09-08-2016, 11:59 AM | #351 | |
Re: 85 GMC Sierra "Scarlett"
Ken, here is the stuff I was talking about. It may not be the finish you already have started but maybe in the future it will work. DEI Header Wrap Paint
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
09-09-2016, 12:04 AM | #352 | |
Happy to be here
09-09-2016, 12:10 AM | #353 |
Happy to be here
This evening I put the finishing touches on the front end. I installed new park lamps lenses that I picked up from Outback Truck parts, and topped the grill off with the GMC letters I restored.
I double checked all the connections and ran the ground wire to the core support. We still need to fine tune the bumper fitment but it's done for the moment.
09-09-2016, 12:27 AM | #354 |
Did you ever find this information?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
09-09-2016, 12:31 AM | #355 | |
09-11-2016, 08:04 AM | #356 |
Happy to be here
With the front end finished I had a feeling of accomplishment that may have led to a foolish decision. I had been accumulating parts for the interior and decided to start the restoration process. Did you know you can bite off a whole lot more than you can chew in less than an hour? Trust me on this, you can.
I stepped back and looked at the pile of dull and faded parts I had removed and the voice of Dr. Phil popped in my head "What we're you thinking? " Well, it seemed like a good idea at the time.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-12-2016 at 09:47 AM. |
09-11-2016, 08:13 AM | #357 |
Happy to be here
The interior pieces have been dyed twice and the top layer was fading and chipping. I just couldn't bring myself to install the new dash components on a dash that looked pinkish.
I went by the local Auto paint store and ordered up some SEM vinyl dye and Bulldog adhesion promoter. For reference, we found the best match to be SEM Napa Red. They offered to color match in PPG dye, but I felt the SEM spray was close enough and it would be available in time for me to use it this weekend.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-12-2016 at 09:48 AM. |
09-11-2016, 08:17 AM | #358 |
Happy to be here
Friday night I worked late and got most of the parts stripped. I used lacquer thinner with Scotch Brite and gently scrubbed the layers of old dye away. The process was tedious but the results were a pile of raw parts that should look much better in the end.
09-11-2016, 08:26 AM | #359 |
Happy to be here
Saturday morning Chris and I had errands to run that couldn't wait and ended up working service calls most of the day. I had a short amount of time in the shop before attending a family function so I washed the parts in preparation for dye. I have found the key to proper adhesion is clean,clean,clean the parts. I scrubbed them with Dawn soap and rinsed, washed and repeated till clean.
The headliner trim pieces are metal, so they were stripped raw then bead blasted. I followed up with a couple of coats of VHT primer. Ithis layed down nicely and will give a good base for the dye.
09-11-2016, 08:46 AM | #360 |
Happy to be here
Unfortunately my plans of spraying the parts after dinner were shot down by the weather.It rained then quit and left the air very humid. I didn't feel comfortable spraying with 100% humidity in the air so I changed my plans.
Instead, I focused my attention on cleaning the dash. It had years of dust and grime from use accumulated that had to go. I removed most of the a/c duct work and scrubbed it clean inside and out. Wash, rinse, repeat once again
09-11-2016, 08:47 AM | #361 |
Happy to be here
I found a broken mounting tab on one of the vent ducts and set about repairing it. Fortunately the broken pieces had remained intact so I created a matching piece to add strength and super glued it back together.
With the glue dry, I did a final cleaning and installed the new LMC vent. Take note if you do this, there is a felt washer on the old vent that's much thicker and better made than the new one on the LMC replacement. I removed the old one with a razor blade and used it instead. This resulted in a nice tight fit of the vent that will adjust easily, and stay where you put it.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-12-2016 at 09:52 AM. |
09-11-2016, 08:56 AM | #362 |
Happy to be here
For now the stock am/fm will remain. I gave it a good cleaning with Windex and a toothbrush. Not as dramatic and improvement as the dust was, but much better for now.
09-11-2016, 09:04 AM | #363 |
Happy to be here
One last detail before closing shop. The dash speakers will be replaced soon, so I got the brackets ready. I needed to remove them to clean under them anyway, so why not clean and paint while they are out. I know they can't be seen with the dash pad on, but I feel better that they are restored anyway.
