02-20-2011, 06:14 AM | #351 |
Re: The '67 Burb Build Thread
still dark!lol that is better whens the last time you drove this thing?
02-20-2011, 10:46 AM | #352 |
low n' slo
gettin closer man..cant wait to see it on the ground!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-20-2011, 02:45 PM | #353 |
02-20-2011, 02:46 PM | #354 |
02-20-2011, 08:48 PM | #355 |
wow that suck to know that my truck has ran and then i stopped and am doing work to iy and cant drive it would kill me!
02-20-2011, 09:22 PM | #356 |
haha its not that bad lol. because it is getting some work done to it to make it better
02-20-2011, 09:28 PM | #357 |
pulled the ball joints out of the old arms and i am painting my new arms so i can start putting them together and get them installed
02-21-2011, 11:53 PM | #358 |
finished painting the arms and started painting the u bolts/nuts, now i just need to wait for it all to dry. also painted the washers/nuts that hold the cross shaft in yesterday.
02-22-2011, 12:26 AM | #359 |
well it should ride really nicely now, right? looking good eric cant wait to see this drivin dwon the streets if i see you i WILL pull you over and check out your ride
02-22-2011, 12:35 AM | #360 |
haha i hope so, should ride better than it did on cut springs thats for sure. thanks, come on down to so cal and i will give you a ride if you want lol.
02-22-2011, 12:59 AM | #361 |
well one day i will take you up on that offer!
02-22-2011, 01:04 AM | #362 |
haha for sure bro, just lmk ahead of time
02-22-2011, 01:06 AM | #363 |
you bet and when ever your in town here let me knoe ill give you a ride to. you probably won be in my town untilo i get done with mine so it all works out!haha
02-22-2011, 01:13 AM | #364 |
hahaa for sure lol. i want to try and go to that c/10 bbq Rene puts on this year if possible, but we will see if funds are good enough for that by then.
02-23-2011, 03:14 AM | #365 |
finished painting the u bolts and nuts, installed the ball joints and one cross shaft, did a quick prime and paint on the front bumper, and installed the one lower arm i got done.
02-23-2011, 03:15 AM | #366 |
did a quick wheel check, and have one lower arm left to finish, still need to touch up the paint and tighten the ball joints and tie rod down on the drivers side, regrease the joints and bleed the brake system, do an eyeball alignment, and install windshield and front bumper and i should be just about done enough for the car show
02-23-2011, 01:37 PM | #367 | |
dave
well...have fun at the show...dont think i;ll b there, at either 1.....still need intake, tune up , wiring, exhaust, bleed brakes, blah blah....got a call into the wiring/brain guy...no return yet tick tock tick tock
check out my build "DIRTY BURB" |
02-24-2011, 02:46 AM | #368 |
that sucks, hope you make get the miracle you need to finish it and make it to the show
02-24-2011, 02:51 AM | #369 |
not much of an update, was at the docs almost all day. but, i installed the front bumper, touched up the paint on the drivers lower a arm, drilled the holes out bigger for the plastic screw inserts, and remounted the front plate with a new black frame and a smoked lens cover. no pic of that but here is one of the bumper mounted and adjusted.
02-24-2011, 07:14 PM | #370 |
yay looks like a truck again ! i mean burb haha.....it doesnt matter because the liscense plate will cover but why is that hole on the bumper?
02-25-2011, 02:28 AM | #371 |
hahaha, i was waiting for someone to ask me that lol. that hole is in the bumper because i traded my chrome bumper to my friend for this one, i traded because i didnt want to grind down the chrome on a good bumper just to paint it black. that bumper came off of his 69 longhorn, the previous owner before him drilled 2 holes to the left(drivers side), for mounting the license plate, and cut that hole out to allow air to flow better to the trans cooler that was mounted between the frame rails while towing.
02-25-2011, 02:37 AM | #372 |
got the drivers side and passanger side complete minus bleeding the brakes, regreasing a few things, and putting the wheels on, airing it up, and dropping it back down. also repainted the bumper again due to a few light scratches from people rubbing against it while walking in front of it oh well . and also took a pic of the front with the license plate on with the new black frame and smoked lense cover
02-25-2011, 08:14 PM | #373 |
looks good
02-26-2011, 12:37 AM | #374 |
thanks.
02-26-2011, 12:45 AM | #375 |
greased the few things that needed it, put the wheels back on and dropped it back on the ground. aired it all the way up and let it all the way down, found out i need to trim a little off the bottom of the carrier bearing crossmember as it is holding it up a little and not letting it lay completely out. also found out i need to loosen up the core support bolts and shift it to the drivers side slightly.
