Old 04-20-2009, 10:00 AM   #351
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: The 283 Rebuild Begins
Originally Posted by justcuz View Post
Mac you may want to use the break in additive for the first 1000 miles, just to be sure the cam breaks in good. Newer oils have had the Zinc additive ZDDP reduced because of pollution concerns. The zinc is what helped create the protective friction coating on metal to metal parts.
Good catch.
Bought three of these - figured it couldn't hurt.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 04-20-2009, 10:02 AM   #352
jason65
Registerd User
jason65's Avatar
What did that run ya? I've seen break-in additive go for $20.00 a bottle.
jason65 is offline   Reply With Quote
Old 04-20-2009, 10:09 AM   #353
MacAttack
283 Drama Queen
MacAttack's Avatar
$10.25 each (less shipping) from Summit Racing.
Old 04-20-2009, 06:41 PM   #354
Desert1957
Desert1957's Avatar
Hey MAC!
Cmon , quit teasing us. Did you run the motor or not?
LOL Desert
Desert1957 is offline   Reply With Quote
Old 04-20-2009, 07:02 PM   #355
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by Desert1957 View Post
Hey MAC!
LOL Desert
Nope. No go. Modified transmission line fittings: N.F.G. Going with flared fittings and rubber hoses to cut-off S/S lines instead. Ticked me off...
Wiring completed in engine compartment - battery hookup, HEI wire, under-dash wire connection check next - then maybe, just maybe I can make some noise.
Mac.
Old 04-20-2009, 08:40 PM   #356
LILRED66
LILRED66's Avatar
Alternators are internaly regulated. Generators are externaly regulated. Thats what I was taught. Both are 3 wire. I just never heard of anyone makeing a gen 1 wire.
The original alternators on these trucks were three wire externally regulated, hence the factory voltage regulator on the driver side of the radiator support. A popular conversion is to a one wire, internally regulated alternator.
I don't know the first thing about the early generator set-ups except from the manufacturer's literature.
LILRED66 is offline   Reply With Quote
Old 04-21-2009, 10:03 AM   #357
MacAttack
283 Drama Queen
MacAttack's Avatar
Based on what I’ve gone through on this project (strictly because I listened to the guy at the NAPA store and went to the original factory set-up, based on the alternator that was in there when I got the truck back - and, of course, my ignorance) you don’t want to know.
It hasn’t been worth it.
The idiot that stole my truck butchered up the wiring, both in the engine compartment and under the dash, so bad it might have just been better to buy a completely new loom. I kept putting it off - hoping some magical little wiring gnomes would come during the middle of the night and take my electrical system pain away, but it didn’t work out that way.
While the drive train was out would have been the time to put all brand new stuff in, but that time passed and I ended up with a ‘taco job’, at best. Let that be a lesson to you childrens - plan your dive and dive your plan.
Mac.
Old 04-28-2009, 07:51 AM   #358
jason65
Registerd User
jason65's Avatar
Anything new?
Old 04-28-2009, 10:03 AM   #359
MacAttack
283 Drama Queen
MacAttack's Avatar
Anything new?
While it pained me to do so - cut the transmission cooler lines over the weekend.
I went out of my way to try and make it right, using the lines that were supplied, but the translation from Chinese to English/American didn't work out.
Bought a fairly nice tube cutter (1/8" - 1-1/8" diameter capacity) at Pep-Boys and went at it. Put standard flare fittings into the radiator ports and had a wonderful time trying to get the hard lines to go into the hoses. Between the tight quarters and the odd tubing O/D (something metric) - they went on with a huge press fit, despite heating them up and using Vice-Grips to wrench them on. Didn't really need hose clamps - but put them on anyway.
Everything took three times as long as it should have, but it came out nice. Almost finished with the last few connections on the engine compartment wiring - but still haven't attempted to put the bulkhead grommet in yet.
Mac.
Old 04-28-2009, 12:33 PM   #360
jason65
Registerd User
jason65's Avatar
When I have to fight stuff that don't want to do what it's supposed to. I mix up a double and come back in 10 mins or so and kick it's a$$.
Old 04-28-2009, 12:59 PM   #361
MacAttack
283 Drama Queen
MacAttack's Avatar
My problem is I have to learn to half-a$$.
Old 04-28-2009, 04:06 PM   #362
4dranch
Shloooooong bed member #2
4dranch's Avatar
Oooh.......your suppose to come back after the double...
no wonder I ain't gettin no where....
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 04-28-2009, 04:52 PM   #363
MacAttack
283 Drama Queen
MacAttack's Avatar
My kid is tired of helping/learning on this project and just wants me to drive the damn thing.
Now I think I need to pull the gauge panel, as the hard oil line is clogged (visibly)
at the engine and I think I need to disconnect the speedo cable from the back and then get to the other end of this oil line with an air nozzle.
I'm not starting this fresh rebuild without being able to monitor the oil pressure.
Oh, and I still need to put the shifter back on the transmission - to make sure I'm in "Park" or "Neutral". Oh - and put some more gas in the tank too.
Another month out to do it. (just shoot me)
Old 04-29-2009, 07:37 AM   #364
jason65
Registerd User
jason65's Avatar
Yes. Sometimes a triple.
Old 04-29-2009, 07:38 AM   #365
jason65
Registerd User
jason65's Avatar
Thats how it starts Mac. Next thing you know youll be down to the frame and painting her all up nice and glossy.
Old 05-13-2009, 11:50 AM   #366
MacAttack
283 Drama Queen
MacAttack's Avatar
A few more photos for our resident scavengers.......
Old 05-13-2009, 11:52 AM   #367
MacAttack
283 Drama Queen
MacAttack's Avatar
continued carrion………
Old 05-13-2009, 11:54 AM   #368
MacAttack
283 Drama Queen
MacAttack's Avatar
some more carnage………
Old 05-13-2009, 11:56 AM   #369
MacAttack
283 Drama Queen
MacAttack's Avatar
and finally........
Old 05-13-2009, 12:16 PM   #370
jason65
Registerd User
jason65's Avatar
Ahhhhhh yes progress pics. Motor look nice and clean Mac.
Old 05-13-2009, 12:38 PM   #371
4dranch
4dranch's Avatar
David,
Daughters 66 truck:
Old 05-13-2009, 12:46 PM   #372
jchav62
1962 C-10
jchav62's Avatar
Looks good! Nice, descriptive pics...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-13-2009, 01:17 PM   #373
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks guys. Memorial Day will be the one-year anniversary for getting "The Tan" back from the OC Sheriff. I'm lighting this ol' girl off, hell or high water.
Mac.
Old 05-13-2009, 01:28 PM   #374
4dranch
4dranch's Avatar
Mac.
That's the spirit Mac....
David,
Daughters 66 truck:
Old 05-13-2009, 03:08 PM   #375
jason65
Registerd User
jason65's Avatar
