Old 02-07-2021, 12:45 PM   #351
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Thanks 88 Stanger.
I may have a line on new 200R4 sheet-metal torque converter dust covers. I'll find out for sure Monday. Nobody has those.
Wiring up the engine compartment now.
Old 02-07-2021, 02:54 PM   #352
MT65
Thumbs up Re: New 64 Stepper Project
Originally Posted by The Rocknrod View Post
Speaking of hands, ow.
Installed all by myself.
That carb mount engine installation tool works great for a one man show, am I correct...
MT65 is offline   Reply With Quote
Old 02-07-2021, 05:40 PM   #353
The Rocknrod
Moderator
I think so. You have to mount the lift arm super close to the tool for it to work without removing the hood.
Old 02-08-2021, 09:33 AM   #354
SCOTI
SCOTI's Avatar
Thanks 88 Stanger.
Be sure to share if you find something.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2021, 05:57 PM   #355
The Rocknrod
Moderator
May not look like I've done mush but it's tedious work. Yesterday and today.
Old 02-09-2021, 06:04 PM   #356
roll_the_dice
roll_the_dice's Avatar
Looks really good...tedious is right getting all the looms how you want them!
roll_the_dice is offline   Reply With Quote
Old 02-10-2021, 02:56 PM   #357
88Stanger
88Stanger's Avatar
Is that Fi-Tech i see? I have the Blow thru kit, 600hp. i had it for my motor previously then decided to go with LS - this was in my 1969 C10.
But for the 1966 C10 i rebuilt my 383 motor and added some goodies and going to run the fi-tech on it. I have a mechanic buddy who is a die hard fi-tech guy so i have a good helping hand if i need it.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 02-10-2021, 04:33 PM   #358
The Rocknrod
Moderator
Street Demon.
Old 02-11-2021, 05:27 AM   #359
justa dumb hick
justa dumb hick's Avatar
Nice! I would venture to say inspiring. Perhaps you could share details on your ignition system?
-JDH
Insomnia is a terrible thing to waste
https://www.youtube.com/watch?v=jWYVs7widI0
(Misanthropic curmudgeon attempts starting old truck in house at 2AM)
justa dumb hick is offline   Reply With Quote
Old 02-11-2021, 07:31 AM   #360
The Rocknrod
Moderator
40,000V Coil, Small Body HEI. Nothing fancy.
Old 02-11-2021, 11:09 AM   #361
88Stanger
88Stanger's Avatar
Street Demon.
Oh ok, i see now. It was hard to tell from the pic, looks just like my fi-tech. The Demon should work great, i like them.
Motor work looks fantastic sir! very nice work... Give me inspiration to get my butt in gear and get mine done.
Old 02-11-2021, 12:50 PM   #362
Hammered 77
Hammered 77's Avatar
Looking good, what valve covers are you running?
Hammered 77 is offline   Reply With Quote
Old 02-11-2021, 06:14 PM   #363
The Rocknrod
Moderator
I think there from CFR? Chrome Aluminum Finned.
Old 02-11-2021, 06:26 PM   #364
The Rocknrod
Moderator
Okay, I worked for two days trying to get the TV Cable/Bracket geometry correct for the Extreme Automatics 200R4. I was finally successful and it is repeatable. I had an old bracket from the cruise control to work with. I don't think I'll be removing it to get it plated or powder-coated. I must have gotten under that truck checking the plunger depth thirty times today. All the while remembering my old Chief saying "you gonna let this Sh%t kick your a$%?"
Looks like hammered cat sh#t but it works.
Old 02-11-2021, 08:00 PM   #365
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks fine, but I would take it off to at least rattle can it. If you leave it alone, it will rust and look worse against all your polished & chrome goodies..
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-11-2021, 08:23 PM   #366
The Rocknrod
Moderator
My plan is to get in there with a Testors paint brush in the morning.
Old 02-11-2021, 09:27 PM   #367
MT65
Happy to see you check plunger depth, its not a fun ordeal, but you should enjoy the outcome......nice build....
Old 02-11-2021, 10:12 PM   #368
The Rocknrod
Moderator
Thank you.
It's kind of a requirement according to Extreme. I do understand why though.
Old 02-12-2021, 11:38 AM   #369
The Rocknrod
Moderator
Okay you shamed me into it. This AM I went in and removed the bracket, trimmed it up then wire wheeled it and painted it. Replacing the fasteners with stainless button heads. News at 11.
Old 02-12-2021, 11:44 AM   #370
88Stanger
88Stanger's Avatar
There ya go!! Way to not let that thing beat you, or give in to peer pressure... lol Looks good!!
Old 02-12-2021, 04:10 PM   #371
The Rocknrod
Moderator
Got the trans dust cover pan in today. There was an ear on the starter side that needed to be flattened down, not sure why it was there. One of the holes elongated when installing. Not a perfect piece but then again, there is nothing else out there for the 200-4R. Off to the powder coater it went with the PML Trans Pan. So the Oil Pan Dust Cover and Trans Pan will match.
Old 02-13-2021, 08:51 AM   #372
The Rocknrod
Moderator
Got the distributor ends of the plug wires terminated.
Old 02-13-2021, 03:26 PM   #373
SCOTI
SCOTI's Avatar
What's the 411 on the Demon set-up? Are they square bore or spread? Any other specifics?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-13-2021, 05:31 PM   #374
The Rocknrod
Moderator
Square bore, so the right intake pattern is used. - https://www.holley.com/products/fuel...eet/parts/1900
Old 02-14-2021, 04:18 PM   #375
The Rocknrod
Moderator
More work today, still working on the details but you get the idea.
