12-31-2008, 09:03 PM | #376 |
1 thing at a time is progress.
Re: My 1965 build thread
Block Party Everyone's invited. JK Ya'll would be interested until I told you what you needed to bring,......sanding blocks I don't like days like today. I spend 7-8 hours sanding, sanding, and more sanding. I did get the dash ready for primer. I'm trying to get the cab ready to prime the final time. I had forgotten about all of the little spots that needed attention. Since the dash took so long. Seam seal still needs to be finished. These pictures are about as boring as this post. Happy New Year everyone!! Digging the old seam seal out (sand blaster doesn't get it). Repairing pits from deep surface rust. Ready for sealer The dash is ready for primer.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 12-31-2008 at 09:25 PM. |
12-31-2008, 09:22 PM | #377 |
The Few, The Proud
Looking good Alan. I've got a cab you can practice your skills on when you're ready.
Shannon |
12-31-2008, 09:22 PM | #378 |
1961 crewcab
Shoot I forgot to have ypou practice on my truck while you were here
lookin good! |
12-31-2008, 09:28 PM | #379 |
Sand paper doesn't work good in 15 degree weather and neither do I
Alan
Philippians 2:14-16 |
12-31-2008, 09:31 PM | #380 |
You might want to learn some on mine, so you can handle yours when the time comes..
Alan
01-02-2009, 10:16 PM | #381 |
Alan, the photos are not boring at all. Those of us that cannot get to our projects for whatever reason, really enjoy seeing the progress you are making. Even if it does not feel like much to you. Keep the updates coming.
01-03-2009, 01:49 AM | #382 | |
I couldn't get off of my arse today, still enjoying the vacation. My motivation came at about 10pm. I got a little done just to uncover that there is alot to do before I can sling some paint. I've been debating to myself........Should I block this opening up. For some stupid reason I think it would be a good cold air intake. More than likely I would never do it. I think I'm trying to find excusses not to do it. I'm thinking of just painting the block off plate. Located another fuel door with filler neck off of a F**d Ranger. Driver door still lumpy. Going to spray slicksand on it. I believe it will fill enough so it can be blocked out then primed. Blocked on the roof and discovered a butt print. Slicksand might cure that problem as well.
Alan
01-03-2009, 02:52 AM | #383 |
60-66 Nut
If you aren't likely to use it, IMHO it would look better welded up and finished rather than just painting the block off plate. You've done an outstanding job this far, it would just not fit the look of the rest of the truck with the block off plate. Just my .02
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-03-2009 at 02:55 AM. |
01-03-2009, 03:04 AM | #384 |
CHEVY ONLY |
01-03-2009, 06:28 AM | #385 |
1961 crewcab
I'll throw it the other way...
cold air intake like on the chev z11 would be cool. Last edited by jonzcustomshop; 01-03-2009 at 06:40 AM. |
01-03-2009, 10:38 AM | #386 |
Hollister, CA.
I was just thinking about that motor.....Yeap, that would be an awesome idea to run it as a cold-air intake.
I would defiantely consider it....plus you would keep the cowl free of leaves and crap !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
01-03-2009, 02:09 PM | #387 |
I am on the Cold Air Intake side of the fence. It would be a nice feature to add.
01-03-2009, 02:18 PM | #388 |
Shloooooong bed member #2
Alan,
I am in agreement with Captainfab. But honestly with your skills you could make either work, and make it turn out nice.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
01-03-2009, 08:37 PM | #389 |
Gets my vote too (that & some pocket change nets you some pocket change ).
01-03-2009, 08:50 PM | #390 |
One day...
Thats a cool idea how they use it as an intake! I like it
01-04-2009, 12:38 AM | #391 | |
Now does anyone have an air cleaner like that laying around. Thanks to everyone else for their input. I'm so confussed. I like the cold air intake idea, but afraid it will take away from a nice and clean engine bay. If done right it might add to the appeal. I've never seen one done to this style truck. I'm sure Jon might have a pic. The roof, LT door and dash got some Slick Sand sprayed on them
Alan
01-04-2009, 12:50 AM | #392 |
wow
that slick sand looks cool
CHEVY ONLY |
01-04-2009, 01:13 AM | #393 |
I was told by a painter that it's not a primer. The label says it doesn't need to be sealed prior to topcoat. It's like a sprayable filler to remove minor imperfections. Once I block it I will prime then block with 400. It's cheaper than primer and metal glaze. It applies evenly minimizing sanding. It is thick and requires a 2.0 gun tip. It can be thinned a little like I had to do tonight due to being 55 degrees.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 08-17-2010 at 06:26 PM. |
01-04-2009, 01:29 AM | #394 |
wow that is cool!
thanks for sharing!
CHEVY ONLY |
01-04-2009, 01:39 AM | #395 |
I like turtles...
looks great!
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
01-04-2009, 02:05 AM | #396 |
Thanks for the pic of the can.I was wondering what to ask for.
Can't wait to see the after pics. |
01-04-2009, 01:35 PM | #397 |
Beautiful work man. Love the frame color.Is that oem or the color you chose.
01-04-2009, 02:17 PM | #398 | |
I think a better option would be one of the NASCAR 'used parts' places. You should be able to pick up a used NASCAR style air cleaner shroud & adapt it to your firewall (NASCAR cars get their cool air from the firewall/base of the windshield). They're made from both aluminum & carbon fiber & usually go for less than $150.
01-04-2009, 04:50 PM | #399 | |||
This should be entertaining to ya'll. Let me know if you find it informational. I'm a little camera shy.
Alan
01-04-2009, 05:06 PM | #400 |
Got it,Thanks. PPG 301274.
Video is cool.Dont be shy,,,you have amazing skills some would kill for.That should boost your confidence. |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
