05-20-2016, 12:53 AM | #3726 |
Re: What did you do to your truck today? Chapter II
Thanks man ....sometimes I try to do good.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-20-2016, 02:34 AM | #3727 |
bought a cap rotor plugs some fuel line and an air filter..... oh.... and added another qt of oil
05-20-2016, 10:13 AM | #3728 |
Wow that grille looks great ! .
I bought a GM Heritage grille , no way the body man could make it fit back on went the old one . I don't think those headers were ' ruined ' . If you're not going to use the choke stove you'll have to put a brass plug in the hole so it doesn't puff soot all over your lovely engine . My truck is mostly stock but I searched until I found some long oil and ATF dipsticks from a G Series van , now I don't have to reach in at all to check my oil and tranny .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
05-20-2016, 05:23 PM | #3729 |
Was going to order some Digi-Tails LED taillights but their website if FUBAR.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
05-20-2016, 10:38 PM | #3730 |
Nothi'n like fresh carpet.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
05-20-2016, 11:02 PM | #3731 |
Nice carpet ! .
I'm thinking of using green carpet to match the paint....
05-21-2016, 12:36 AM | #3732 |
You guys are way ahead of me. Today I flapped what was left of the rotten carpet out of the way and pried the rust-locked connector loose from the old decrepit high/low beam switch as it fell apart in my hands. Worked loose the screws, cleaned them up, and put in a brand new switch. I love it! Works great! My first use of a #3 phillips screwdriver in a long time.
05-21-2016, 04:01 PM | #3733 |
tried to sand blast the bed today didn't work out going to have to try some chemical first . like the look of the flat black though
05-21-2016, 04:23 PM | #3734 |
Finally got the truck road worthy. First fill up, got it weighed so I can get my tags, needed in California, first wash, and made the hour and half ride home yeah!
05-23-2016, 12:11 AM | #3735 |
Pulled my retract seat belts. They sure cleaned up nicely. Other than one faint scratch in a boot ("pictured" on right) the boots are like new. The interior on these trucks were sure made well. Cloth seats excluded, IMO.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-23-2016, 01:22 PM | #3736 |
Not today, but I forgot to post when I did this. Fabbed a bracket for my fuel psi regulator.
Gotta remove it for paint yet...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-23-2016, 01:35 PM | #3737 |
Bought LED taillights, side markers and front park/turn lamps.
05-23-2016, 01:35 PM | #3738 |
05-23-2016, 01:42 PM | #3739 |
I used a Mallory 4207 that I bought from member Madmartigan. You can get them thru Summit, Jegs, etc. I used the Eddy fuel line kit with filter, then used a 45 degree flare female swivel - to - 3/8 male pipe adapter, then a brass 3/8 pipe street elbow. I made a new fuel line to go from the mechanical fuel pump to the elbow coming out of the regulator.
I used a Holley non liquid-filled gauge, as I read the liquid filled ones are not accurate once the underhood temps come up. I have about $100 in the setup, but I got a good deal on the line kit (Amazon, it was a returned item so it was discounted) and regulator. The bracket was just a piece of scrap steel that I cut with a bandsaw and rounded the edges with a bench grinder, then bent it in a vice with a soft hammer. I made a template out of paperboard beforehand and it fit perfectly.
05-23-2016, 02:49 PM | #3740 |
Over the weekend, I noticed a slight vibration when applying the brakes, seeming like the rears. This morning I pulled the drums and found the shoes needed replaced along with a turn on the brake lathe. Headed to pick-up the drums now, was a lot easier that I expected, like all the other drum brakes I have ever done over the years.
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
05-23-2016, 03:12 PM | #3741 |
05-23-2016, 03:15 PM | #3742 |
At some point the vac canister must have broken thru the mounting on the side of the AC box under the hood. Dad just covered the huge holes with gray duct tape and remounted it lower which also got broken at some point. I cut and mounted a plate to cover and seal the holes and remounted the new vacuum ball.
At some point in the future I may try to find a new AC box half, but for now it works.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-23-2016, 04:23 PM | #3743 | |
Posted via Mobile Device |
05-23-2016, 05:02 PM | #3744 |
Not a problem, glad to help.
05-23-2016, 05:41 PM | #3745 |
New seats started interior
05-23-2016, 07:43 PM | #3746 |
Are those Procar Pro90 lowback seats? If so, how do you like them? I was toying with the idea of installing those in my truck. I can get them at Speedway Motors which is local to me so I'd save a ton on shipping.
05-23-2016, 08:04 PM | #3747 |
05-23-2016, 09:24 PM | #3748 |
Broke it
05-23-2016, 09:36 PM | #3749 |
owch
05-23-2016, 11:03 PM | #3750 |
Finished the crazy dealings with California DMV to get my out of state truck registered and got my tags.
