03-08-2018, 10:11 PM | #351 |
Vintage 4x4s
Re: 1971 K20- project just get driveable!!
Been busy fixing snowmobile, chainsaw, plowing snow, fixing a UTV. Here is a pic of gage cluster installed, works great and its nice to have confidence and numbered readouts! I know its not for the purists but I have other trucks for the purist in me. Sometimes you just have to modify things to have fun. Now I need to figure out why the cluster lights and fuel gauge aren't working. Seemed to be a problem with the old cluster too so it must be in the truck.
Also here is preview of the upcoming tcase rebuild and 7 speed conversion Thank you New Process Gear Co for coming up with a good product and not changing it between 1970 Chevy and 1993 Dodge applications This is off a Cummins fronted np205 but it bolts right up since the shafts are the same.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
03-18-2018, 06:12 PM | #352 |
GEARHEAD
Is that a gear vendors overdrive? What transmission are you going with?
On the dash lights, might be the headlight switch. They get touchy over time. Mine has been glitchy and I know it's in that switch.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
04-08-2018, 11:33 PM | #353 | |
Vintage 4x4s
As for the electrical issues, I replaced the switch with another one I had here and there was no change
06-13-2018, 07:54 PM | #354 |
Vintage 4x4s
Update, been driving the truck some on weekends for a few weeks now. Still need to get dash lights fixed but other than that its running really good. It rides pretty good with the skyjacker softride setup and these goodyear 17 inch tires I had laying around. It gets a lot of looks and people comment on it being neat and how they want one. Here are some pics.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 06-13-2018 at 07:59 PM. |
06-13-2018, 08:56 PM | #355 |
Proprietor of Dale's Corner
That's looking pretty good compared to what you brought home.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-13-2018, 11:12 PM | #356 |
Carpe manana
Looks great Jud. Thanks for posting.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-03-2019, 02:29 PM | #357 |
Vintage 4x4s
Well I finally got more than 2 days off in a row without a ton of commitments, so I worked on the truck a little.
I rebuilt the old front driveshaft that was clanking in 4wd. I rebuilt the cardan assembly with 2 new Ujoints and a new centering ball setup. I used a little press and it was not as hard as I thought it would be. Hardest part is reinstalling or removing the shaft thanks to the ridiculous backwards bolts on the transfer case output yoke. Thankfully it wasn't too hard to pull the seat and high hump out to get access from in the cab. I also put the old 235/85/16's back on for driveway plow truck duty. Runs really smooth now. I didn't balance the front driveshaft but probably don't need to since i don't use 4wd on the road. This is only on the roads in the summer and my personal driveway and acreage in the winter.
01-04-2019, 12:26 PM | #358 |
I hate that backwards flange !!! Of course I didn’t think about removal of the seat and high hump.. 🙄
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
