Old 09-03-2015, 11:14 PM   #351
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
just make sure you leave enough clearance for the belt to pass over the inner fender. On the 5.3 with Holley brackets the belt goes over the alt pulley and down under the PS pulley and back up over the water pump so it needs some room to get past the inner fender
dwcsr is offline   Reply With Quote
Old 09-19-2015, 02:30 AM   #352
cruzinthecoast
cruzinthecoast's Avatar
Re: 1949-50 3100
Great work. I'm getting ready to install a Danforth crossmember could you tell me what year camaro tie rod ends you used.
cruzinthecoast is offline   Reply With Quote
Old 09-19-2015, 10:18 AM   #353
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
The Camaro ends are ES3238RL and need to be tapped to 9/16-18 The taper is 1.6 so check the taper on the spindle your using to make sure its the same if not you will need an insert of some sort. I'd wait to see where your tie rod ends up top or bottom before doing an insert. Either way the insert fixes the rod alignment and the correct taper.
Search google for "tie rod flip insert" and you will see a bunch of different ways to do it.
Tie rod should be as level as possible at ride height so you don't get a wander left or right when you hit a bump (bump steer)
Old 09-20-2015, 12:08 AM   #354
cruzinthecoast
Re: 1949-50 3100
Thank you so much for the great info
Old 11-10-2015, 10:07 PM   #355
AZDavid
Re: 1949-50 3100
Dave absolutely phenomenal job on this truck! I hope my 48/3600 comes out half as nice. I am also using Scott's cross member so I was very interested in how this turned out. I used a set of Belltech 2" drop spindles and the 96' Camaro rack I had intended to use is too long. Center to center on my spindles is +- 47". I saw some shortened Mustang II racks on Flaming River's website but I really don't want to spend ~$400 for a new rack. Any suggestions on a rack?
Thanks Dave
AZDavid is offline   Reply With Quote
Old 11-11-2015, 12:28 AM   #356
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We used a Mark 8 rack on the final version but the customer complained it was way to sensitive ( 2.5 turn)so we have a 1988 FORD THUNDERBIRD 5.0L 302cid V8
ATSCO 6406 ( 3 turn) Rack and Pinion Complete Unit $ 72.79 unit from rock auto that's suppose to cure that. We plan on installing in the next two weeks so I'll let you know
Old 11-11-2015, 10:09 AM   #357
Coach529
Coach529's Avatar
Re: 1949-50 3100
Thanks for the info Dave.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 11-11-2015, 02:21 PM   #358
ptc
ptc's Avatar
Re: 1949-50 3100
Nice build- lots of great info in this thread.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 11-11-2015, 02:28 PM   #359
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Thanks it was an interesting build, its nice to be able to stretch and grow your talents on builds like this instead of a stock restoration. Its also nice to see my helper grow his talents from the beginning to the end of this build.
Old 11-11-2015, 09:18 PM   #360
AZDavid
Re: 1949-50 3100
Thanks Dave I'll be looking forward to hear how the Thuderbird Rack works out.
Old 11-12-2015, 12:33 PM   #361
Coach529
Coach529's Avatar
Re: 1949-50 3100
Same here..........
1949 Chevy 3600
Old 12-02-2015, 11:34 PM   #362
Donnie Lee
Re: 1949-50 3100
Fantastic build, my son has '50 model needing front ifs, I like Scott's crossmember as well, wish you were in N.C. so we could let you install one for us.
I've got a couple questions, in your post #138 you wire brush & sprayed Ospho, install a couple of braces & the boxing plates, how did you prime/paint inside behind the boxing plate, & what gauge is the boxing plate?
Thank You
I
Donnie Lee is offline   Reply With Quote
Old 12-02-2015, 11:51 PM   #363
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
The Ospho converts the metal very top layer to an oxide so painting isn't really necessary. The paint would all burn off during welding anyway and probably collect water and dirt to start the rust process. We have used a long wand bug sprayer with Ospho to get into small tight areas such as that. The plates were 10 gage (.102" Cold rolled steel).
Old 12-03-2015, 12:05 AM   #364
Donnie Lee
Re: 1949-50 3100
I thought about the weld burnoff 30 seconds after I posted the question, ten ga. plate will definitely do the job.
Old 12-03-2015, 10:54 AM   #365
Elder Rogue
Elder Rogue's Avatar
Re: 1949-50 3100
Any updates on this?
Been watching this closely as I have a the same cross-member for my trunk.
Elder Rogue is offline   Reply With Quote
Old 12-03-2015, 11:39 AM   #366
kameltoes2015
Re: 1949-50 3100
I will be bringing my '49 to you guys to work your magic...cant wait
kameltoes2015 is offline   Reply With Quote
Old 12-03-2015, 01:23 PM   #367
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Not yet, the customer has not been able to get it back to us. A lot of our customers work out of state or country for extended periods of time per year so fixes are some times slow. As soon as he's in town I'll get the new rack in it and report back.
Old 12-03-2015, 03:45 PM   #368
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We have you penciled in on the job board.
Old 12-03-2015, 08:35 PM   #369
918733
Re: 1949-50 3100
Dave does awesome work I can vouch for that
918733 is offline   Reply With Quote
Old 12-03-2015, 09:01 PM   #370
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Have you made any progress on yours?
Old 01-05-2016, 11:00 PM   #371
Cautrell05
Re: 1949-50 3100
What steering gear did you finally settle with and how was the turning radius?
Nick
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 01-05-2016, 11:22 PM   #372
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Nick
We have a ATSCO 6406 ( 3 turn) Rack and Pinion Complete Unit to put in it when it come back to us. for a Mark 8
Old 02-02-2016, 12:20 PM   #373
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Last update. We finally got the truck back in and changed the rack. Major difference, its not twitchy any more so a 3 turn rack is what's needed on this swap. I'm really happy with this swap now that its figured out. You wouldn't think a half turn makes that much difference but it does. The ford 3 turn is the NON sport steering. 2.5 turn is sport steering
Old 02-02-2016, 12:23 PM   #374
Elder Rogue
Re: 1949-50 3100
Thanks for updating us. I had already decided to use the same rack but this confirms my decision.
Old 02-02-2016, 12:31 PM   #375
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I think you'll be happy with the results.
FYI our setup is
The 3 turn Ford rack
Type II Power steering pump with the Borgeson pressure reducer.
If you use a type 1 (old style) you need the reducer for that pump.
