Old 03-08-2020, 10:11 PM   #351
sprint_9
sprint_9's Avatar
Re: sprint_9's 72 C10 Project
Thanks.
I switched to the dual 9 inch, previously I had a rebuilt single 11 inch, or whatever stock was.
I went for a quick test drive today and the dual 9 inch is an improvement over the stock replacement I had. Im still not sure Im where I want to be with my brakes yet though, they just dont impress me like I feel they should. Im probably going to try new pads and see if that makes a difference.
sprint_9 is offline   Reply With Quote
Old 03-12-2020, 09:24 AM   #352
Kronald_70GMC
Kronald_70GMC's Avatar
Wow what an incredible build. Great work!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 03-13-2020, 05:42 PM   #353
sprint_9
sprint_9's Avatar
Thank you.
Old 03-16-2020, 05:00 AM   #354
my kids toy
What did you use to keep the tailgate letters flat that you cut out for paint ?
my kids toy is offline   Reply With Quote
Old 03-16-2020, 12:10 PM   #355
sprint_9
sprint_9's Avatar
I used Avery Dennison 100-235-S High Bake Yellow Paint Mask. I bought it here
I got the high temp stuff as I needed it for a future project too. They sell a standard temp that's a few dollars cheaper.
Old 04-01-2020, 04:16 AM   #356
my kids toy
What did you do to get the tailgate letters so nice, how did you trace it and keep it down when you went to paint the blue ?
Old 04-01-2020, 06:11 PM   #357
sprint_9
sprint_9's Avatar
My process for the letters started by tracing out each letter individually using the tailgate as a template. I used paint masking paper. I held the paper down with one finger in the center of the letter and used free fingers to help hold down any other corners. I traced around the outside with a pencil in the other hand making sure to push the paper down and into the letter recess with light pressure. The paint mask I had was real lightweight and worked really good as a tracing paper.
Once I had it traced in paper I cut it out and then taped it to the Avery Paint Mask and traced it with a Sharpe. Once traced with a Sharpe I removed the paper mask and cut out the letter. All cutting was with a scissors, I used an xacto knife were needed on inside corners. The Avery Paint Mask is adhesive backed, its like vinyl lettering so you just stick it on like a sticker. I sprayed the black for the letter color and let it flash a couple hours, then I just peeled the backing off of the letters I cut out of the Avery Mask and stuck them in place. From there I sprayed the entire tailgate blue, let it flash, carefully pulled the letter mask off and cleared.
Old 04-01-2020, 06:28 PM   #358
MDPotter
MDPotter's Avatar
You did a fantastic job on those letters sprint.
I thought about doing this, but on a GMC tailgate the letters are actually not raised, but the area around them is recessed. So I would have to just spray that recessed area black and then everything else blue. That or just apply stickers to the letters I guess, but that's not ideal.
I could just do the letters in black, but that might look weird and it wouldn't look original either.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 04-01-2020, 07:32 PM   #359
sprint_9
sprint_9's Avatar
Thank you, they turned out way better than I thought they would have when I started, lol.
On your's I think it would be awesome to do the recessed area black, and anything raised like your lettering or the rest of the tailgate blue. The blues that we have just really work with black I think.
http://67-72chevytrucks.com/vboard/s...d.php?t=432657
Old 04-02-2020, 09:14 AM   #360
MDPotter
MDPotter's Avatar
I could make a stencil to cover the entire recessed area. How sticky is that masking? I have visions of laying it down, pulling it up, laying it down, pulling it up before getting it positioned correctly and pulling up paint in the process. It would be a big stencil.
Old 04-02-2020, 01:13 PM   #361
sprint_9
sprint_9's Avatar
Its tacky but it releases nice and even so it's not bad to work with.
Old 06-27-2020, 11:45 PM   #362
JoeKan
JoeKan's Avatar
Very good work spring_9, love seeing good craftsmanship
JoeKan is offline   Reply With Quote
Old 06-28-2020, 02:51 PM   #363
sprint_9
sprint_9's Avatar
Thanks.
I haven't updated in a while but Ive been working on various issues when I get time. Lately Ive been a little more focused on trying to make some ground on some long standing problems. The first and big project I undertook was changing the transmission, while it was out I worked on an oil leak which so far seems to also be fixed. The transmission was changed due to a compatibility issue, I also had to change some of the wiring harness. My main engine harness was rubbing on a sharp corner of the head, I had a friend 3d print a bracket for me which turned out great. A couple pictures of the rendering and installed below. The swap was a big project but nothing too terrible. It was a great change as all my issues were fixed and I took the opportunity to change to an aftermarket torque converter while it was out. I think it is around a 2400 stall now, that has been a great upgrade.
