02-12-2013, 07:14 PM | #376 |
6>8 Plugless........
Re: 72 k20 project
Nice work, I look forward to seeing your rear suspension. On mine I'm planning ultra cheap but heavy duty. Heavy duty semi trailer trailing arms with huge 1" bolts and I might use schedule 80 pipe. I have 4 new air bags from a trailer I purchased years ago. We'll see when if I get to this any time soon.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-12-2013, 10:09 PM | #377 |
Re: 72 k20 project
i will recommend to stay away from pipe. it isnt built to withstand forces the same way as mechanical tubing. i can imagine the trailing arms will be more than enough, that **** is manly.
i need to order the bags, and ill have to build some dummy links until i get my ends, but i got a start. hope to put in a little time after work each night. tonight was burning out the parts. tomorrow is some bending and maybe a little welding. you can see my idea for weld washes in the pic. i still need to punch the holes. i prefer to use the ironworker for bolt holes so they are right on. we can scribe locate the holes on the plasma table so they are in the right spot too. |
02-12-2013, 10:14 PM | #378 |
Re: 72 k20 project
The base material is .250" and the weld on parts are 10ga. total thickness at the stress area will be over 3/8"
02-13-2013, 02:19 AM | #379 |
Junk Yartist
Re: 72 k20 project
Man that is a lot of welding you have to look forward too! That thing will be over the top! By the way, "weld washes"? What is that? The double thick parts that hold a load?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
02-13-2013, 10:25 PM | #380 |
Re: 72 k20 project
Weld washers are just metal welded over the bolt hole to add more material for the bolt to act against. helps keep the holes from getting ovaled. i just had to go all ritzy for mine. i had considered using a normal style stepped weld washer and 3/16" material. my need for adding weight bled through and i did the thicker material and cut out stuff.
got it all bent up and all the holes punched. tomorrow, Weld. |
02-13-2013, 11:22 PM | #381 |
Re: 72 k20 project
Sweet bracketry!
02-14-2013, 08:43 PM | #382 |
Re: 72 k20 project
did a little welding tonight.
didnt get the last bit done on one. and a gratuitous weld shot. damn phone makes it all blurry. i promise i dont weld that blurry |
02-14-2013, 08:54 PM | #383 |
Re: 72 k20 project
I's just throw all that s**t in a box and send it to me.................................................
LMAO! It looks awesome! You're a god with metal dude!
02-14-2013, 10:57 PM | #384 |
Chevy Enthusiast
Re: 72 k20 project
Are you sure you don't have some kind of machine to do all of your welding for you? lol It definitely looks awesome!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
02-15-2013, 02:12 AM | #385 | |
Re: 72 k20 project
Thanks! |
02-15-2013, 10:48 PM | #386 |
Re: 72 k20 project
got the last of the welding done. hope to do some fitting on the frame tomorrow... not sure if ill pull the rear suspension yet, or wait till i have the bags. i still need to get the cab to the body guy, but i need good weather to haul it out of the garage and get it on the trailer...
Ryan |
02-16-2013, 12:03 AM | #387 |
Junk Yartist
Re: 72 k20 project
Weld candy my man!
02-16-2013, 09:45 PM | #388 |
Re: 72 k20 project
sort of mocked up. as always, there are hurdles i figured id have to whack the body mount. so it was. but now i am considering longer links. not that its really neccesary, but since i had to whack the body mount, i have a little freedom to move a bit. i doubt i do since i will be lowering the AS of the geometry the further i move it forward. also, i loosened the bends up a little with my welding so i need to tweak those a little before it can be welded up. oops. i didnt even think about checking it before i left work friday. i may be able to borrow a buddies press tomorrow to fix them, otherwise its waiting till monday.
02-18-2013, 03:20 PM | #389 |
Re: 72 k20 project
Very nice! That stinks the cab mount was in the way.
02-18-2013, 10:27 PM | #390 |
Re: 72 k20 project
i never get to bent about cutting off stock stuff! if i had a longhorn frame, id be in business.
DOM came in today... still a few tweaks of bracketry to be made. |
02-18-2013, 11:46 PM | #391 |
Re: 72 k20 project
I can hook you up! I have a spare frame!
02-20-2013, 10:41 PM | #392 |
Re: 72 k20 project
i cut a few 1"x.120" sleeves to use as spacers when it all gets welded. i faced them to get them all square and equal length.
got all the brackets in order, tacked the inside on, and measured for the access hole for the body mount. now i have to cut the hole... |
02-20-2013, 11:13 PM | #393 |
Junk Yartist
Re: 72 k20 project
More weld candy! Makin me want to go get my welder fired up!
02-20-2013, 11:53 PM | #394 |
Carpe manana
Re: 72 k20 project
Looks good!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-21-2013, 09:16 AM | #396 |
Re: 72 k20 project
Im not even sure what these cost me yet. id have to calculate that all up first. Ryan is wanting a set too, so if i need to cut two i can. ryan |
02-21-2013, 04:36 PM | #398 |
Re: 72 k20 project
I foresee a side product for you my friend!
02-21-2013, 10:46 PM | #399 |
Re: 72 k20 project
i am still a little sketched about not having any real R&D on it. for all i know, it will suck bunghole when i finally drive it.
02-21-2013, 10:49 PM | #400 |
Re: 72 k20 project
And Josh, i am not sure how the geometry will work on a lower truck. you had planned to do a 2wd right? i saw your wedge for sale, so maybe you are gonna do a 4x?
it may not be all that reasonable on a 2wd with my heights and angles. i am pretty sure ryan will be OK since he and i are close to the same in height. his is a little longer, but that will be no big deal on the AS. in fact, he may be a little taller an that would help bring it back to the sameish Ryan |
