11-28-2015, 08:52 PM | #351 |
Re: 53 Surburban "Family Truckster"
Are your front bag mounts upside down? Looks good, subscribed
11-28-2015, 09:23 PM | #352 |
67-72 parts collector,
I think they are upside down and on the wrong sides.
Following this killer build,...
11-28-2015, 11:33 PM | #353 | |
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-29-2015, 11:10 AM | #354 |
Marc, frame is looking great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-29-2015, 08:31 PM | #355 |
A320 Pilot/USAF Retired
Those PorterBuilt welds are nice!!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
11-29-2015, 09:44 PM | #356 |
Thanks Jim..
Yes, they really are. Marc
11-29-2015, 10:04 PM | #357 |
Well, I got back at it this afternoon. I spent a great deal of time re-doing some things. I flipped over my top bag mounts. Upon mounting the rear notch I realized/confirmed that my passenger side front PB frame rail needed to move forward about 1/4".
After I got that squared away I moved to the back. I clearance for the bolts of the notch. It fought me when I tried sliding the notch over the frame. I figured out I had the notch backwards. You might laugh, but it is somewhat easy to screw up. Once I figured it out it fell right in, but I fought it for 30-45 minutes first...ha ha. Porterbuilt also does something neat to try to eliminate this type of mistake. They put a small notch in the front of each part. I took a picture of one of the notches to you can see what I'm referring to. I looked at this notch and thought no, I have it right...I was wrong. The good news was by the end of the evening, I mounted both notches as well as the bridge. All that is left is to drill some holes and cut out the old frame....on to the pics. I should mention that these photos were after a massive garage floor cleanup. I had all sorts of metal shavings and grinder dust.
11-29-2015, 11:20 PM | #358 |
Do you know when PB Fab will start releasing these kits to the general public?
11-30-2015, 01:02 PM | #359 |
Looks great...Nice work Marc.
11-30-2015, 04:44 PM | #360 |
That is going to be one sweet burb.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-30-2015, 10:51 PM | #361 |
[quote=84blaze;7393282]Do you know when PB Fab will start releasing these kits to the general public?[/QUOTE
I would say soon. Give Nate at Porterbuilt a call and ask. Thank you...di you get yours yet? I hope so. it's nice to finally see some progress on it. Marc
12-01-2015, 12:29 PM | #362 |
Looking pretty nice! - are you planning on welding everything up to the frame after its all figured out? I would think that would be better for strength overall.
My Build: 57 Chevy Pro-Street |
12-01-2015, 04:44 PM | #363 |
[quote=youngrodder;7394625] ... Still waiting
12-01-2015, 11:30 PM | #364 | |
[quote=69CST-V;7395374]I bet yours is close. Marc
12-02-2015, 06:19 PM | #365 |
Just a Question: If all your using of the original frame is the straight center part why not build the whole thing new.?
12-02-2015, 11:02 PM | #366 | |
Again there is a bunch of different ways to go about it. This is the route I chose since I don't have experience setting up a chassis from scratch. I would rather pay PB for their engineering...ha ha Marc
12-03-2015, 10:49 AM | #367 |
You are right on that Marc!
If the frame is not broke don't fix it kinda thing, simply box in the remaining portion of the frame and will be way stronger than O.E. Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-03-2015, 08:57 PM | #368 | |
12-04-2015, 12:35 AM | #369 |
Maybe I missed it, but what truck suspension goes on the PB kits? I assume its C10 stuff. Also, did you order everything including arms, rack and shocks from them? Or are you going to source those parts later?
12-04-2015, 09:52 AM | #370 | |
I will have more pics of the a-arms and other components soon. I'm getting ready to cut some rivits from the factory center support and bold in the new PB one. This center section is very nice look part (as is the case with all of the PB parts). Marc
12-04-2015, 09:58 AM | #371 |
I have spent the last few day fine tuning and confirming my rear dimensions. Nate at PB has been great to send me all sorts of cad drawings to make sure that I was spot on with my measurements. Keep in mind that this is first Suburban frame, so we need to make sure that there are no major differences. SO far so good.
I'm getting ready to drill the remaining holes for the rear notch and add the other support pieces. Then I will turn my attention to the factory support center section to get the rest of the rivits cut out in order to install the PB center support. I plan to get out in the garage this weekend. Marc
12-04-2015, 10:24 AM | #372 |
Looking good Marc, bet your getting all sorts of Excited now!
12-04-2015, 02:30 PM | #373 |
Nate sure provides outstanding customer service in addition to his high quality parts.
Marc, the only difference I've noticed between the Suburban and truck frames was the body mount outside the frame by the rear running board bracket that you had a picture. There might be others. My chassis was built from a truck frame so I just transferred that mount. |
12-04-2015, 09:22 PM | #374 |
looking good... I assume this will be able to drag the running boards if you want?
Have you decided on size of wheels? |
12-05-2015, 12:28 AM | #375 | ||
Thanks Mark, it just feels good to be making progress and have some actual pictures to flood my build thread with. Marc
