Closed Thread
Old 03-13-2014, 03:15 PM   #351
Lees68GMC
Lees68GMC's Avatar
Re: What did you do to your truck today? Chapter II
Ready to Start for first time just waiting on the 'puter, any day now
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 03-13-2014, 06:19 PM   #352
myyamr7
myyamr7's Avatar
Originally Posted by Tom Vogel View Post
Post a vid of that start up!
Too much to think about during the initial start up, but I did take a short vid during the 25 minute break-in period.
https://www.youtube.com/watch?v=LRb6BktWUzc
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline
Old 03-13-2014, 09:47 PM   #353
Lanman1972
Lanman1972's Avatar
Ordered the fabric and vinyl to get the seat redone, SMS Fabric carries the orange plaid and scroll work on the vinyl. This pic makes the seat look better than it is, drivers side is mostly gone.
Lanman1972 is offline
Old 03-13-2014, 10:18 PM   #354
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Clean install. Very nice.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-13-2014, 10:46 PM   #355
texjake
texjake's Avatar
I installed my LED bulbs today. Its not as bright as I thought it was going to be, but its a lot better than the old dim yellow/green that it use to be. Plus a camera phone is not the best for night pics. It does look better in person. I also painted both inside gauge cluster panels gloss white to try to help brighten up the lights inside the panel. I know if I would have used the multi directional LED's it would look better. I still need to do some tweaking on it & check to see if all the bulbs are working ok. But for now this will work. I got 20 LED's on eBay for $15 + free shipping. So I'm happy with it.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 03-13-2014, 10:52 PM   #356
TrkEnvy
I have done a few of those.. get yourself some HVAC duct tape. the shiny kind that they wrap the actual ducting with. makes for a great reflector. line the inner walls with it and the light will passed around the inside the cluster much better. looks good though
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline
Old 03-13-2014, 11:54 PM   #357
texjake
texjake's Avatar
Ok cool, thanks TrkEnvy. I'll try that duct tape thingy later.
texjake is offline
Old 03-14-2014, 12:13 AM   #358
magwakeenercew2jh
Putting the lights in my dash was probably the most fun, cheapest, and easiest mod I made on the whole truck.....And I don't even drive much at night.
Go figure!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-14-2014, 12:21 AM   #359
BlacklandCamper
Now that it runs, and more importantly, will idle on its own, I decided to address the brakes today. Got everything torn down on the front, swung by my store to turn my rotors, and pick up some parts, got home, and had enough time to stage everything for tomorrow. Got distracted with a mice issue.
More progress is being made, just a bit more before I can drive it to work, and shake out any bugs that appear.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 03-14-2014, 01:03 AM   #360
texjake
texjake's Avatar
Go figure!
Which LED bulbs did you use? And did you paint the inside of the cluster panel gloss white?
texjake is offline
Old 03-14-2014, 01:14 AM   #361
magwakeenercew2jh
Not necessarily this seller. But here are the bulbs:
http://tinyurl.com/o5bawcu
The gauge color is made up of those white stickers, http://tinyurl.com/mczwa3r
and I did paint the inside of the cluster panel gloss white.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-14-2014, 02:36 AM   #362
texjake
texjake's Avatar
Thanks magwakeenercew2jh. Those white face gauges really makes a difference.
texjake is offline
Old 03-14-2014, 03:20 PM   #363
magwakeenercew2jh
I like 'em. Thanks.
I'm still far*&%g around in the garage with the (extra) motor parts.
Whatever gets built, I'm gonna need a water pump unless I steal the shiny one off of the already running motor that's in the truck now.
Anybody had any experience with the electric ones? If so...good/bad/ugly, what brand?
Next, all I need is a trip to the machine shop, timing gears, revolving assembly, cam, lifters, gaskets, push rods, pan, oil pump.....etc.,
etc., etc....aieeeee!!!!!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-14-2014, 08:40 PM   #364
BlacklandCamper
Finished the front brakes, was going to move on to the rears, but managed to tweak my ribs putting the front wheels back on, and decided the rears could wait. Instead I figured I would see if the radiator from my donor GMC would fit, but I learned that the radiator is too tall to work. Guessing they got taller during the late '80s. Oh well. Put the usable old radiator back in, and need upper and lower hoses, along with a thermostat and gasket.
So...
Hoses, thermostat, coolant, then exhaust flange gaskets, new pipe and mufflers (in hand, just need to be welded up), then rebuild wheel cylinders, bleed brakes, add trans fluid, vac tune carb, and take it on its first drive in almost a decade.
With rain on the forecast, I may not get much done tomorrow, and I work Sunday, so hopefully the weather clears on my days off next week, and I can get as much done as possible.
Old 03-14-2014, 09:52 PM   #365
In The Ten Ring
Made arrangements to buy another part I don't really need but really, really want! Brush guards!
In The Ten Ring is offline
Old 03-15-2014, 06:47 PM   #366
Mike_The_Grad
Mike_The_Grad's Avatar
Preview... need to replace more bolts. I.e. torque converter bolts, trans to block bolts, fly wheel bolts. Also new chrome water pump shaft output is different from factory, so my existing pulleys are out of alignment...hmm. guess I need to get new ones...
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 03-15-2014, 06:58 PM   #367
Econman
Econman's Avatar
I started putting the bottom end of my engine together today.. After waiting forever on the machine shop, I finally get the crank in and torqued down just to find that the crank has .020" of end play.. There just aren't any machine shops worth their weight in sand in this town anymore.. Ugghhhhhhh!
Econman is offline
Old 03-15-2014, 08:46 PM   #368
Mike_The_Grad
Just got my package from member tkorinek, Thanx again by the way. This should keep me busy for a while...
Old 03-15-2014, 09:31 PM   #369
C10Calvin
C10Calvin's Avatar
Over the last couple days I've replaced upper and lower ball joints, lower A-arm shaft and cut 1 coil off my front springs. Also installed some parts I got from specialtyretail, he always has the parts I need, 4" rear drop springs and adjustable trac bar. Here is a pic before the drop.
C10Calvin is offline
Old 03-15-2014, 09:33 PM   #370
C10Calvin
C10Calvin's Avatar
Here is pic just after I dropped it down off the jack.
Old 03-15-2014, 10:57 PM   #371
texjake
texjake's Avatar
Was in the process of repainting the steering column & putting a smaller steering wheel on when I found out that the upper bearing was in need of some attention so I cleaned everything real good and repacked the bearing full of grease. It's a hard to find item, not located at any local auto parts store so I just repacked it & it all seems to be ok. I also checked the fiber optic cable leading to the shift indicator & it's working great.
texjake is offline
Old 03-15-2014, 11:57 PM   #372
Motoxrrar
New seats and center console mounted, new carpet kit! Got some door panels to put on soon!!
72 GMC Sierra Grande.
Motoxrrar is offline
Old 03-16-2014, 12:44 AM   #373
magwakeenercew2jh
Too nice not to flip.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-16-2014, 12:51 AM   #374
Motoxrrar
Haha thanks they came out of a 2011 2500 they are so comfy!! Here is another look with the console down! I was so amazed how easy they were to fit in just using the factory mounts.
Old 03-16-2014, 01:03 AM   #375
Grumpus Monkus
Nothing to exciting, just got the old motor mounts out. If all works out well tomorrow, pressure wash engine bay, continue sanding and painting.
Our very slow build page:
http://67-72chevytrucks.com/vboard/s...d.php?t=618078
1981 C20 350ci TH350 LWB Edelbrock Carb
Grumpus Monkus is offline
Closed Thread