A couple other things Ive been working on are the brakes, mainly brake pads. Im trying to find something thats quiet and doesn't dust alot. The stock Wilwood pads quite frankly were terrible, they dusted a ton and didnt really bite. I then tried a set of Wagner Thermo Quiets and they were a big improvement but squeaked and chirped about all the time. Currently Im on a set of Bosch ceramics and they seem to check all the boxes so far.
I started and finished one side of my power lock redo. I took some inspiration from TA_C10 and switched it just a little bit. I ended up threading 3/16 rod and holding it together with some 10-24 nuts. Switching to the other side of the pivot is a big improvement. Im going to go out and work on the drivers side in a bit. Ill be really happy to have this one checked off the list.
Ive been working on my cruise control, Im running the Dakota Digital CRC-2000. I couldnt get it to engage, I found and fixed a 12v power issue with it. It now engages but goes about wide open throttle immediately after being set, so its a major safety hazard Ive got to try and figure out. I assume something with the VSS signal is off, but really have no idea. I pulled the fuse on it for now.
In between cruising sessions I make an occasional tuning change, the focus as of late is deceleration idle. Its getting better but Ive got a ways to go yet and usually do more cruising than tuning for the time being.
Old 06-28-2020, 03:07 PM   #364
sprint_9
sprint_9's Avatar
During one of my cruises a few weeks ago I stopped and got a bunch of pictures. I wanted some of it fairly complete on the outside since all I had were pictures without the tailgate on.
Old 06-28-2020, 03:15 PM   #365
sprint_9
sprint_9's Avatar
One more tailgate shot, the tailgate is probably one of my favorite pieces on the truck.
Old 06-29-2020, 10:57 AM   #366
Snake72
Snake72's Avatar
The fit and finish of that truck is exceptional...love the tailgate lettering. I think I know that body of water too...
Snake72 is offline   Reply With Quote
Old 06-29-2020, 11:18 AM   #367
KMC3420
KMC3420's Avatar
This shot just speaks to me! I love the look, and the tailgate lettering could not look better.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 06-29-2020, 11:34 AM   #368
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Such a great job with this build. You should be very proud of you work. Hope it is as fun to drive as it looks. Super clean truck.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-29-2020, 11:42 AM   #369
Kronald_70GMC
The truck looks excellent! Loving the blue
Kyle
IG: kyle_ronald
Old 06-29-2020, 11:46 AM   #370
TA_C10
TA_C10's Avatar
The truck looks amazing man. You did a great job on your truck. Well done sir.
I'm glad changing the pivot point on your locks worked out for you. It took me an hour of thinking about that, and the parts laying on the table just staring at them lol. But man, locks have NO trouble now.
Sooooo, I didn't see a pic of your pedal assembly on the LS. Are you using DBW or DBC? I will assume DBC since your using a DD cruise unit? I'm getting really close to jacking up my rear wheels and connecting the 4 wires for cruise to my steering column and testing. The DBW makes cruise soooo easy... Hope you get yours figured out.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 06-30-2020, 11:54 AM   #371
sprint_9
sprint_9's Avatar
Thanks guys.
I usually have a good time with it when I have it out, one of these times will try to get a short video. The exhaust is alot of fun.
My throttle is DBW, but its gen 4 so normally the BCM deals with the signal to set the cruise. The Dakota box is taking over this duty as I'm not running a BCM. I emailed them and they have a couple things for me to double check so I will look into it more this weekend probably.
Old 08-03-2020, 08:15 PM   #372
1972CST
1972CST's Avatar
Just read through your build and all I can say is WOW, what skill and craftsmanship!
How are you liking the low mount a/c compressor?
Which bracket and compressor are you running?
1972CST is offline   Reply With Quote
Old 08-03-2020, 09:50 PM   #373
sprint_9
sprint_9's Avatar
Thanks.
I had a long weekend working on my truck so a nice comment is great to see. I spent some time working various things and nothing really went right, one of those deals where no matter what you touch it just turns to crap.
As far as the mount and compressor I really like both, but haven't gotten around to charging the system to actually put it to a test. It should work good since its very similar to a stock type mount and belt setup. For a bracket Im using a Holley bracket, PART# 20-159. The compressor is a Vintage Air Sanden SD7, PART# 04670-MTA. I have some more detailed pictures in this thread. I did have to make a small modification for it to fit and that is also in the thread.
Old 08-05-2020, 09:08 AM   #374
1972CST
1972CST's Avatar
Thanks for the info and the links!
Keep up the good work, you really have something to be proud of!
Just remember, if it was easy, anyone could do it.
Old 08-05-2020, 12:59 PM   #375
sprint_9
sprint_9's Avatar
Thanks, If you or anyone else for that matter have any more questions feel free to ask.
