Closed Thread
Old 04-16-2012, 07:08 PM   #3876
firemanmario
firemanmario's Avatar
Re: What did you do to your truck today!
went from no grill, to billet grill. Now I need to find a billet emblem.
firemanmario is offline
Old 04-16-2012, 07:39 PM   #3877
cobrajet21
cobrajet21's Avatar
I ended a 3 year break from working on it and cut the lower cowl and firewall off of it with my new plasma cutter.
http://67-72chevytrucks.com/vboard/s...d.php?t=288820
68 Chevy CST project
02 Chevy Silverado Ex.cab
71 Ford Torino Cobra
cobrajet21 is offline
Old 04-16-2012, 10:42 PM   #3878
VDOG
Grand PooBaa Member
VDOG's Avatar
Working on my new cab so I cut off the passenger side of my rocker panel to replace it. Now I have to go buy a welder and being a newbie who has never welded anything, this should be like going to hell in a handbasket.
VDOG is offline
Old 04-16-2012, 11:13 PM   #3879
RossRinSD
RossRinSD's Avatar
We all have to learn some time...
What welder are you thinking about?
For sheetmetal, the smaller 110V welders will reduce the amount of burnthrough. I'd really go with a MIG, that fluxcore stuff sucks, or a TIG if you have the money...
I have a Hobart 135 that has worked great for 15 years for me. I think now they only build 140's
1969 Chevy K10
1984 Chevy Monte Carlo SS
1998 Chevy Camaro Z28
2004 Chevy Silverado
2010 Chevy Colorado
RossRinSD is offline
Old 04-16-2012, 11:21 PM   #3880
VDOG
Grand PooBaa Member
VDOG's Avatar
From HomeDepot this is the complete kit for 280.00 just need to buy a gas bottle. True we all have to start somewhere, but looking at what I have to do, im not feeling this. Dont want to spend money if im not interested in welding.
VDOG is offline
Old 04-17-2012, 12:26 AM   #3881
RossRinSD
RossRinSD's Avatar
Once you start sticking metal together, it opens up the door for all sorts of new projects. You'll be able to make, build, and fix all sorts of cool things.
This was my latest, winch bumper, tow bumper, and rocksliders.
I do have all my rocker panel replacements, just need to find the time and get to work on them.
1969 Chevy K10
2010 Chevy Colorado
Old 04-17-2012, 12:57 AM   #3882
Mike Bradbury
Mike Bradbury's Avatar
VDog, that little welder is just the ticket for learning. It will be great for body panels and light duty stuff, but like Ross just said once you start you'll find all kinds of jobs to do.
Start with .023 solid wire (this will minimize the burn through) and a bottle of 75/25 argon/CO2 mixed gas and you should be fine for the body panels. To prevent burn through make a series of tack welds strung together (this is called triggering) but only after you have made a bunch of tack welds all around the perimeter.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 04-17-2012, 02:10 AM   #3883
ItsRandy
ItsRandy's Avatar
Finally got my evaporator plumbed and bolted in place...what a pain (I say that a lot lately). I have all of my air conditioning lines and heater hoses installed too. Pretty good for just a few hours after work.
ItsRandy is offline
Old 04-17-2012, 02:18 AM   #3884
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Bought a can of
18 oz. Arctic FreezeŽ "Ultra Synthetic" R-134a + w/reusable Dispenser/Gauge
Driving to work it was right at 32 degree's.
It's the coldest it has ever been.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 04-17-2012, 02:56 AM   #3885
RexDodge
Found a few more wires to replace on the back half, done, Wired my sending unit and fuel pump (waiting for relays), almost done. Took my gauge cluster out and started installing my Autometer tach (in the center hole. I'll finish that tomorrow and get it back in.
RexDodge is offline
Old 04-17-2012, 03:18 PM   #3886
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks guys!! After I cut or butchered that panel behind the rocker that I was not supposed to cut, I got discourged. Do I use a cutoff wheel to remove the rusted parts or do I use a sawzall? Again I have no direction so im just going at it.
VDOG is offline
Old 04-17-2012, 04:15 PM   #3887
RossRinSD
RossRinSD's Avatar
I like the cutoff wheels, seems more precise, use the thinnest ones you can find. Sawzall, air powered body saw, spot weld drill, air chisel, BFH... You'll use it all.
Did you get your patch panels already?
You can use a bunch of big magnets to hold stuff together for welding. A big hunk of brass behind the weld will support the cherry and sink heat out of the surrounding metal while you weld. And flapper wheels for dressing your stitches work great. Go slow, too much heat in one spot is gonna warp the panels.
Next thing you know, shaved door handles and chopped tops.
1969 Chevy K10
2010 Chevy Colorado
Old 04-17-2012, 06:34 PM   #3888
VDOG
Grand PooBaa Member
VDOG's Avatar
I was going to get them today, but Jr was not feeling good today so I will go tomorrow. The thing is, I really have no interest in welding. Thus why I was going with one with no gas. I know everyone said gas is best, but my problem is I dont want to spend the money on something I'd rather pay someone to fix. Just me I guess.
VDOG is offline
Old 04-17-2012, 11:51 PM   #3889
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Took my used Pro Comp rims down to my mechanic to get some used tires mounted on them. Got some for $30. Someday I'll work again and be able to afford nice new ones.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 04-18-2012, 12:51 AM   #3890
ItsRandy
ItsRandy's Avatar
Installed all of the slide switches and wiring harness for my heater/cool controls for my Vintage Air system.
ItsRandy is offline
Old 04-18-2012, 03:25 AM   #3891
Mike Bradbury
Cool, you got one! are you going to the Brothers show this year? I would like to check it out in person.
Old 04-18-2012, 01:47 PM   #3892
mmmBoost
Unhappy Re: What did you do to your truck today!
<<<(((SOLD)))>>>
NO I DIDN'T SELL MY TRUCK LOL But I did sell my beater to force myself to finish my truck. Good bye Import
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 04-18-2012, 05:19 PM   #3893
bollybib
bollybib's Avatar
I installed a new hose from the windshield washer reservoir to the pump. The old hose failed every few months because it would split apart at the pump connection.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 04-18-2012, 07:20 PM   #3894
trev1
Sanded and painted the trim for the cab. What a pain.... all the way up to 1000 grit....
trev1 is offline
Old 04-18-2012, 10:31 PM   #3895
sjarrett71
sjarrett71's Avatar
Installed a power brake booster. Man, the brakes work SOOOO much better!!
-Scott-
sjarrett71 is offline
Old 04-18-2012, 10:42 PM   #3896
ffk
ffk's Avatar
got the frame outside in the sun..frame looks awsome..i used epoxy primer and eastwoods semi gloss chassis paint...
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline
Old 04-19-2012, 08:12 AM   #3897
wrwelton
wrwelton's Avatar
Put the turbine wheels back on truck
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 04-19-2012, 08:16 AM   #3898
wrwelton
wrwelton's Avatar
Put rear bumper on truck
wrwelton is offline
Old 04-19-2012, 05:43 PM   #3899
VDOG
Grand PooBaa Member
VDOG's Avatar
Picked up some patch panels today.
VDOG is offline
Old 04-19-2012, 07:23 PM   #3900
69 GMC forever
69 GMC forever's Avatar
I painted the bottom of the truck white and added some new trim and wheels
when the smoke clears all your gunna see are my Tail lights
69 GMC forever is offline
Closed Thread
