12-11-2014, 09:41 PM | #376 |
Re: Let's see some 73-87 1 Ton Dually Pictures!
The inside spacer is just that (a spacer). The one used for the outer wheels in an adapter. Spacers are just inserts of varying thickness. Adapters are secured to the original stud threads & utilize a different set of studs to secure the wheel.
12-11-2014, 10:57 PM | #377 |
It's an adapter if it adapts a different bolt pattern. Spacer if it spaces the wheels apart.
12-11-2014, 11:20 PM | #378 |
I'm gonna be running 315-75-16 tires so I'll be needing a 2 inch for the inside and then prolly 2 inch for in between the tires..so I wonder which ones I would actually need..
12-11-2014, 11:49 PM | #379 | |
Dont you love the way it handles/maneuvers like a sports car compared to a compared to a full wide strech or crew truck? Check out my POS in the projects/builds.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
12-12-2014, 02:30 AM | #380 |
It's an adapter if it has studs w/threads; even if it's the same bolt pattern.
12-12-2014, 10:28 AM | #381 | |
http://www.roughcountry.com/wheel-spacers-1099.html http://www.gotshocker.com/product.php?productid=17233 http://store.roadkillcustoms.com/8-l...-bolt-pattern/ http://www.sky-manufacturing.com/cgi...TRLSPT-AWS-865
12-12-2014, 11:32 AM | #382 | |
12-14-2014, 09:20 PM | #383 |
“Being ignorant is not so much a shame, as being unwilling to learn.”
― Benjamin Franklin
12-14-2014, 09:32 PM | #384 |
and to think i thought there would be pictures of duallys in here!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
12-14-2014, 11:21 PM | #385 |
Better?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
12-16-2014, 12:21 AM | #386 |
12-16-2014, 12:43 AM | #387 |
The bottom pic is with worn out 215/85/16's on a 2" lift. The other two pics are of new 235/85/16's on the same 2" lift.
12-16-2014, 12:14 PM | #388 |
01-05-2015, 11:10 AM | #389 |
For sale on eBay in Nashville. 1980 K30 dually crew cab 54 k orig mile California truck 2nd owner truck One respray of a real deal original truck California truck no rust ever or damage 400 small block truck runs like new with fresh headers and Flowmasters NV4500 trans conversion makes it like a new truck RPM wise so very fuel efficient for a 1 ton AC works perfect Heat will make you sweat Truck was brought to Tennessee in 2010 and the mods done in 2011 and has had only 1500 miles since just too many toys mods are as follows: New Skyjacker 6'' lift New not junkyard NV4500 trans and conversion kit (makes the truck) New wheels and New BFG TA Ko tires 33" New interior headliner,carpet,correct seat covers,dash pad and windshield New crossover steering set up and all new frt suspension components New custom driveshafts for the lift New removable gooseneck hitch set up |
01-05-2015, 12:58 PM | #390 |
^^^^ Good lookin rig!
01-13-2015, 12:10 PM | #391 |
Here is mine. Waiting in springs from ORD then I can finish the 2 to 4wd conversion.
01-14-2015, 03:14 AM | #392 |
Squarebody guy
01-22-2015, 01:36 PM | #393 |
NOT MINES but whoa nice
01-22-2015, 02:40 PM | #394 | |
Long live SLIM ------------------ At least try to buy American |
01-22-2015, 03:47 PM | #395 |
lol@ DADE COUNTY, here is some progress on mine.
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
01-22-2015, 04:54 PM | #396 | |
01-23-2015, 05:49 AM | #397 | |
02-11-2015, 10:45 AM | #398 |
Here's a couple pics of a 79 1 ton dually I recently shortened to a short bed length. Was going to put it under my 68 Dually but after reading all the trouble with the swap I went ahead and just shortend my original frame 60 inches. Yep 60.
So now, what to do with this one? I do also have 4 squares sitting at my mountain property so I might just wait on this one for a future project. Anyhow, saw this thread asking for pictures of 73-97 1 ton dually and thought you guys might want to see pics of what one looks like undressed?
"Life is too short to drive a boring vehicle". Later, Wayne |
02-11-2015, 10:16 PM | #399 |
Just about done with my 4wd conversion. Have to mount the front shocks and brackets and finish the crossmember for the engine.
02-14-2015, 06:04 PM | #400 | |
something doesnt add up, either those arent 33 inch tires, or that isnt a 6 inch lift, it is however a very nice truck!!
