Old 06-11-2012, 09:37 PM   #351
CC69Rat
CC69Rat's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Originally Posted by VA72C10 View Post
dash looks great! was the toothpaste for the lens?
On the brakes, I think it's a win, win....I am not much help as I have the same debate because discs on the rear look great with big rims, but the modulars/bigger fronts look great also....
As far as braking performance, I really don't think you'll notice a huge upgrade with the discs on the rear....even many high dollar modern trucks use drum rears since most of the braking pressure is (and needs to be) at the front anyways....
thanks fellas (not sure how to do the multi-quote thing ..)
Yes, he said he read up on polishing plastic and found toothpaste works really well. Man, I tell you. I saw the lens this past weekend and he sent me this picture today. That's the original lens he cleaned up. What a difference.
I am really impressed with it. MAN I wish I had a TACH !
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-12-2012, 09:38 AM   #352
gcburdic
Restoration Virgin!
gcburdic's Avatar
Use this little booger...it can be found in the lower right corner of each post that you want to reply to....click on each post you want to reply to and then click "Post reply" button....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-12-2012, 10:16 AM   #353
N2TRUX
Happy to be here
N2TRUX's Avatar
CC69Rat- Your project is moving along nicely. I wanted to comment on a couple of items you mentioned. Regarding your concerns about buying CPP brakes, I would suggest purchasing them from a Forum Vendor. DO NOT buy from CPP on eBay as that is where most of the service issues stem from. There have been very few complaints on CPP products, but many on their customer service. If you buy from a stocking dealer those issues go away.
If you want rear discs and prefer them to match the front, McGaughys is the best bang for the buck. You can upgrade to 13" front and rear for about 1k less than any other brand.
If you need to multi-quote, click on the button for each post you want to quote. Once you have selected all of them then hit the button and it will multi-quote.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-12-2012, 10:22 AM   #354
67cheby
67cheby
67cheby's Avatar
now i want the Mcgauhys set up myself !! LOL, dang this board for giving me so many new ideas !
67cheby is offline   Reply With Quote
Old 06-12-2012, 10:41 AM   #355
CC69Rat
CC69Rat's Avatar
Does McGaughys offer a whole conversion 'kit' for my 70? Big brakes, similar to the CPP kit I posted? Anyone have a part number? For $1k less, absolutely I'll look at it.
I was talking to Summit Racing about it. .. the CPP kit (for the shipping advantages) and was planning to pull the trigger today at lunch.
But, I'm sure they could get the McGaughys kit too. The main thing is I just need the year appropriate center link stuff and / or sleeves to make it work on the 70 setup. My truck is power drum 6 lug now.
Chad
Old 06-12-2012, 10:52 AM   #356
CC69Rat
CC69Rat's Avatar
NM .. found it.
You guys ROCK. How about the McGaughys big brake kit on the front and rear, Hotchkis drop springs and Bilstiens from ECE? with the sways too, that should REALLY plant the ole GMC
.. and prepare for the next update .. LS anyone?
Chad
Old 06-12-2012, 01:25 PM   #357
CC69Rat
CC69Rat's Avatar
Ok. Desicion made.
McGaughys Big Brake kits. Both front and rear. Hotchkis springs.. now my question is the master cylinder and proportioning valve. I have a CPP booster I bought for my Big Block truck. It is too big. (OE style) I thought I would use it on my GMC (smallblock, short valve covers, etc.) Make sense. .
My question - Do I need a specific Disc / Disc master cylinder? I know the prop valve is disc/disc .. and what size lines would I need from the MC to the valve? I might just buy the kit with the smaller booster style and kinda swap boosters from the new kit to my BB truck .. would that work? that gives me a smaller booster to fit around the taller valve covers.
thoughts? I'm going to order it tonight. The McGaughys kit is cheaper and that's what's on my 68 too. It went on great. I'm going this route. I can do big brakes front and rear for the same money I could do just the front from CPP.
Chad
Old 06-12-2012, 06:56 PM   #358
VA72C10
VA72C10
VA72C10's Avatar
sounds like a solid plan and going to look great! The master just needs to be a disc style...as far as I know there's no difference between a disc/drum and a disc/disc master....just the prop valve as you mentioned...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-14-2012, 02:52 PM   #359
CC69Rat
CC69Rat's Avatar
Dad's at it again .. Column has been painted to match the glove box door. The door panels are off now, but that will change soon. All the wiring issues corrected, new headlight switch, etc. He's cleaning up the rear view mirror now. I'm leaving for FL tomorrow so I'm sure there will be more to post when I get back. I like it when my trucks are at Pop's place !
