Old 07-30-2011, 09:58 PM   #351
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by 68 TT View Post
Good idea with the blocks of wood for where the bed rails are.
Don't forget to put about 400 pounds on the rear frame area to compress the suspension to where it will be with the bed, tailgate & rear bumper on. That little bit of movement can make a big difference in pipe placement around the trailing arms.
I'm taking lots of measurments and test fitting. Still thinking about removing the springs just to be sure.
Originally Posted by mcbassin View Post
Hey nice work on the frame. Looks like you have a plan for making the exhaust too.
Couple of questions. Will you need to cut clearence in your bed for the Blazer tank? I just picked one up myself. I am gonna set my fuel system like yours too.
Did you use a Corvette regulator/filter? How do you know if you need one? I don't think my engine has a return at the fuel rail. Does that mean I need one of these style regulators? thanks
Yes, the bed crossmember needs to be notched for the Blazer tank.
Yes, I used the vette filter/regulator. You need a regulator if your drivers side fuel rail doesn't have one built in with the return line. No matter what you need a filter, the vette filter/reg is just a relatively cheap and easy way to knock out both. You can also run a aftermarket regulator and figure out a filter, but I think the vette filter/reg is the less expensive route.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-06-2011, 12:32 AM   #352
mcbassin
Still Learning
mcbassin's Avatar
Thanks Ben! I appreciate the help. I will just notch my bed for the tank before I mount it.
I'm cool with using the Vette filter. Sounds like a good setup. How do I tell if the fuel rail has a regulator?
mcbassin is offline   Reply With Quote
Old 08-06-2011, 04:38 PM   #353
67shortie
Green club
67shortie's Avatar
My intake had the dual fuel line, and the way to tell if yours has one is simply look for 2 connections at the rear of the fuel rail on the drivers side. One will curve into a vacuum pod the size of a trans regulator.
If you have only one line, you will need a external regulator like the Vette setup.
Easy stuff, but I like the dual line myself, it's cheaper
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 09-02-2011, 06:39 PM   #354
usmcchevy
usmcchevy's Avatar
After a month of vacation I back working on it. My little 110v welder is doing pretty good once I got it set right.
More later.
Build thread
LSx Swap FAQ index
Old 09-03-2011, 01:55 AM   #355
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-03-2011, 12:10 PM   #356
mcbassin
Still Learning
mcbassin's Avatar
Exhaust looks good Ben. Did you have to get some different wire for it?
Old 09-04-2011, 11:08 AM   #357
usmcchevy
usmcchevy's Avatar
Thanks guys, more pics later today!
Just using mild steel wire.
Build thread
LSx Swap FAQ index
Old 09-04-2011, 10:36 PM   #358
usmcchevy
usmcchevy's Avatar
Still need to bring it back to the bumper and add the H pipe, but I guess it is going to be considered "done" for a little bit. Welder is having issues maintaining a arc for some reason. It sounds GREAT!! Quiet at idle, but open her up and you know its there
Build thread
LSx Swap FAQ index
Old 09-07-2011, 04:19 PM   #359
mcbassin
Still Learning
mcbassin's Avatar
Exhaust is hooking good Ben! Glad you were able to weld it with the mig.
Old 09-07-2011, 09:46 PM   #360
66redw/white
made in america
66redw/white's Avatar
very clean. i love the way it dumps out. do we have an exhaust clip of this thing yet?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 09-07-2011, 10:15 PM   #361
usmcchevy
usmcchevy's Avatar
Thanks! It sure took a toll on my welder, I found a melted connection going to one of the transformers Oh well in a year I'm moving to MN where I have a Miller 175 and I can sell this thing.
Thanks! Sound clip will come later this week maybe beginning on next week....I have duty this weekend.
Build thread
LSx Swap FAQ index
Old 09-07-2011, 10:40 PM   #362
66redw/white
made in america
ahhhh duty! dont use the d word here! i thought this forum was supposed to be family friendly!!
somebodys gotta do it
sounds good
my old girl
Old 09-17-2011, 11:08 PM   #363
usmcchevy
usmcchevy's Avatar
Still no sound clip...... Both of my cameras seem to be challenged in the audio department.
Bed back on, guy i bought the new bed from is still working on it.
Started working on getting these in.
Temp sender and adapter:
Then turned the glove box door latch into a switch. This is the type of switch I used. Just a cheap momentary switch.
http://www.allelectronics.com/make-a...HBUTTON/1.html
Drilled a 15/64" hole in the bottom of the glove box latch. The latch was already missing the little tang that would keep the glove box door closed. When you push the button, the little lever inside pushes down in turn pushing on the switch.
15/64" Hole
Switch screwed in.
Build thread
LSx Swap FAQ index
Old 09-17-2011, 11:19 PM   #364
68 TT
Still plays with trucks
68 TT's Avatar
So what is the switch for?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-17-2011, 11:43 PM   #365
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Probably the ejecto seato like the fast and furious movie
John
1999 Toyota Tacoma 4x4
Old 09-17-2011, 11:44 PM   #366
usmcchevy
usmcchevy's Avatar
Going to use it for tow/haul mode. The tow/haul mode has been reprogrammed in my computer to be "haul azz" mode, which is higher shift points and harder shifts.
Build thread
LSx Swap FAQ index
Old 09-17-2011, 11:46 PM   #367
usmcchevy
usmcchevy's Avatar
So, wanna go for a ride?.....I'll drive
Build thread
LSx Swap FAQ index
Old 09-17-2011, 11:55 PM   #368
oldblue1968chevy
lol
Good thinkin' usein the button on the glovebox instead of cuttin holes
How do you open the glovebox
John
Old 09-18-2011, 12:06 AM   #369
mcbassin
Still Learning
mcbassin's Avatar
That is very good idea for the tow/haul butt switch. I like the gauges too.
Old 09-18-2011, 12:29 AM   #370
usmcchevy
usmcchevy's Avatar
lol
Thanks! This is my soon to be gauge panel so the headlight/wiper chrome pieces keep it "closed"
Thanks! 5" Pro comp Autometers would have been my first choice, but I paid about $220 for these so I'm happy with them.
Build thread
LSx Swap FAQ index
Old 09-19-2011, 11:22 PM   #371
68 TT
68 TT's Avatar
Nice idea. Can't wait to see the finished glove box gauge panel.
Did you do the PCM reprogramming? I am considering buying the software to do it myself.
Old 09-19-2011, 11:40 PM   #372
oldblue1968chevy
watta bout tackin some bolts to the backside to put nuts on the inside of the dash?
John
Old 09-20-2011, 09:55 PM   #373
usmcchevy
usmcchevy's Avatar
Thanks, I had Black Bear performance do the computer. Next time around I'll buy the tuning software, I was just scared of the steep learning curve of tuning.
Not needed, The headlight and wiper switch bezels hold the top tight and the bottom is held on by the part that holds the steering column grommet. Its not going anywhere.
This is what it looks like now. Still need to do a bit of die grinding in the small holes as the gauges fit a bit too tight.
Build thread
LSx Swap FAQ index
Old 09-20-2011, 10:16 PM   #374
oldblue1968chevy
So your going to use the button as a...button? I thought you would have to reach over to the glovebox...?
John
Old 09-20-2011, 10:20 PM   #375
66redw/white
made in america
my understanding is there is a glove box cover thats goin where the steering wheel is and hes just using the button whole for the haul bauls button
sounds good
my old girl
