Old 03-18-2012, 11:04 PM   #351
trout
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
looks awesome as always
Edited by staff
trout is offline   Reply With Quote
Old 03-20-2012, 04:30 AM   #352
hick
Did you decide to go back and redo all your brake lines?
My project just got shelved...
So i will have to live threw guys like you
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 03-20-2012, 09:59 AM   #353
Jonboy
Slots go on anything!
Gordon, Did the A/C compressor fit OK when you were done? I am using the DD mounts as well, and would llike to keep the OEM compressor. Also, where did you find the adapters for the A/C lines?
1974 Jimmy- 5.3/4L80e/NP241
Old 03-20-2012, 10:59 AM   #354
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Yes, I redid all the brake lines but kept the hard lines along the rear axle for durability.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-20-2012, 11:03 AM   #355
Gordonr1973
Home Built '87
I had to trim around the compressor line adapter a bit, its in the pictures a few months ago.
I just used all the adapters that Glock listed in his build.
Gordon
Old 03-20-2012, 11:09 AM   #356
Jonboy
That's what it looked like; but I wanted to be sure. How much trimming was involved?
Old 03-20-2012, 11:15 AM   #357
Gordonr1973
Home Built '87
I trimmed at most half an inch...not that much and I just used a Dremel to fit it in.
Gordon
Old 03-20-2012, 08:47 PM   #358
Gordonr1973
Home Built '87
And on the first day, God said "Let there be light!"
This isn't my first day, but it is the FIRST day I've had some positive progress in a while! Very thankful for that!!
Gordon
Old 03-21-2012, 01:59 PM   #359
foamypirate
foamypirate's Avatar
Nice progress! I like those brake lines!
foamypirate is offline   Reply With Quote
Old 03-21-2012, 06:46 PM   #360
GuZ
GuZ's Avatar
great build man!
very nice work. I dig the paint choice!
GuZ is offline   Reply With Quote
Old 03-21-2012, 11:40 PM   #361
Gordonr1973
Home Built '87
Thanks guys.
I re-ran the harness under the dash & trimmed my PCM to fit back there on the heater box. I stuck some velcro on both surfaces too to hold it & trimmed the glove box to be able to close.
It should work out!
Gordon
Old 03-22-2012, 06:07 AM   #362
mooseknuckles
mooseknuckles's Avatar
nice work!
mooseknuckles is offline   Reply With Quote
Old 03-22-2012, 07:30 AM   #363
rs72z
rs72z's Avatar
looking good.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-22-2012, 09:51 AM   #364
noonzor
i like it.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 03-23-2012, 12:14 AM   #365
Gordonr1973
Home Built '87
Couple more things buttoned up tonight...
Got the ashtray in & wired for an aux power to charge my cell phone.
Reran the LS harness coming in from the engine BEHIND the air ducts under the dash so there is enough room to put in the ducts.
Tested the gauges finally to check my gauge wiring harness.
Hopefully get more off the list done this weekend...
Gordon
Old 03-23-2012, 08:02 AM   #366
rs72z
rs72z's Avatar
Gauges look awsome!
___________________
78 ccsb dually
5.3
4l60e
Old 03-23-2012, 06:46 PM   #367
GuZ
GuZ's Avatar
I REALLY LIKE THOSE ULTRALIGHT II'S!
very nice man!
Old 03-24-2012, 08:31 PM   #368
Gordonr1973
Home Built '87
Thanks guys....if I had to do it over again I would probably keep my stock gauges with tach that I had and just fixed them up with new LEDs and clean it good. Maybe next time!
Today I got all the grounds done, as well as the ground straps to the chassis, cab, rad support. Will still need to do one for the box to the frame later.
I also wired up the electric fans. One fan is controlled by the PCM & temp sensor, the other I decided to hook it up to a manual switch that is powered by the key. That way I can turn (or leave) it on all the time. I just don't know how much cooling these fans will do verses the heat of the motor mods and cam.
So I will go with it like this and see for now.
Gordon
Old 03-25-2012, 05:18 PM   #369
Gordonr1973
Home Built '87
Had a short in the switch today for the fans when I tested them again, so replaced the switch and installed the new one in the dash without problems.
Also installed the Lokar 1800 shift linkage....took a little time to get the angles right but I didn't need to trim any of the stell shaft in the end, just used the adjustment screws to position it correctly.
Also replaced the tranny seal to the drive shaft & the tranny pan filter and seal...almost done my weekend to-do list & getting closer to a test fire!
Gordon
Old 03-26-2012, 09:49 AM   #370
noonzor
sweeeeeet.
Old 03-26-2012, 09:28 PM   #371
83_shortwide
Great build...
Bo
'83 C10, LQ4, 4L80E
83_shortwide is offline   Reply With Quote
Old 03-26-2012, 10:04 PM   #372
1425956
1425956's Avatar
Very nice. This is the first build thread I have read from start to current. Keep up the great work. I bought some seats and console from a salvage yard that were pulled from a Burb and they look exactly like yours. I thought mine were from a van cause of the dual arm rests on each seat, and a cut air line. Someone has welded brackets on them. You could set our seats side by side and you couldn't tell a difference. But I certainly know what you're talking about on making brackets to raise the front of them. Mine make me feel like I am going to slide right out of the seat. What were you seats out of?
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 03-27-2012, 01:15 AM   #373
Gordonr1973
Home Built '87
Thanks guys, the seats are out of a Suburban.
I bought them off a guy here in the city that had a perfect '87 SWB that had a bench seat he was going to replace but never did.
I should have bought his truck off him as he was considering selling it at the time...
Gordon
Old 03-28-2012, 09:54 PM   #374
Gordonr1973
Home Built '87
Finished putting on the auxiliary transmission cooler today and ran all the lines.
I have a tranny cooler built into the rad as well but I want to keep the tranny fluid as cool as possible with a 4L80E.
Gordon
Old 03-28-2012, 09:58 PM   #375
Gordonr1973
Home Built '87
I mounted the cooler on a piece of flat aluminum stock so I could but it on the cross brace so it would get some draft while driving.
There wasn't really any other place that seemed right to place it.
One other thing to make note of, Summit AN fittings do not fit the Koul Tool.
Gordon