Chad
Old 06-14-2012, 03:12 PM   #360
shawno72
C/10 junkie
shawno72's Avatar
Ask Pop's if I can leave my truck at his place to.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-14-2012, 04:13 PM   #361
mcbassin
Still Learning
mcbassin's Avatar
me too
mcbassin is offline   Reply With Quote
Old 06-17-2012, 06:44 PM   #362
Tinkermc
this thing is starting to look really nice, Pops does nice work
Tinkermc is offline   Reply With Quote
Old 06-19-2012, 10:44 AM   #363
CC69Rat
CC69Rat's Avatar
I talked to dad on Sunday and he said he had the dash all cleaned up and waxed, the new bezel is in, he is just cleaning and detailing as he goes.
I am in Florida for the next week or so (be back Mon) and I am going to order all my drop stuff. I just have a hard time making big purchases but I really think the Mcgaughys setup would be ideal for this truck. I have a really clean set of 5 lug rallys I can run until I get some wheels.
Im trying to buy some Intro Pentias off of 'Original 71' Blue and white Cheyenne. May work out, may not.. well see.
Ill post some pictures of the dash asap. Hes fixing a canceling cam issue today I think and putting my steering wheel back on.
Chad
Old 06-19-2012, 11:43 AM   #364
shawno72
C/10 junkie
shawno72's Avatar
Sweet!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 06-19-2012, 11:46 AM   #365
superflysteiny
superflysteiny's Avatar
looks great keep up the good work
superflysteiny is offline   Reply With Quote
Old 06-19-2012, 12:35 PM   #366
shearjs
shearjs's Avatar
Your truck is looking great! Pop's is doing some good work too.
shearjs is offline   Reply With Quote
Old 06-20-2012, 11:39 AM   #367
Tinkermc
lookin good waiting 2 C brake job
Old 06-20-2012, 01:45 PM   #368
67barnfind
67barnfind's Avatar
It's amazing how projects and ideas change from page 1 to last page.. LOL.. I was looking at turning mine into a road course racer until I read your first few posts. After reading about (and seeing) how cool these trucks look bone stock, I was seriously looking at an original resto...Now, I agree with 67Cheby, this dang site has given me so many cool and different directions to take my truck... Who knows where mine will be by my "last page".. LOL !! Nice build, can't wait to see more !!
67barnfind is offline   Reply With Quote
Old 06-20-2012, 06:05 PM   #369
CC69Rat
CC69Rat's Avatar
Here's a picture of the dash, Dad has it all put back together .. I think it looks awesome
The metal plate on the floor on the pass side looks like it is covering rust, but we looked under it, around it, on the bottom of the floor pans, etc. There is no rust through or even surface rust on the top to speak of. It is 42 yr old original floor pans so nothing more than the normal crud that builds up over time .. Honestly I thought about taking it off. I'm not even sure why it's there.
Maybe the floor pans were getting hot or something? When I got it, the truck didn't have any carpet in it at all .. but I have a new molded black set that will go in on Monday. New sill plates, etc .. I think I'm just going to leave that plate on it and Dynamat / Carpet and just go with it. That plate has been there a looong time .. not sure why ?? Bizarre yes, but not a big deal to me.
Chad
Old 06-20-2012, 06:09 PM   #370
VA72C10
VA72C10
VA72C10's Avatar
Looks GREAT!!!! Way to go Pops!!!
Old 06-20-2012, 06:27 PM   #371
CC69Rat
CC69Rat's Avatar
Like the black dash pad? The 'gold' color was pretty much impossible to find. I just went with black.
Sticking with the original gold door panels, seat cover, headliner, etc. I looked back through some of the earlier posts and man it really looks better!
Chad
Old 06-20-2012, 06:35 PM   #372
VA72C10
VA72C10
VA72C10's Avatar
I think that will all look great together...the black dash pad is smart anyways IMHO with this being a driver...the lighter dash pads can cause glare...
Old 06-20-2012, 06:49 PM   #373
CC69Rat
CC69Rat's Avatar
Thanks man.. Ill post pics of the carpet once we get it in. I will likey go with 'Sandalwood' for the door panels and seat cover. Classic Industries carries both in that color. While not listed as the GMC gold color. Its the closest thing I have found so far. At that point the int is probably going to be considered done. The wood bed is really close to ready to be installed, and the drop and brakes will be here soon.
Chad
Old 06-24-2012, 07:11 PM   #374
CC69Rat
CC69Rat's Avatar
Big steps today fellas .. $$
I ordered a McGaughy's front drop / disc conversion big brake kit, rear big brake kit (both drilled) and Hotchkis spring set.
... Wow, I can't wait!
Chad
Old 06-24-2012, 07:27 PM   #375
67cheby
67cheby
67cheby's Avatar
Nice !! I have to get some bigger brakes !
