#376 |
Re: Jimbo's 67 Long bed step side build
Verrrrry Nice! coming together nicely.
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#377 |
![]() Join Date: Mar 2011
Truck has been done for awhile, just posting pic fast....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#378 |
Thanks Cam, appreciate it.....Jim
#379 |
Pic 1 This is the stock location of ash tray in the Jag console.
Pic 2 I installed the ign. switch here, and will have a push button start above where chrome ring is now. With the door closed no one knows(except everyone checking out this post ![]() ![]()
#380 |
Pic 1 Checking fit of Kick panels (panels from Rod Doors).
Pic 2 Pass. side with speaker grill in place.
#381 |
Pic 1 Installed new battery tray.
Pic 2 Headlights and trim installed. Pic 3 Checking out the routing of AC lines, etc.
#382 |
Pic 1 Making new center cover for console, to line up with new locations of controls, vents, etc.
Pic 2 Aluminum cover installed for shifter boot. Pic 3 Fitting new center cover for console. etc.
#383 |
Pic 1 Stainless piece for covering radiator.
Pic 2 Rubbed out and installed. Pic 3 Front view.
#384 |
Pic 1 Fitting a stainless band to shroud.
Pic 2 Here the band is being rubbed out. Pic 3 Band installed on shroud.
#385 |
Pic 1 Installed new overflow container for radiator.
Pic 2 Checking new knobs for headlight and wiper switches.
#386 |
OK guys, that's it for today.....Jim
#387 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Wow lots of red in that engine compartment...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#388 |
Yeah, it gets your attention......Jim
#389 |
Hope all you Dad's had a great Father's Day
![]() Pic 1 Running brake lines from valve down to frame, etc. Pic 2 Another view.
#390 |
Pic 1 This is a Jag door handle, it's being modified to work with the 67 latches.
Pic 2 Welded in a plate and checking fit. Pic 3 Can be adjusted with the turnbuckle. Pic 4 Here's the drivers side. Pic 5 With door panel in place it will look nice (after it's covered in leather).
#391 |
Pic 1 Brake parts being painted.
Pic 2 Booster also painted.
#392 |
Pic 1 Power window buttons added to console.
Pic 2 These are Foose design mirrors added to the outside doors. Pic 3 Another view (they were added to the corner piece of the one piece glass kit).
#393 |
Working on linkage for carb, trans, etc.
#394 |
Pic 1 Getting ready to cover kick panels in Ultraleather. ABS plastic must be sanded good.
Pic 2 Here you can see where glue has been sprayed, first half is done. Ready to glue other half to panel. (I use Weldwood Contact Cement). Pic 3 Everything pressed into place on front side.
#395 |
Pic 1 Back side has also been sanded, put glue around the edges, fold over, trim corners, etc.
Pic 2 Finished panel. (Here's can of glue I use). Pic 3 Rubber installed around the door jams, panel installed with speaker in place.
#396 |
That's your pics for today, catch you tomorrow.....Jim
#397 |
VA72C10
![]() Join Date: Mar 2008
Very nice! You do good work!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#398 |
The break lines, door handles and kick panels look great, along with everything else! your attention to detail is phenomenal.
#399 |
Thank you. There are so many on here that do good work, I appreciate you putting me in the group
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 06-20-2011 at 09:49 PM. |
#400 |
Thanks for the compliments, Cam. I'm better than some, but there are a LOT better than me. There are home builders on here that just amaze me with their talent. Detail is one of those things that doesn't cost to much, but sure pays off in the end.
