05-21-2021, 08:40 PM | #351 |
Re: Orson the 49 GMC ~ Chris C.
We have installed the fuse box
We began to wire the body harness And the speaker box design was finalized today, Monday they head to the plasma cutter.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 05-22-2021 at 10:25 AM. |
05-25-2021, 07:42 PM | #352 |
Today we got the steering column in primer, wet sand and paint tomorrow.
The headlight and turn signals are all wired
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 05-26-2021 at 09:39 AM. |
05-25-2021, 07:44 PM | #353 |
The new PCM arrived and we installed it, still no spark. This harness is junk. When you Connect the battery there is no voltage to the PCM relay or any of the fuses! And of course I am unable to contact the seller. $260 wasted! I’ll have to buy another one!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 05-26-2021 at 09:40 AM. |
05-26-2021, 09:07 PM | #354 |
We got the steering column in paint today
We spent more time cutting out and replacing Michael's shotty work We created and fit the Transmission tunnel We even wired and installed those expensive turn signals
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 05-27-2021 at 09:14 AM. |
05-27-2021, 09:06 AM | #355 |
who's harness did you get?
05-27-2021, 10:00 AM | #356 |
EZ wiring
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
05-27-2021, 11:36 AM | #357 |
I went with a painless wiring harness.
05-27-2021, 12:04 PM | #358 |
Painless is nice, but rich for my blood. I paid $150 for the EZ
06-01-2021, 08:44 PM | #359 |
We accomplished a lot today...
The body harness in the engine bay is all finished up
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-02-2021 at 09:15 AM. |
06-01-2021, 08:50 PM | #360 |
The old engine harness is remove
the tail section is now all attached to the frame
06-01-2021, 08:52 PM | #361 |
And the column is finally finished!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-02-2021 at 09:16 AM. |
06-02-2021, 08:45 AM | #362 |
Good progress, thanks for sharing.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-02-2021, 05:50 PM | #363 |
You bet! The goal is that more folks are undaunted!
06-02-2021, 10:40 PM | #364 |
We got the dash all finished and painted.
06-02-2021, 10:46 PM | #365 |
in paint
06-08-2021, 12:59 PM | #366 |
pretty stuff!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-08-2021, 09:29 PM | #367 |
Thanks!
Today’s progress, we wired the ignition. The new engine harness came in, so that will be going in in the next few days (hopefully then it’ll be a runner) we continue to work on that dash (it still doesn’t meet my standard) the dash is holding everything up The back wall of the cab goes into final paint tomorrow
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-09-2021 at 09:36 AM. |
06-09-2021, 08:35 PM | #368 |
Still working on that dash
This is how we create the hidden stereo Here it is mocked up And I’ve decided to put a 2 USB power adapter behind the ashtray
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-10-2021 at 09:35 AM. |
06-09-2021, 08:37 PM | #369 |
These are the side panels for your 6.5” kick panel speakers
And the back of the cab in final paint!
06-10-2021, 11:23 AM | #370 |
Nice work on the truck and I've been following the build. My question is once you mount the hidden stereo in that plate you made, is it going to leave enough room for your wiper motor?
06-10-2021, 07:07 PM | #371 |
yup, I’ve done it many times before
06-14-2021, 08:10 PM | #372 |
We spent all day fitting the front bumper, not quite done. Will finish tomorrow and move on to the rear bumper.
Switched sides on the brackets to tuck it up and removed 3 inches from the brackets
06-15-2021, 08:53 PM | #373 |
We finalized the front bumpers Position and made the brackets
06-15-2021, 08:55 PM | #374 |
We welded them on and leveled and installed the bumper
We then mocked up and got 2/3 of the way done with the rear brackets
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 06-16-2021 at 08:42 AM. |
06-15-2021, 08:57 PM | #375 |
Here’s some more