09-11-2016, 10:57 AM | #364 |
A buddy of mine showed me a trick on the a/c vents. He found rubber o-rings that fit over the plastic piece that lets the vent swivel up and down. I can't remember if this works on that lower vent in the cluster, but I know I did it on the center vent and it made it move nice and smooth. I thought I had a picture from when I did mine, but I can't seem to find it now.
I don't remember that Napa red. I used SEM Firethorn red on my dash and door panels. It's pretty close, but not quite as marroon looking as the factory color. |
09-12-2016, 08:15 AM | #365 | |
Happy to be here
I looked online, but didn't trust color charts on my monitor. I felt more comfortable seeing them in person so I went to my local PPG store. I compared unpainted parts to SEM Napa Red and it was a very close match. Since I will be dying everything it won't really matter so that's what I went with.
09-12-2016, 08:31 AM | #366 |
Happy to be here
Sunday was pivotal. If Chris and I couldn't make serious progress with the interior parts it would be a major defeat. We got the majority of the upper interior pieces dyed, but our focus was on the door panels. We knew they would require a slow build process so our goal was to get them done.
I had ordered brushed aluminum trim from LMC Trucks to replace the billet inserts. They look very nice, but did require a couple of holes to be drilled. Once installed with the provided PAL nuts the fit was good. They do not come with holes for the pull straps. We opted to eliminate the straps for now. I tried to clean and polish the door handles and the related handle pockets with no success. The handles were too pitted, and the pockets scratched deeply enough they just couldn't do. I ordered new handles from Auto Metal Direct and bought the pockets locally from Outback Truck parts. We are done with the panels and waiting for new handles to arrive so we can install them.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-12-2016 at 09:55 AM. |
09-12-2016, 08:36 AM | #367 |
Happy to be here
While waiting for dye to dry Chris and I worked on lots of small parts. He pulled the rear view mirror and sanded the surface rust down then gave it a fresh coat of satin black.
I cleaned and painted several small parts then started on the steering column. It was chipped around the ignition switch so I sanded it and primed the raw spots. Once we get of few more critical pieces we can do final assembly.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-12-2016 at 09:56 AM. |
09-12-2016, 08:40 AM | #368 |
Here's a pic of the SEM Firethorn red. I didn't paint the door pockets so they are the factory color (or LMC's version of the factory color). Just looking a the Napa red can you posted, the top looks more maroon so it's probably closer. My dash was a new replacement, but it was black. The door panels and headliner trim were the same factory color as yours. I found that the SEM die sticks better to the softer materials like the dash. My door panels have a few scratches since I painted them, but they've held up fairly well. It's been about 3 years now.
09-12-2016, 08:43 AM | #369 | |
09-12-2016, 10:02 AM | #370 |
Happy to be here
I really like the Firethorn red much better than the Napa red, but I had a dilemma to deal with. The carpet has been replaced with Firethorn red but the kick panels havent. The seat belts, vinyl on the seat, and headliner matched the Napa red the best so I went with Napa to prevent having to gut the interior.
In the end it will "match" best, just not my first choice of color on a red truck.
09-12-2016, 03:23 PM | #371 |
http://www.usa1industries.com/chevy-...-burgundy.html
This is actually a 100% match, I didn't want to dye my whole door panel so I spotted in the top edge, matches perfectly. |
09-12-2016, 05:49 PM | #372 | |
Happy to be here
I picked a color that would help bring the different shades together.
09-12-2016, 10:17 PM | #373 |
That front end looks great! Like new. The painted inside of the bumper shows itself off well in your pictures. I see that you used VHT primer. They also have a high heat product with ceramic. I just bought a can of flat aluminum color to use for my tailpipes and more as I get the chance.
http://www.vhtpaint.com/high-heat/vh...eproof-coating |
09-13-2016, 10:24 AM | #374 | |
Happy to be here
Yes I really like VHT paint and have seen the VHT ceramic paints. Unfortunately they are all flat. The paint I used on my exhaust has a nice satin sheen to it so it's not as porous as flat paint.
09-13-2016, 10:31 AM | #375 |
Happy to be here
Some nights in the shop are a lesson in frustration. The dash pad is in excellent condition and it appears to be a GM replacement. It had two layers of dye on it and the bottom layer was peeling and lifting. I had no choice but to strip the entire piece.
I worked very gently to prevent damaging the grain on the surface while removing as much dye as possible. It was a tedious process, but it's finally done. I will be able to spray it tonight and install it tomorrow.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-13-2016 at 12:30 PM. |
