05-23-2016, 11:13 PM | #3751 |
Re: What did you do to your truck today? Chapter II
05-23-2016, 11:36 PM | #3752 |
05-24-2016, 12:17 AM | #3753 |
Priming and sanding parts
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-24-2016, 03:42 AM | #3754 |
Spar Urethane on the wood, and painted the tailgate.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
05-24-2016, 07:59 AM | #3755 |
What color is your truck? I really like that blue.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-24-2016, 08:42 AM | #3756 |
05-24-2016, 08:44 AM | #3757 |
Ok, thank you.
05-24-2016, 10:40 PM | #3758 |
Came home from work this afternoon and did some more sanding inside my box. It as a bit rough inside so we are going to smooth and repaint as a welcome home to the new wood bed. Here is one inner bedside I am working on.
05-24-2016, 10:50 PM | #3759 |
RAT1968 '68 Cab/'71 Parts
Had to take the cover off, charge the battery, and start her up as far as operating temperature before she went back to bed....Too many
"better-do-'ems" today...
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
05-24-2016, 10:56 PM | #3760 |
05-24-2016, 10:58 PM | #3761 |
i replaced the rubber fuel lines on my truck
I used Gojo lanolin hand cleaner on all the rubber bits under my truck. I scraped about four lbs of grease sand and rocks off of my trucks frame and drivetrain. I sucked about 2 gallons of bad gas out of my trucks fuel tank |
05-24-2016, 11:15 PM | #3762 |
Cleaned up the more of the grime today. This is the third time around with the scraper, p washer and gunk degreaser.
I almost feel bad about washing away the years of frame saving greasy tar like goop. Lying in the wet greasy grass too blast the underneath isn't any fun. But I did reveal a Chelsea plate on the pto. Think im Almost there MAYBE one more time around.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-25-2016, 12:46 AM | #3763 |
made a custom gage bracket for my new auto meter gauges.
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
05-25-2016, 01:02 AM | #3764 |
So clean!!! Nice work.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
05-25-2016, 03:25 PM | #3765 |
I ordered a factory style tach conversion for the instrument cluster, a new bezel, a door jamb switch harness, courtesy light harness, a new engine harness with HEI support built in and a new temp sending sensor. The temp gauge in my cluster has never really read the temps quite right, always reads low. I think this is because the sending unit is for a 1976 engine/truck (came with the sb400 I installed). I'm guessing 1976 gauges were calibrated differently. I hope to be buying new bucket seats soon as well.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
05-25-2016, 06:22 PM | #3766 |
Put some advanced safety feature in the truck. Out with the bench seat in with the power Sebring Convertible seats($50 half off sale at the junkyard). I also picked up a f-250 jumpseat off craigslist for $40 that needs to go in. I cant find a pic of the bench but oh well.
05-25-2016, 08:24 PM | #3767 |
Those seats look good.
05-25-2016, 08:30 PM | #3768 |
new c10 project, leave the way it is or full restoration?? Ideas
05-25-2016, 09:04 PM | #3769 |
Thanks, they were a steal. I had to pull apart the passenger side seatbelt and rebuild it because it was stuck due to the accident. But everything went smooth, just about 10 minutes of my time and fiddling with the internals. I now need to figure out how to make a little extra room for my legs. I am 6ft and I lost about 2 inches of room. Next step is disc brakes and then getting parts for the LS swap to fit in the truck. The donor silverado is waiting patiently to be torn apart.
05-25-2016, 09:12 PM | #3770 | |
Drive it. Enjoy it.
Chris '69 C-20 '04 Jeep TJ |
05-26-2016, 12:26 AM | #3771 |
Ditched the chrome alternator and painted the billet bracket.
05-26-2016, 10:37 AM | #3772 |
I am almost finished with my Electric Vacuum Pump install, just have to wire up the relay and test it out..... I also finished wiring up the electric power window crank switches on the modded window regulators, (I had to move the crank stub forward 3/4" forward to align with the door panel holes) since I was at it, I cleaned up the wiring and drilled the holes to pass the wiring through the hinge pillar and door, now to install some conduits, rubber or what ever works, I think the braided steel ones I made are too rigid, they walk the rubber grommets out of the holes I cut, oh well, something that won't be seen too much any way.
I also finished my Van tilt steering column the other day, and once I get my power windows in, I can finish up the weather strips/vent windows, etc.. and start driving this bad boy! Pictures to follow! Have a good one! Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
05-26-2016, 11:56 AM | #3773 |
Started getting my new Boyd tank installed and adjusted the valves.
05-26-2016, 09:18 PM | #3774 |
got the speakers out from under the seat and the kick panels in what a difference . going to have to do something with the interior doors when grumpy new door panels get here that sky blue aint going to cut it . originally was planning on pulling the doors and stripping them out when I get ready to paint the outside so I didn't paint them when I did the rest but now with all the rest mostly finished its going to bother me that they look so bad
05-27-2016, 07:49 PM | #3775 |
Just dropped off my seat to have it patched. 2006 Silverado seats, driver's side has a hole in the fabric and into the foam, he said it may be done tomorrow, I hope so!
