11-22-2010, 09:04 AM | #376 |
One day...
Re: How about some pics of '73-'91 Crew Cab Short beds?
yeah he was posing in both.
11-23-2010, 06:55 PM | #377 |
I have been pretty busy coaching (HS girls soccer), then spent 2 weeks in Moab, UT and Lake Powell, AZ.
After all that sun, I have been pretty unmotivated to go work out in the rain... I thought we had a solution; looking at the LMC catalog, they list different rear cab mount "cushions" for 3/4 ton and 4x4 vs. 1/2 ton. It made sence that that was the problem and the guy that did the work said that he runs into a similar problem on the 67-72 trucks (he is well known for his expertise on those trucks). I measured the frame to the ground and the body to the ground (don't remember the exact measurements) and while the frame had a rake to the front, the body was level. This suggested that the cab was sitting lower on the frame towards the rear of cab than the front. He said it was possible that he used the cross-member that was in the best shape without noticing that the cushions were different? But after going back and looking at the catalog, the cushions being different only applies up to 1980? They do list different cusions for 81-83 and 84-87, but the project truck and donor truck were both 87's. The mechanic suggested putting some shims under the cushions and said that is a common thing to do on the 67-72's when swapping cabs. I had the laser programmer at work make a quick program to cut some 3x3 plates with 5/8" holes in the center; (8) 1/4" thick and (8) 1/8" thick. I ended up using half of each on the cab and having to use the other half on the bed to keep the body line even. I am still off a little bit so I had (8) more of each made (this time with slots instead of holes so I could just slip them over the bolts instead of having to remove them) but have not had a chance to go put them on yet. While swapping doors, fenders and hood (before realizing I had the alignment problem with the bed) I was having no luck at all getting any of them to line up worth a damn. I am no body man so I just assumed that was something the body shop could correct when it ever goes in for paint. I bought a cowl hood and to get the front of the hood flush with the front edges of the fenders I had to slide the hood real far roward in the hinges leaving a masive gap at the back of the hood. I just assumed that this was due to it being an aftermarket hood. I loosened up the bolts from the fenders to the cab before jacking it up to install the shims. When I was done for the day I noticed that the door to fender alignment was WAY better than before. Also, the hood now sticks out past the front edges of the fenders; when I loosen the hood to slide it back in the hinges the gap between the rear of he hood and the cowl should be halved. I assume all of this is because the cab has been tipped forward? This would seem to tell me that he used the 1/2 ton X-member and that they are in fact different... except for all the shims I have to put under the bed also??? I think another 1/4" and maybe another 1/8" shim under both the bed and the cab should have it dialed. But then I have to add progressively smaller shims for the other three sets of bed bolts too, at least for the middle two sets. Bottom line is I have a way to get it to look right, but I am not sure if it is the right way to make it right...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
11-23-2010, 08:48 PM | #378 | ||
Yeah Quote:
Guess it all comes down to "can you live with it"? If the answer is Yes then go for it! Posted via Mobile Device
CHEVY ONLY |
11-26-2010, 01:07 AM | #379 |
Doesn't seem to really make sense why the box doesn't line up though.
12-10-2010, 06:25 AM | #380 |
here is a couple of pics of the one i picked up a few weeks ago! Last edited by joe231; 05-19-2011 at 04:56 PM. Reason: had double "http://" |
12-10-2010, 09:52 AM | #381 |
Looks like a nice project!
12-22-2010, 05:05 PM | #382 |
any information on the red & beige truck in the back ground ? nice looking truck.
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
12-22-2010, 10:35 PM | #383 | |
its just $$$$$
79 2wd Blazer, Mostly original paint, real cool truck, wish I had that one back |
12-23-2010, 09:29 PM | #384 | |
Luv the Crewcabs
Just wanted to bring back up for any new builds we may have going on, Would like to see more pics in the Club???
Thanks, Rick Quote:
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
12-23-2010, 11:18 PM | #385 |
i have an 81 swb i redid about ten years ago that i want to stretch into 4 doors since 2 car seats and wife wont fit in the front seat with me very well i have everything to do it but the cab itself cant seem to find a rust free cab in nebraska or everyone want a fortune for a complete pickup around here keep looking on craigslist and every other site
12-25-2010, 04:57 AM | #386 |
i just bought a rebuild fuel injected 454 with 0 miles on for mine.
12-25-2010, 10:51 AM | #387 | ||
have you started a build thread? we need more pics!
CHEVY ONLY |
12-25-2010, 10:28 PM | #388 |
were at in oklahoma? i am about 8 hrs from norman what options for the cab and color is it?
thanks eric everingham |
12-26-2010, 06:50 PM | #389 |
no have not but i will soon im just gathering parts at the moment
12-26-2010, 08:11 PM | #390 | |
No doors, it has a/c though. I think it is either light brown or orange and white 2 tone. It is in the far east side of OKC. I'll see if I can find the guys number Posted via Mobile Device
CHEVY ONLY |
02-05-2011, 06:36 PM | #391 |
CHEVY ONLY Last edited by joe231; 02-05-2011 at 06:37 PM. |
02-15-2011, 12:00 PM | #392 |
Glen
Pretty cool laid out CCSB. I found this on the Dropsicles CC website under their Lethbridge, AB chapter. www.dropsicles.com
Says the owner is Rich and its a 1985 Chevy Crew Cab short box.
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
05-13-2011, 04:50 PM | #393 |
Formerly- 1972SuperCheyenne
Any more out there?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-14-2011, 11:39 PM | #394 |
its just $$$$$
just realized I hadn't posted my latest one in this thread
05-19-2011, 01:31 PM | #395 |
Luv the Crewcabs
These pics were in the other thread about Crews..........
Rick
05-19-2011, 01:33 PM | #396 |
Luv the Crewcabs
Would it be Possible to make this Thread a Stickie???
Rick
05-19-2011, 03:24 PM | #397 |
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 05-20-2011 at 12:09 AM. Reason: Thanks Joe for hookin' me up! |
05-19-2011, 04:50 PM | #398 | |
nope, sorry.
not for lack of trying either.... Quote:
CHEVY ONLY Last edited by joe231; 05-19-2011 at 04:53 PM. |
05-20-2011, 01:45 AM | #399 |
...what size tires are you running? And what drop front/rear? I am doing the same thing to mine except keeping it 8 lug and using a cab and chassis 14 bolt which is narrower for a wider meat out back. Going to stick with widened stock steelies in a 16"...
nice ride by the way, build thread?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" Last edited by Devillusion; 05-20-2011 at 01:46 AM. |
05-20-2011, 09:21 AM | #400 |
If I started with a 1ton DRW crewcab, what would the smartest way to get the parts needed for a CCSB conversion? Buy a 1/2 ton parts truck?
Don't light me up for axing a stupid question. Never really used my dually for what I bought it for and maybe this way I can actually get some use out of it. |
Tags |
ccsb crew cab short |
