to see if I can embed the videos on this thread.
04-28-2019, 11:47 PM | #366 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-28-2019, 11:54 PM | #367 |
Thanks so much for the tip! I would have never thought of that!
04-29-2019, 01:53 AM | #368 |
I learned it here on one of the music posts. Gotta love this site.
