Closed Thread
Old 06-16-2010, 09:02 AM   #351
cokeb
Re: What did you do to your truck today!
Thanks Eraser5, that is our plan of attack as soon as we can get wheels back on so the truck can go on the ground to lift from the frame.
cokeb is offline
Old 06-16-2010, 09:29 AM   #352
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Drilled and tapped the back of my tunnel ram so I finally have a vac port for a pvc. Carb bases and the ram had no provision for a port. Now I don't douce my valve covers with oil when I land on it!
prostreetC-10 is offline
Old 06-16-2010, 10:17 AM   #353
07SSSC
07SSSC's Avatar
Cleaned and painted the area that was covered/hidden by the fuel tank and the cab corners. Soap, water, then Por-15. Tonight the sound deadener gets layed down.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 06-16-2010, 10:28 AM   #354
pro1955
pro1955's Avatar
Installed new poorly fitting carpet, new Lokar shifter. Just started and broke in new motor, trans. and rearend. Long day.
Truck's just for the fun of it.
pro1955 is offline
Old 06-16-2010, 09:53 PM   #355
67Slider
67Slider's Avatar
Painted the front frame and firewall.
from this:
[IMG][/IMG]
To this:
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-16-2010, 10:18 PM   #356
07SSSC
07SSSC's Avatar
Nohin, too cold and windy. Glad I enjoyed our 2 days of Summer like weather while it lasted.
07SSSC is offline
Old 06-16-2010, 10:40 PM   #357
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
today I pulled the rest of the rivets holding my passenger side rear suspension, removed the carpet, amp, floor insulation, seat, and unbolted the cab. Will pull the cab tomorrow....I've sweated all I can sweat for one day.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 06-17-2010, 06:26 PM   #358
Dads69C10
Dads69C10's Avatar
Today i removed the steel plate that was welded on top of the wood bed when the truck still belonged to the Air Force.
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline
Old 06-17-2010, 06:36 PM   #359
Deggs
Deggs's Avatar
Replaced the upper control arm shaft, drivers side, and repacked the front bearings.
Should be a little less "ricochet" effect down the highway now.
Found a hole in the collector of my header... Time for a louder radio
Looking for a short fleetside bed in the Pacnorthwest/western Canada.
Deggs is offline
Old 06-17-2010, 08:21 PM   #360
SOON2BLAZE
SOON2BLAZE's Avatar
I got the B%#@H runnin!!! Ran her around the block too! so far no leaks from the dif trans or brakes. Gotta take it easy to break in the new gears (but I wanna roast the old tires off as it's been off the road for 3 years, minus two 5 mile drives last summer) New tires tomorrow, new gas lines and dual exhaust next week.
SOON2BLAZE is offline
Old 06-17-2010, 10:50 PM   #361
68GMCCustom
pulled the cab....everything else was off except for a few riveted items
Kurt -
Old 06-18-2010, 12:02 AM   #362
07SSSC
07SSSC's Avatar
Finished laying the rest of my Second Skin on the last 10" of floor and then put the rest on the back of the cab. Por-15-ed o few more spots too.
07SSSC is offline
Old 06-18-2010, 01:26 AM   #363
joes50pu
I finished blocking out the rear fenders and doors. Now I just have the hood and bed sides to repair.
joes50pu is offline
Old 06-18-2010, 09:17 AM   #364
Shyguy
Junior Member
Shyguy's Avatar
It seems my projects have stalled out, two many projects too little time is the problem.
This time of the year is pretty hectic out here in the flatland of Missouri on the farm.
Also the next thing I need to do on the '71 is figure out where to buy and what carb the stock 454 needs. I have a couple of mechanics telling me different stories, one says go with Edelbrock and the other says go with Holley.
Hope you all have great progress on your projects and keep the post and pictures coming.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 06-18-2010, 11:44 AM   #365
Ole Blue 71
Ole Blue 71's Avatar
Battled with the ignition timing. I will get 'er dialed in yet!
71 C-10 "Ole Blue"
72 C-15 - Current Project
72 K-10 - In Pieces (Sold)
70 C-10 - "Goldie" (Sold)
66 Impala Convertible
20 FLTRXS
Ole Blue 71 is offline
Old 06-19-2010, 01:20 AM   #366
71tahoe
71tahoe's Avatar
Bags!
71tahoe is offline
Old 06-19-2010, 08:31 PM   #367
67Slider
67Slider's Avatar
Finished prepping the engine for reinstall.
From this:
[IMG][/IMG]
To this:
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-19-2010, 08:49 PM   #368
marks1972
marks1972's Avatar
started yesterday repalcing my resistor wire for my HEI upgrade. while i was in there deside to replace another wire i didnt like then another wound up replacing all electrical wires under the hood one by one and eliminating wires not needed anymore like the TCS wireing. used the hot wire for that one on my electric choke. who needs a painless wiring harness when you have diagrams and all the help in the world on this site. thanks for everyones inputs and help. it is amazing at how much better it runs with the new wire on the HEI. smoother and better throtle response. night and day.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline
Old 06-19-2010, 09:01 PM   #369
davebloomer
davebloomer's Avatar
bought a tailgate. ordered bed cover from craftec. bought new side markers and parking lenses. finally bought a gas pedal. Bought a lunati VooDoo 60103. ordered summit racing heads. bought a holley blue and holley fuel pressure regulator.
That should have me pretty hooked up for a few weeks! WHOO HOO!
davebloomer is offline
Old 06-19-2010, 10:36 PM   #370
swierker
swierker's Avatar
Installed late 90's 60/40 split chevy tahoe/truck seats to replace the sagging original. Now I have power adjustments on the driver side and comfy seats.
swierker is offline
Old 06-19-2010, 10:52 PM   #371
vectorit
What?
vectorit's Avatar
Went out for shake down cruise around town, since I have been tweaking everything for a good tune. Got home, then mopped up all the oil that my T221 likes to drip.
Then drained all the oil out of the T221, and then refilled it with new oil.
I really need to get the T-case seals fixed!
Still trying to get everything sorted for the upcoming Brothers truck show!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-19-2010, 10:58 PM   #372
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
frenched my rear sidemarkers and got my bed on..
i really like this thread!
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 06-19-2010, 11:27 PM   #373
Hubscrub
Cruzin
Hubscrub's Avatar
moved my truck to get the car out to go to a show, and painted a head for my wife's 67, after i have already painted it orange a couple weeks ago
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 06-19-2010, 11:31 PM   #374
oldblue1968chevy
^^looks AWEOMSE hub! Is that gonna be the whole theme?
John
Old 06-19-2010, 11:33 PM   #375
Hubscrub
Cruzin
Hubscrub's Avatar
yes sir that were the "Lime" comes in in lime wifes 67
Proverbs 3:5,6
Hubscrub is offline
Closed Thread
