10-28-2013, 08:56 PM | #351 |
Re: DURG's Black 65 C10
Just finished getting caught up on your assume bad a** build.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-02-2013, 04:37 PM | #352 |
Not much progress but I did get the widened rear wheel tubs sand blasted today.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
11-16-2013, 08:01 PM | #353 |
Do i need to bring the camera down?? Did you ever look ito the gearvendors?
11-18-2013, 01:35 AM | #354 |
Wow you make that look like fun. Nice work on tubbing the rear wells too, cant wait to see the bed finished thanks for sharing the pics,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
01-05-2014, 01:25 PM | #355 |
It ain't much but at least I did something on the truck. I installed a Cherokee front door check with the two detent spots. Nice and smooth.
Fits: 1984 - 2001 Jeep Cherokee Front Left or Right Doors Mopar Part #55235571AB
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black Last edited by DURG; 01-05-2014 at 01:33 PM. |
01-05-2014, 02:19 PM | #356 | |
Rollin' Old Skool
Thanks for posting that! I had forgotten that's something we need to do with mine. I remember a thread talking about the Cherokee door checks a while back, but I'm not sure if it had actual part #'s. Sometime during it's life before me, my driver's door suffered the typical crease associated with the door flinging open too far.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
01-05-2014, 07:56 PM | #357 |
Nice build DURG. I'm for sure following this one to the end. I may have missed it, but what did you end up doing on the transmission? You said you had a 400 and you were thinking about going through it to make sure it was up to snuff. Are you running the 400 or something else?
01-05-2014, 08:18 PM | #358 |
I had a turbo 350 lockup tranny not a 400. I bought a new non lockup turbo 350 from TCI.
01-09-2014, 06:52 AM | #359 |
Glad to see you back on the truck, how did the rear tubs come out?
01-09-2014, 01:03 PM | #360 |
Still at body work and paint. He is spraying the underside with rubberized undercoating.
01-27-2014, 01:07 AM | #361 |
Sweet build! Is the rear sway bar from speedway engineering?
01-27-2014, 06:50 AM | #362 |
Yes it is.
01-27-2014, 06:54 AM | #363 | |
Installed the other Cherokee door check. Welded one small patch in left floorboard. I am just going to screw 1/4-20 button head bolts into the old mirror mounting holes where I took the large side view windows off. I need a second hand to hold a dolly inside to flatten out where the screws went in so a plastic washer can seal between the door and underside of the button head screw. I think I am going to use spanish oak on the bed wood. It's pretty dark.
05-18-2014, 06:20 PM | #364 |
So jealous
-Chapa 65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear. |
07-13-2014, 08:40 PM | #365 |
Actually did something on the truck today. Sandblasted the radiator support, high hump, lower fender mounts and front frame to hinge mount braces. Also painted it all black except the high hump which I have some more grinding to do on the patch for the shifter hole. Nothing worth taking pictures of. Always fun sand blasting in July.
07-13-2014, 08:47 PM | #366 |
67-72 parts collector,…
Love this truck. Always look forward to updates.
12-04-2014, 08:09 PM | #367 |
Welded in new kick panel patches. Got the new rear bumper gravel guards so the rear brackets and bumper can go on. I just bought an aftermarket stock type chrome bumper, as this truck had an accessory step and tow on it.
12-04-2014, 10:50 PM | #368 |
that's awesome, I gotta remember this for when I get to my truck. this looks a lot better than the little plastic or aluminum rivet that held mine on, until it broke at least.
12-31-2014, 12:16 AM | #369 |
Cab going back on. Slow no-tech way of doing it. Jacks, blocking etc.
http://i224.photobucket.com/albums/d...pseed0c0b7.jpg
12-31-2014, 05:06 PM | #370 |
12-31-2014, 05:07 PM | #371 |
12-31-2014, 05:26 PM | #372 |
looking looking looking good
12-31-2014, 05:29 PM | #373 |
Love It!!!!!
12-31-2014, 06:33 PM | #374 |
Very Nice!
01-01-2015, 12:32 AM | #375 |
Rollin' Old Skool
What they ^^^ said!
